head stud install
#51
2012 ML63 AMG, 2015 RAM 2500, 1968 Charger
It's worth a try. If a metal gasket, tightening down the studs will push out any liquid as you clamp it down. I'd bet it will be fine. There is an enormous amount of clamping force with those studs torqued.
I've seen Harley's with leaking metal head gaskets, torqued back down and be absolutely fine.
There's no way your going to hydro lock the engine unless that gasket blows apart.
#52
Someone asked worst case scenario and that's it. Odds of it happening?
![](http://www.quickmeme.com/img/49/49ded2238ba4eaaca94bf22f509c13db3e7699d8a1934664cd942a491650b05f.jpg)
#54
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
There's the opposing view point I was looking for! I think what I'm going to try is doing the head bolts, then filling up the cooling system, pressurizing the system and see what happens. I'll be sure to post my findings and let everyone know what I find. Thanks for the vote of confidence Merc63.
I find it hilarious that this little discussion has happened in a thread made by a guy who CLEARLY knows what he is doing, didn't take any shortcuts, and preemptively replaced his headbolts before they failed, AND lifted the heads and did the HG too at the same time out of an abundance of caution. Good thinking there, and pretty much the exact opposite of what you're contemplating.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Well said. Do it right the first time.
#56
@ BLKROKT - I really did not intend to anger anyone here and I honestly am not trying to go against what someone with the experience and knowledge that I don't have, says. However, I clearly stated that I was not trying to be disrespectful and very clearly asked you not to take offense and asked for some evidence of what experience you had with these gaskets that have lead you to believe that the only option at any point is to replace the gasket. All you could do was personally attack my response to someone who provided some experience they've had with some steel gaskets. If someone at some point hadn't questioned the universally held truth the earth was flat, we'd all be all be walking around believing that today. I realize that's a crude analogy, but what I'm asking here is if anyone has tried what I'm proposing and no one has been able to say they have. I'll say it again, if we were dealing with a composite or graphite gasket here, I would t even be asking this question; I have the experience with those gaskets that tells me that the sealing capability of that material once it's been compressed is gone. But, I have no experience with steel gaskets and I'm here looking for people who do. Plain and simple. If 9 out of 10 people respond and said, I have worked with steel gaskets for years and tried more than once to re-use/re-torque them in the sort of situation your describing and you're wasting your time trying to re-torque that head with the old gasket in there, then I am content to trust their knowledge and experience and follow the advice I'm given. But, without knowing what level of experience the ten people who've responded here have, I can only assume that someone has told them the only option is to replace the gasket, and the someone they heard that from told them same thing and no one has even tried what I'm proposing. Merc63 offered some experience and I was happy to hear from some who didn't just respond by saying "if you already have coolant making it past the gasket, head's off". I appreciate everyone's time, point of view, and responses here, it's all good discussion. Additionally, I'm not trying to say that I'm going to try this and throw it all back together and not even test it before I try to fire it up and bend a rod. What I'm suggesting is torquring everything down, pressurizing the system and seeing what happens. I would think that would be a good test for people here who have experienced similar issues to mine. If it doesn't work, it doesn't work. If it does, we'll then, I may save someone like me time, money and the possibility of causing damage to the short block by removing the head. I readily invite someone to tell me that they've tried what I'm suggesting and it hasn't worked. Once again, thank you for those of you who respond with useful and helpful information.
#57
Ok, fair enough. Totally my bad. Good luck.
#59
Exactly what I'm thinking, my labor is free. If it doesn't work, then all I'm doing is pulling the studs and coolant back out and I'm right back where I need to be to get the head off. I figure it's worth a shot. Thanks for the reply guys.
#60
So, I got into the sick puppy this weekend and much to my surprise, I had not a single bolt come out cracked, rusted or visibly stretched in any fashion. They all looked brand new. I forgot to take a few pictures of those, but will when I get home tonight and post those. I want to get the small amount of sealant they each have around the top of the fastener off and see if any of them have stress cracks where the head meets the shaft of the bolt, but I didn't see anything on initial inspection. I worked methodically, replacing each bolt with a Weistec stud, in the proper torque sequence, following the Weistec directions carefully. I'll take some pics of them in the head tonight as well and report back. Although none of them were cracked or broken, the torque required to loosen them was pale in comparison to what the torque required to torque the studs down was. I don't know what the actual difference in torque is since the factory service manual uses degrees of rotation as opposed to the torque specs that Weistec gives, but I can tell you I was working MUCH harder to get the nuts to 110 ft lbs than I was to get the bolts loose. At any rate, all ten are in on the driver's side and I'm anxiously awaiting my new pressure tester to see if the studs have re-established the head seal and go from there. If the cylinder in question starts weeping coolant then I know they're all coming back out and I'm adding a head gasket set to my list of parts. I've also been filming most of my progress with two different Go Pro cameras and will, when all is said and done, post a series of videos on You Tube for others wishing to tackle this job by themselves. Finally, I took some pics with my borescope to show just what the inside of the cylinder can look like when you have the low coolant issue. Obviously mine was nowhere near what happens to some with regard to hydrolock, etc., but mine was definitely burning coolant, if only a very small amount. Very obvious by the look of the spark plug as well as what the piston looks like where the problem is with my particular engine.
#63
Took some pics of the bolts and the studs in place as well as pressure testing the system. Gonna leave it pressurized all night and see what happens. Again, crossing my fingers none of the cylinders are full of coolant in the morning. Wish me luck!
#67
07 E63 + 07 CLK63CAB
The piston/cylinder with the coolant leakage or burning as you state would have been clean unlike the others that would have the carbon build up. This is quite obvious when the head is off, also the combustion chamber will also be clean of deposits.
During the firing of the cylinder the coolant turns to steam and thus the cleaning action, 1 drop of coolant will expand approx. 15000 times when the transfer from liquid to gas occurs.
Just sayin!
Just sayin!
#68
Just sayin!
Just sayin!
#69
Update: Checked everything this morning after letting the system sit overnight with pressure on it and the good news is all the cylinders on the driver's side where I installed the studs are dry. However, now the opposing cylinder is wet. So, I'm going to button everything up on the driver's side and repeat the process on the passenger side. But, at least for now, it would appear as though the studs have reestablished the head gasket seal on the driver's side which was clearly leaking before I started this process. Will continue to report my progress as I move forward, unless no one cares, in which case I will stop wasting people's time making updates.
#70
Jk nice to see the one side appear to hold up gl
#72
Regards,
Justin Wade
2007 R63 AMG
#73
I know right?!? I was distracted by the shiny object outside! Any who, I'm trying not to grenade the glorious m156, so I'm doing one side at a time and verifying that the seal is holding. It's not a simple process, and I don't want to miss anything, I want to make sure I get everything right. So, yeah, I am also excited that the one side is holding, now I'm just crossing my fingers that I have the same luck with the other side. Stay tuned.
#74
Definitely keep posting. Interested. I decided to just get the updated Mercedes bolts along with ARP cam bolts, SLS valve buckets, and ARP cam phaser bolts. Got the updated bolts for only $10 each. Found it hard to justify the ARP pieces without a supercharger. Gonna get them installed in the next couple of weeks.
Regards,
Justin Wade
2007 R63 AMG
Regards,
Justin Wade
2007 R63 AMG
#75
I think you'll be fine. Those studs put an enormous amount of torque down on that head. Those bolts look brand new to what I've removed.
If I recall correctly, when doing the rotational torque sequence on mb head bolts, we were hitting around 80ftlbs.
