VP101 Race Fuel Review
I was surprised that I did actually notice a bit of a difference as I will be the first to admit I was skeptical. At the end of the day, is it worth it for daily driving, no... But for those moments when you find yourself in a situation where the extra ponies could come in handy, it may just edge out an otherwise slightly overpowered competitor.
The *** end came out far easier today than normal, it always comes out easie, but this was noticeable for sure.
I also noticed both tires left black on the asphalt... I was under the impression my car did not have LSD, but now I wonder...
Thanks for reading. Hope this answers a few questions out there.
Not a 100hp gain, but def noticed a lil something extra.
If compared to what you regularly run the VP101 reduced knock, ignition timing would not have retarded and the engine will make more power.
I wouldn't go as far to say I noticed a power increase, more so just that it felt like the *** came out a tad bit easier, end result would be more power, but if I was hooking up and just blazing down the street I doubt I would have noticed anything at all.
The beast doesn't seem to mind drinking it...
Wish I had access to some in my area. Definitely worth a try.
Ive tried SUNCO racing 100 octane fuel and there is a difference. The engine is more responsive and without a question, better performance. Upgrades to Michelin PSS and the 507s true potential comes out and crushes the manufactures 0-60 times
I have a problem keeping it under 80 doing a quick 0-60 run! If you don't look at the odometer the entire time- she jumps very quickly from 45-50 mph to 80 with those two basic changes that are well worth it!
In the beginning (after about 2-3k miles on the brand new 507 engine)- I did 80% 91 and 20% 100- you can start to feel the difference in just how much more responsive the engine was right away. It actually idles much smoother when adding 100 or 101 octane. I did this just to see how the car ran- and the results kept getting better when getting more aggressive with the mix. The most I've done- and do it occasional is 50/50 mix. 0-60 times get in the mid-low/mid 3's consistently, if not better (when achieving max tire grip on track conditions/surface).
Thus far, I have 11.4k total miles (almost 2 years now, bought it brand new in 2013 of course) on the Edition 507 and been running 100 and 101 octane with mix of 91 for at least 5-6k miles, if not a lil more actually if I think about it. Car, even with people/extra weight in it- runs amazingly quick and pulls like no other C63 that comes out the box can.
A 3 mph gain is amazing ! this simply blows my mind, i am very much into 1/4 mile racing and to pick up that much trap speed does not usually come easy or cheap ... i plan to try this same test in the spring with my stock c63.
BTW... i just put some 101 in the tank yesterday, idles better, fact is... 11.3 to 1 will like higher oct.
The Placebo Affect is well documented....
bro, i do t know what people are talking about on all tjese threads. It makes a night and day difference. At least on my CL63 and it made the same amount of difference on my CL55 Kompressor. The second ypu crank the engine out the gas station you feel it.
