C63 AMG (W204) 2008 - 2015
For those who are running the eurocharged V5 tune
Old Sep 4, 2014 | 03:09 PM
itzjonjon69's Avatar
12 C63 Coupe
How does this throttle blipping work? Do i have to be in manual mode or sport? I was driving around in sport and when i was slowing down i didn't hear/feel anything different?
Old Sep 4, 2014 | 03:18 PM
Kriston's Avatar
C63 AMG
hehehe,
Downshift using the paddle shifters in Sport or Manual mode. The car simply rev matches much more aggressively - hence the throttle blip.
Old Sep 4, 2014 | 03:30 PM
chrisridebike8's Avatar
'10 C63
Sport will downshift more aggressively based on your braking. Brake hard from high speed like you are going into a corner and it will drop down gears as you slow.
Old Sep 4, 2014 | 03:32 PM
Autosport7's Avatar
C63 AMG
As Kriston mentioned, the downshifting must be handled manually (paddles) to take advantage of the "blip".
Old Sep 4, 2014 | 04:04 PM
12 C63 Coupe
Aww got it! Thanks guys! Another question is there a certain mileage or anything of when the ECU will fully adapt and take full advantage of the tune?
Old Sep 4, 2014 | 04:52 PM
H20 MRV's Avatar
C63 - Golf Tdi
Not in the UK, the car will " Blip " on downshift in S+
Old Sep 4, 2014 | 06:23 PM
'10 C63
Nope, the car will go from wow to WOW immediately after the tune. No need to let it adapt or anything. No going from race gas back to pump gas, you need to take it easy and let it adapt...
Old Sep 4, 2014 | 07:14 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
For V5 users with FL cars - does the enhanced blip only happen in M and S+ . . . ie no blip in S or C?
Old Sep 5, 2014 | 06:11 AM
jcfay's Avatar
2018 AMG E63s
In my experience, only M (unless as mentioned above you manually, paddle downshift in S+). And also only 4th gear and lower, IIRC. I drive mostly in S+ and I still get it every once in a while, if I'm driving more aggressively, and maybe it's on more aggressive braking, not sure. Regardless, it sure is fun...
Old Sep 5, 2014 | 10:15 AM
Merc63's Avatar
C63 AMG
I wish they could remove throttle blipping. I dislike it, so loud with headers.
Old Sep 5, 2014 | 10:58 AM
pjdizzle94's Avatar
2011 bmw 335i, 2014 c63
scary loud with headers. i throw it in comfort mode whenever i see police
Old Sep 5, 2014 | 12:16 PM
alexmtl's Avatar
2013 C63 coupe P31
I'm sure you can tune it back to v4, since afaik v5 is a v4+transmission update.
Old Sep 5, 2014 | 08:59 PM
D7reU's Avatar
C63
Can the pre-facelift C63 get the V5 map?
Old Sep 5, 2014 | 09:07 PM
12 C63 Coupe
i have a pre-facelift C63... anywho so i tested out the throttle blipping feature today and it's amazing!
