head stud install
07 E63 + 07 CLK63CAB
Motoman, of the 3 German sources is there any one source that has multiple failures. We had talked before about AMG designers obviously did not buy all the headbolts at one time and we see more failures in the C class for some reason but recently a few of the E have rose up, was going to say popped up but!!!
I run Water wetter in all cars do you believe this will reduce the formation of "micro bubbles" with the coolant system?
The failure is always the head coming off. The original bolts, with inset pattern, are the problem. The new bolts, with external pattern, are the solution. It has nothing to do with corrosion. If it did, the breaks wouldn't be at the head where the head gasket protects the metal. The head was not redesigned -- the bolts were.
The chemistry of our coolant is pretty complicated. I wouldn't add anything.
It's more common on the C's since there is alot more C-63's made, not to mention because of this more are actually driven. Non of mine had failed yet, this was more of a preventative maint. no cotton gloves used for the install, but they got fresh latex gloves
lol you think germans will ever admit they did something wrong? The new design isnt because the old ones are bad or fail, it's because they improved them AMG engineers are too busy with the new motors to worry about problems cars out of warranty have.
C63AMG, NIssan NX2000, Pontiac Fiero GT
We have so far only seen the "big world" defects visible to naked eye. There are several "small world" failure mechanisms of interest. IMO 1. stress corrosion 2. tensile strength (hardness) 3. crevice corrosion (remote). Takes high paid guys on high priced equipment -scanning electron microscope (SEM) to analyze. Seems MB addressed 2. above with the newer bolt by dropping the hardness to M 9.8 from M 10.9.
I spent a year surveying test labs. Most don't like private parties, but several will do the work . Prices $1700 low, $ 2400 typical. Best deal offshore Mumbai India at 1/3 US prices. Never brought this up since I could barely get ahold of even several sample bolts. Knowing how hard a group buy is, such a group ante seems difficult. Will supply sources if asked.
We never did establish any pattern of headbolt failures by vendor , I believe. I am not familiar with water wetter.
Head gaskets cannot protect the the headbolts which pass thru along with the coolant which surrounds the shoulder and flange.
WaterWetter®
- Unique agent for cooling systems that doubles the wetting ability of water
- Rust and corrosion protection allows for use of straight water in racing or reduced antifreeze levels in warm climates
- Improves heat transfer and reduces cylinder head temperature
- May allow more spark advance for increase power and efficiency
- Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. Vehicles with larger cooling systems should use two bottles. Small cooling systems should use 1oz (3 to 4 capfuls) per quart
- Compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
- Satisfies ASTM D2570 and ASTM D1384 corrosion tests for glycol-based antifreezes
let's get some bolts tested, that will tell us how much the strength has been reduced (for what ever reason)
would be nice to have samples from various years and mileage.
you start collecting data like this and MB USA will take your arguement more seriously
I use the Water Wetter, basically a surfacant, better contact between coolant and metal, ie, better thermal transfer, or so they claim
#32
Have there been any reports of the new bolts failing? I haven't heard of one case. If you guys believe the problem is with the bolts' environment and not their design it's only a matter of time before new engines start failing.
#33
environment may be a factor in the time to failure but the root cause is the bolt design (I think everyone agrees on this?)
