Finally got my baseline dyno runs in
The tests were done on a dynapack at WORKS motorsports(Sonoma Raceway).
dyno room temps ranged from 80f-90f
pulls made in 5th gear
As i mentioned, there were some difficulties with the factory tune so i am a little confused by the results as they are very similar.(going to follow up with Jerry but ill post it anyways)
You can definitely see how much smoother the curve is on the eurocharged tune.
Stock tune- Notice the dip in the curve at 4k.
Stock tune- Torque and AFR
EC tune- 4K is smoother
EC tune- Torque and AFR
Stock tune- Room temp
EC tune- Room temp
The tuned files were the RED and LIGHT Green Lines
The ones which produced the lowest numbers..
Am I reading this right?
Base Line - 423.1hp
Tuned Control - 424.9hp
Base Line seems high and the Tuned Control seems low.
I am so confused by this.
I have a 2012 P31
The ECU Tuned Runs are in Red and Light Green
The Stock Tune Runs are in Magenta and Light and Dark Blue
In my case i think my top base was 431 and my top Tunes was 429 so I actually went -2 HP with the Tune
I think yellow is base line and green is tuned.
I think you went from 421.61whp to 431.76whp and 392.76trq to 398.055
And if you are a P31 package that is why I was thinking your original docs were a bit high on base line. Looks like on a P31 package the EX tune is worth 10whp and 6wtrq if I am looking at this correct....
This was how i ran it.
First run was with ECU flashed
Second run was with it removed, they were almost identical/
Third and Forth run was ECU flashed
Fifth was ECU Stock.
So actually my best flashed was -2 i think. vs my best Stock
So in short they were pretty much identical
Wich is inline with the OP's numbers and conclusion,
I don't have the RAW file anymore, i can't find it but the only difference is that i think i found the correct gearing ratio for the gear which is 3.861 and not 3.88 so maybe that adds the +7hp i have over his.
The top Torque was the light blue line - Stock
The lowest Torque was the red line - Tuned
The top HP was the Light Blue line - Stock
And the lowest was the light green line - Tuned
I reached out to them again and awaiting their feedback.
There is another member on here also with the same setup so lets see how this Reputable Tuner handles this.
The only other explanation is that the tune(s) did not get downloaded?
We have seen higher gains
Definitely on non PP
Can't recall on PP cars
Makes sense if all they do is remove the oem throttle restriction
So you need to look at the gains between the base and tuned run and work of that.
I use to have a non P31 2010 and the ECU tune made a massive jump/
But it looks like there is 0 gain from a p31 tune
I'd like to point out that the tune is not only for making higher numbers (which at this power level, and limitations on tire size is useless). I'm am very happy with how much better the car drives in a smooth manner. The power band is clearly refined in the tuned pulls. The factory tune was pulling power around 4k for some reason.
Also, give Jerry till next week to get back to you. I was lucky enough to catch him just before he jumped on a plane Tuesday. I've worked with him very little, but coming from a very similar career I can tell you he knows his stuff from the discussion we had.
As I mentioned in my original post, I had issues with my factory file which could explain what I'm seeing, but I wont know until I do a little tinkering with the memory on the programmer or wait for Jerry. Will keep you posted.
These charts aren't what I expected.
