C63 AMG (W204) 2008 - 2015
Head bolts getting done....
Old Jun 28, 2014 | 11:48 AM
Infiniti's Avatar
a unicorn tuned p30 e63
Hey guys,
The head bolt job got approved by my local dealer and i just had a few questions.
Is there anything i can do while the motor is apart other than long tubes ?
What should i be expecting and or looking for?
Any advice or input is appreciated.
Thanks,
Old Jun 28, 2014 | 12:06 PM
olszowa12's Avatar
'08 C63 Estate
The headbolts are getting done under warranty? :O
Old Jun 28, 2014 | 12:24 PM
whoover's Avatar
'19 E63S sedan
Originally Posted by Infiniti
Hey guys,
Thanks,
Cam follower replacement is standard part of the job. If they weren't going to, have them use the M159 followers. They're straight replacements and a better design. Insist, even if you have to pay for the parts. Also, make sure they check for cam lobe wear.
Old Jun 28, 2014 | 03:00 PM
Ingenieur's Avatar
C63 AMG
Did one fail?
Did you have a cel and coolant loss re: the sib?
What year? Are you under the original or cpo warranty?
They are doing under warranty and upon request?
Old Jun 28, 2014 | 03:23 PM
neverbroke's Avatar
GTR R35
Not under warranty but getting my head bolts issue fix.
What is Cam follower?
Head bolts getting done....-32144c7b-c59d-41fe-91a7-02afd4eceabd_zpscwnjn4fp.jpg
Old Jun 28, 2014 | 03:26 PM
Ingenieur's Avatar
C63 AMG
So you are paying for it?
Did they fail?
Is MB doing it goodwill?
Details please
Cam followers are the buckets between the cam and valve
Old Jun 28, 2014 | 03:37 PM
AMGPower88's Avatar
C63 AMG
Did they fail?
Details please
+1... NEED details
neverbroke's Avatar
GTR R35
coolant and Oil mixing when checking the dip stick repair being done at local shop, OEM parts are about 800.00 and labor 1500 to 2g's
replacing heads gasket stud bolts and other little things.
installing shorty header while i'm in there.
Old Jun 28, 2014 | 03:44 PM
Ingenieur's Avatar
C63 AMG
Are any bolts broken?
Old Jun 28, 2014 | 03:47 PM
neverbroke's Avatar
GTR R35
heads and bolts coming out monday or so.
Old Jun 28, 2014 | 04:28 PM
Ingenieur's Avatar
C63 AMG
Let us know if any are broken
Or if they break while being removed
Also take some close up pics broken or not
Thnx
Old Jun 28, 2014 | 04:52 PM
neverbroke's Avatar
GTR R35
Thnx
will do.
Old Jun 28, 2014 | 04:58 PM
Petakii63's Avatar
C63
Use the m159 valve buckets and arp head studs! You'll be good to! Forget the shorty headers. Waste of money.
Old Jun 28, 2014 | 05:27 PM
neverbroke's Avatar
GTR R35
After i take a look at the VB i'll make a decision then, If they look good they stay.
Shorty header already got them from a member here for a nice price.
After looking at the factory manifold anything in better, arp head stud are over priced so im leaning to the new OEM stock bolt for now still up in the air.
Also once you run 1000 mile or so on ARP studs you'll suppost to go back in and retorque them.
factory studs are one time use, set them and for get them.
Old Jun 28, 2014 | 05:46 PM
whoover's Avatar
'19 E63S sedan
After i take a look at the VB i'll make a decission then, If they look good they stay.
False economy on the buckets! Stock are a bad design and cause tappet noise and cam lobe wear. The new parts are cheap at twice the price.
Old Jun 28, 2014 | 06:15 PM
Ingenieur's Avatar
C63 AMG
I have no problem with the revised oem bolt
I would definitely use the revised m159 buckets while you're in there
My 2 cents
Old Jun 28, 2014 | 06:45 PM
Infiniti's Avatar
Yes under cpo
Deff will do!
Did one fail?
loss of coolant, terrible idle and engine surging at times. 09 bought it with 17k about a year and half ago now has 45k
way to hijack
I was thinking of using the weistec oil/air seperator, but i want to see how the intake looks when out first. Will deff have my guy check for cam wear.
Old Jun 29, 2014 | 01:06 AM
Conv_GSDriver's Avatar
'18 Audi A4
Interesting thread, definitely following. For sure the pictures of the removed head bolts will be a plus, seen some nasty ones on here aleady from that same issue.
Old Jun 29, 2014 | 10:25 AM
Ingenieur's Avatar
C63 AMG
How did they confirm a bolt broke?
Any cel's
Did they do the any tests?
Bubbles in the coolant?
Coolant in the cylinders?
Etc
Let us know if they find a broken bolt and post the invoice if you don't mind
Old Jun 29, 2014 | 11:17 AM
Merc63's Avatar
C63 AMG
Looks like they are pulling engine and tranny out the front, wonder why not just lift engine straight up and out.
Old Jun 29, 2014 | 11:20 AM
Ingenieur's Avatar
C63 AMG
Isn't it easier to remove the engine/tranny as an assembly?
Old Jun 29, 2014 | 04:50 PM
Merc63's Avatar
C63 AMG
I had the tranny dropped in 40 mins.
Removing all those hoses and rads in the front is a huge pain.
Old Jun 29, 2014 | 05:56 PM
whoover's Avatar
'19 E63S sedan
Why do you think they're pulling the engine if they're just working on the heads?
Old Jun 29, 2014 | 06:10 PM
Ingenieur's Avatar
C63 AMG
Might be easier and a better job since they are doing headers too
Much easier to work on an exposed engine
Old Jun 29, 2014 | 08:18 PM
bhamg's Avatar
C63 AMG
Does anyone think replacing motor mounts at the same time might not be a bad idea?