MB has tacitly acknowledged that by changing the bolt design
#34
camshaft adjuster loose
camshaft adjuster tensioned with special tool - earlier styles can just use a bolt in the back when removing to lock in place
this is the inside of the camshaft adjuster with the special diamond plated friction washers laying out to the right. make sure you replace them, these and the camshaft bolts are the only thing that hold the adjusters to the camshafts there aren't any dowel pins to key them
adjuster installed
right bank pulse wheels aligned ready to torque down
left bank pulse wheels aligned ready to be torque down
adjuster installed
thx
#36
Thanks for the pictures, they are great for people like me who don't know what the parts look like. You mention the cam adjusters were loose. Did you know this before you opened the engine or was there something that gave signs of the problem? Also how many hours do you think a MB garage would typically quote for opening the engine for inspection. (sorry for so many questions
thx
thx
#37
2012 ML63 AMG, 2015 RAM 2500, 1968 Charger
I realize this thread is from some time ago, but I'm in the midst of doing weistec head studs on my 2010 C63 and I'm trying to get as much information as possible so this is the only time I have to do this job. My question to anyone who has the answer is, what type of head gasket do these engines use? Is it an MLS gasket or composite? The reason I ask is, I already have coolant leaking into one cylinder, its what prompted the repair. It's not excessive, however, the top of the cylinder is wet, the spark plug ground strap has a thin film of white material caked to it, so it's been leaking for at least a brief period of time. I'm wondering if the head gasket is a MLS design, if it's possible to remove the head bolts one at a time and replace them with the studs if doing so will seal the leak and thus, prevent me from having to remove the head? I realize that with older composite gaskets, once they leaked fluid, they were saturated and therefore, would never again create a seal. However, I believe an MLS head gasket is capable of re-establishing a seal once the pressure is reapplied. It's obvious that I have a stretched or broken bolt in the area of the cylinder that's leaking, and that's what's causing the leak. My concern is, I really do not want to remove the head, but I want to do this job twice even less. So, if there's a chance I can get away with doing one bolt at a time, I'd like to get away with it. If those of you out there who have experience with MLS gaskets, of which I have none, can weigh in on the integrity of the seal after a leak has developed, I would greatly appreciate it. Thanks gents.
#41
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If the gasket has been compromised at all, head(s) off and replace. Sorry.
#42
@BLKROKT - I mean no disrespect with what I'm about to say, so please do not take offense; I am merely trying to collect information in an effort to make an educated decision. Having said that; what evidence do you have to substantiate your claim? You responded with the exact same reply in the head bolt DIY discussion where I asked the same question. I certainly appreciate your response and opinion, but forgive me if I don't blindly trust what you say without some information to back up your statement? The reason I'm even asking this question is I have absolutely no experience with MLS gaskets, but I have heard they are very resilient and have even heard of people reusing them on engines that have already been run. I have read that as long as the coating on the top and bottom of the gasket is not disturbed, an MLS gasket can actually be used more than once without issue. Again, I don't know because I have no experience with MLS gaskets. I am looking for people who do. If the m156 was manufactured with a composite gasket, I wouldn't even be asking this question; I know full well that if a composite gasket is compromised, its useless and needs to be discarded, end of discussion. But, since I believe that due to the higher compression ratio these engines develop, AMG used a multi-layer steel gasket and I have heard/read many different things about these gaskets. Please be more specific about what makes you say that if there is a leak of any sort; even if that leak is due to a broken fastener, not necessarily a failure in the gasket itself, that a new one has to be used and cannot just be re-torqued. Thanks in advance.
#43
The HG appears to be is metal according to any online part catalog.
Looks like it's multi-layer metal as well on the Wesitec site. I would guess once it has been soaked in coolant it could compromise the mating surfaces.
#45
This is exactly what I'm trying to avoid. Maybe I'm beating a dead horse here and I should just make the effort to remove the head and replace the gasket, but the further I get down into the engine, the more concerned I am that something may not go back together properly, I might break something, more gaskets and seals are required, etc. Again, if I can get away with it, I want to avoid removing the head if at all possible. I suppose that on the bank with the issue, I could remove all the ******* bolts, replace them with the studs, fill the cooling system, pressurize the system and see what happens. If that cylinder fills with coolant, I know I'm taking the head off, but I'm 80% of the way there. If it stays dry, then I can take a calculated risk that the gasket will seal once everything is up to operating temperature and properly expanded. Thoughts anyone? Anyone tried this?
#48
If it hasn't hydro locked already replacing broken studs with new ones and firing it up isn't going to hydro lock it...
The right way to do it is definitely replace them properly or your never going to trust it in the future even if it does work...
#49
If he has a coolant bubble trapped between the HG preventing proper mating. What's to stop it from creating a water path channel? You bet your *** hydro locking the motor is on the table of possibilities...
#50
It's worth a try. If a metal gasket, tightening down the studs will push out any liquid as you clamp it down. I'd bet it will be fine. There is an enormous amount of clamping force with those studs torqued.
I've seen Harley's with leaking metal head gaskets, torqued back down and be absolutely fine.
There's no way your going to hydro lock the engine unless that gasket blows apart.
