Weistec Engineering Oil/Air Separator Group Buy 2014
#176
MY12 C63 P/P
#177
Former Vendor of MBWorld
Weistec Engineering
#178
07 E63 + 07 CLK63CAB
Called Weistec and got immediate courtesy. and a quick responding picture when I asked where in the "***" does the catch can fit under the hood of a 07 E63. Jonathan answered as soon as they pulled a E63 into the shop and sent the pic, 10 minutes max, behind the headlight which was my thought as there is no room as shown by the firewall. A phone call is always answered, Right Steve ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Very happy using another fine well designed Weistec product, for all 63 owners, look into the billet pulley sets, plastic MB pulleys are so prone to failure.
#179
#180
You possibly misunderstood my comment, the E63 has the engine ecu power cable running in the spot by the firewall so my query was just where did they recommend for my car, they had a 63 on site so the sent a picture of where it should go although it was tight it looks like it belongs there. As for instructions really it is quite simple, unbolt the PCV valve reposition the adaptor to the PCV hose to can hose from can back to engine what is so complicated. I take it the C63 is more crammed in that the E63.
#181
#182
MY12 C63 P/P
#187
is it true that our car does not have an air/oil separator of some sort from the factory, or do we and it is inefficient? don't all cars have one to some extent? just curious.
#188
12 C63 : 03 Jetta
more or less it's a breather valve. it's not inefficient for what it was designed to do. it lacks a component to take out harmful spray the Germans just don't quite think about oil migrating everywhere and carbon build up.
#189
is this breather valve the line that goes from the "y" pipe to the intake manifold (right adjacent to the pcv mounting hole)?
#191
Gotta say that 200 miles after install I opened the canister and there was a surprising amount of oil. I am beyond a believer in this product now and can't imaging how much oil is blown by after thousands and thousands of miles. For those that must know how much a surprising amount is all I can say is that the entire bottom of the canister was covered about 2mm deep? Fantastic product.
#199
I have over 600 miles on the car and see nothing in the can other than a smell of crank case.
Do you run high RPMs a lot, manual shifts, holding rpms in lower gears.
Just thinking that is a lot of blow by you are getting, is the oil level in the car at the correct place, (no over fill).
Would not worry though as you should still have warranty, have you had to add much oil in the 3800 miles to maintain?
#200
Thanks for the concern but my engine is fine. Do most people read their manual? The manual clearly states that these engines may consume almost a QUART of oil every 600 miles. Especially when new. Blow by is one of the ways this consumption takes place and my catch can "caught it" fantastically!
