C63 AMG (W204) 2008 - 2015
Wheel spacer specs for our cars??
Old Jun 16, 2014 | 01:29 AM
AMGPower88's Avatar
C63 AMG
Im still running the stock 18" amg wheels and I want to get 10mm spacers for the rear and 15mm spacers for the front, can someone give me the correct size to buy in terms of lug pattern etc. and which kind of extended bolts I need?
Old Jun 16, 2014 | 01:54 AM
Conv_GSDriver's Avatar
'18 Audi A4
well the PCD is 5x112 for these cars. The stock bolt stud length is 14x1.5 so anything a little bit longer than that.
http://www.boltpatternguide.net/Merc..._Patterns.html
Old Jun 16, 2014 | 08:54 AM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
AMGPower88,
We have the 10mm Spacers and 15mm Spacers available on our website from H&R. You can get to the Wheel Spacers by clicking HERE, or by clicking on the photos of the Wheel Spacers below.
We also have the correct MB Ball Seat Wheel Bolts for your car available as well. You can get to them by clicking HERE, or by clicking on the photos of the Wheel Bolts below. The OE Wheels Bolts for your car are M14x1.5x21 (21mm being the length of the Wheel Bolts). If you are going to put spacers on your car, you will need to get longer Wheel Bolts to accomodate the length of the Wheel Spacers.
If there is anything else we can help you with, please feel free to post or send a PM, or you can contact our sales department via telephone, email or Live Chat.
Old Jun 16, 2014 | 08:59 AM
mr747's Avatar
c63
Do you sell 20mm wheels spacers as well???
Old Jun 16, 2014 | 09:17 AM
ECSTuning's Avatar
2012 SLS AMG
mr747,
Yes, we do sell 20mm Wheel Spacers. You can get to them by clicking HERE, or by clicking on the photos of the 20mm Wheel Spacers below.
If there is anything else I can help out with, please feel free to post or send a PM!
Old Jun 16, 2014 | 09:37 AM
mr747's Avatar
c63
So will I get away with 40 mm or 43 mm bolts??? On a 20mm spacer?a.
I'm running these spacers on 16 in wheels on the rear for slicks
Old Jun 16, 2014 | 09:40 AM
ECSTuning's Avatar
2012 SLS AMG
mr747,
That depends on the length of your current wheel bolts. Are you using the OE 21mm wheel bolts, or are you using something different with the 16'' wheels you are running? Measure one of the wheel bolts you are currently using, and add 20mm to it to account for the spacers.
Old Jun 16, 2014 | 09:48 AM
OlegKouz's Avatar
2012 Diamond White C63 Coupe
H&R Spacers are definitely the way to go, very satisfied with mine.
Old Jun 16, 2014 | 09:49 AM
mr747's Avatar
c63
I wil order these tomorrow
I'm running I'm running standard wheel bolts
I will purchase the 43mm bolts and shave 3 mm off
Old Jun 16, 2014 | 10:38 AM
Mort's Avatar
The shank length on the OEM bolts is 27mm.
Old Jun 16, 2014 | 12:53 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
ECS - if you're going to peddle your warez, at the very least you can make sure you sell the guy the right bolts for the application. The OEM bolts are M14x1.5x27, not x21. Using 21mm bolts on the C63 is extrememly dangerous to say the least.
Old Jun 16, 2014 | 01:06 PM
ECSTuning's Avatar
2012 SLS AMG
Code 797 - AMG 19'' Spoked Wheels With Mixed Tires (OP Did not mention 19'' wheels, so I assumed he would be using the bolts that are listed in the EPC (21mm in length).
See attached MB EPC screenshot.
Old Jun 16, 2014 | 02:00 PM
Diabolis's Avatar
The EPC is incorrect on this. Both part numbers are M14x1.5x27, with the regular bolts being silver and the Code 797 bolts being black. Physically they are both the same with ~27mm shaft length.
Old Jun 16, 2014 | 02:13 PM
ECSTuning's Avatar
2012 SLS AMG
Diabolis,
I have looked into this further, and spoken with someone at MB dealership, and you are correct. In fact, the latest revision of the EPC noted that part number (000 990 49 07) as being M14x1.5x30.7
I have updated our website accordingly, so as not to confuse customers. Thanks for the heads-up.
Everyone,
Be sure to measure your wheel bolts and to buy the correct size bolts if you are installing wheel spacers. Also remember, if you are using OE Mercedes-Benz wheels to use Mercedes Ball Seat Wheel Bolts. For those that do not know, Mercedes Ball Seat Bolts are different than other Ball Seat Bolts. They must be used when using genuine Mercedes-Benz wheels.
