head stud install
https://mbworld.org/forums/c63-amg-w...ngagement.html
So i can only post so many pics in each post so there will be a few.
first up in order.....
My engine has about 30k on it, most of which with the oil separator too, these motors carbon up quickly regardless of how much you get on it. Here's what the cylinder head looked like.
My engine mounts were slightly collapsed, so might aswell replace them. here's new vs old.
this is the difference in the original stock, updated stock and arp weistec studs
here is what the pistons cleaned up to. loctite 7200 cleaner and plastic razor blades work great.
here is how the pistons started.
studs installed
This is how you remove and install the guide pin for the timing chain idler gear in the cylinder head - there is also a bolt that holds these in
cams are installed and lubed up, new lifters or hydrualic compensation elements as some would say - when removing make sure you label all the camshaft journals they are not marked from the factory.
cams are installed with the holding device - note the black bar in the back and the black fork tool across the front on top
this is the slide hammer and adapters needed to remove the chain idler pulley pin and chain guide rail pins
camshaft adjuster tensioned with special tool - earlier styles can just use a bolt in the back when removing to lock in place
this is the inside of the camshaft adjuster with the special diamond plated friction washers laying out to the right. make sure you replace them, these and the camshaft bolts are the only thing that hold the adjusters to the camshafts there aren't any dowel pins to key them
adjuster installed
right bank pulse wheels aligned ready to torque down
left bank pulse wheels aligned ready to be torque down
left bank
right bank
valve cover, make sure to replace the outside gasket and inside 4 spark plug hole gaskets
weistec valve body upgrade
and the motor is back in, not running yet but soon.
The bottom of the head in your first picture looks a little gnarly. The aluminum seems quite covered in oxidation. The rear cylinder also looks like there is something else going on in the combustion process. The first three have a burning slightly rich carbon look while the fourth has a more lean maybe coolant fouled look.
Oops. After looking at that pic again it sort of appears that the head might have some kind of cleaner sprayed on it?
great write up
did any bolts break or deform when removing them?
what positions were the most damaged bolts it
did any of the bolts cause you concern due to their condition?
old style vs. new
are the flared shanks at the top the same size?
are the flanges the same size?
If coolant leakage has been occurring in that cyl the it would be prudent to replace that piston if you are going for a high output engine.
Possibly Ingenieur could chime in on crystallization of the piston top.
Good job though, brings new insight into the upgraded head bolt issue. As well as the feature of the diamond plated friction washers, just wonder what the thought was by the designers of this engine by using this method instead of keyed, grooved, taper or interference fit to name a few, somehow although it seems to work there is always chance for slippage if the bolt torque is inadequate.
great write up
old style vs. new
Yes sorry that picture has the foam loctite 7200 cleaner sprayed all over it. I think i forgot to take the picture and remembered half way through lol. The rear cylinder 3/4 and 7/8 were the most carbon'd up. Cleaning took more time than the entire job.
How many km/miles on your motor?
very informative
Recall will never happen. alot of 272 and 273 motors had bad balance shaft gear, or timing chain idler problems with the teeth wearing off them. this didnt affect a few/small run of amg engines. It affected like 100,000 or so motors. No recall, just a bulletin. They get goodwill'd or extra assistance from mb unless you are just a total *** to the dealer.
The hard part ofcourse is finding someone competent to do this job properly.
Last edited by motoman; Jul 16, 2014 at 09:51 AM. Reason: clarify "dowel:" the shoulder just under the bolt head
We have posted the German sources (3). Earlier I suspected defects, but the (extremely low quantityand therefore suspect)samples I looked at seemed fit at 10x. Not even ARP nickel based studs can withstand worst case corrosion. ARP procedure calls for white cotton gloves when handling the studs during install.
Last edited by motoman; Jul 16, 2014 at 09:50 AM. Reason: why gloves? salt contamination from hands,think watch battery
Basically destructive testing on several bolts
Torque to yield and fracture/failure
Do the same for a new old style bolt if one can be found
To determine strength reduction
And test a new style
Needs certified by a lab/ engineer
Might be handy if litigation is an option
