[PICS] How close can the rim be to the caliper?
Need some advice.
I am looking at a set of rims.
FRONT: 8.5 x 19, 40 Offset
REAR: 9.5 x 19, 48 Offset.
The rears arent a concern. They fit perfectly with 275 rubber.
The front also sit great.
But the spokes of the rims are VERY close to the caliper.
Like 1mm away. VERY VERY close.
I have seen cars rims that are close to the caliper, but not sure if this close.
Can anyone confirm if it is OK to run this? Or is this just way too close?
See pics.
Thanks for your help!
8.5" Wide with 3mm spacer will bring ET down to +37
9.5" wide with 3mm spacer will bring ET down to +45
Will be a great looking fitment.
But the spacers being so thin, wont be hub centric.
Will this be an issue with vibrations? I have had spacers on the ML63 (15mm spacers) but they were hub centric. Never had 1 vibration. Though, with non-hubcentric i dont have any experience with.
Can anyone comment?
Once the rim is fixed on it doesn't move in that way and shouldn't move in anyway to hit the caliper.
So measure up and spin the wheel, if it doesn't rub the caliper at all then you're all good
PS: Stick with hubcentric spacers.
Rims look off their head. I'm thinking of getting a set for mine!
If you have the wheel moving on the hub so that it hits the caliper then you have another issue which would likely lead to tears. Once the wheel is on the hub it isn't moving or wabbling.
I've had some pretty tight fitting wheels before. I'll admit, my bootyhole was a little puckered at first and I kept imaging a scene straight out of a movie where the wheel hit the caliper and I started to cartwheel down the road. Still here though.
I went ahead and got the rims
I will be putting 3mm hub centric spacer on there to push the fronts out JUST that little bit for piece of mind.
but for now i have just fitted them as is.
I have started a new thread with pics.
Thanks again everyone!!!
Yep, i will be getting 3mm spacers just to be on the safe side.
The rims are on the car now, and are working fine. But god damn its close! hahaha.
Yes, they are similar design to the 18" C63 Update rim. But these wheels are more of a knockoff of the W221 S65 / CL65 rim which comes in 20"
These are 19's tho.
Thanks for the compliments guys.
personally I think it's a really bad idea to use a small spacer and eliminating the hub centric mounting... I think that will cause more problems than leaving them as-is... the wheel bolts are spec'd to and rely on hub centric mounting. spacing them just beyond the hub will cause excess stress to the wheel mounting bolts. torque will need to be increased for bolt centric mounting, torque required can be substantially more than with hub centric and wheel bolts are really not intended to be bolt centric. all bolt centric wheel mounting will use larger diameter studs, not M12 bolts... you will probably have to torque them beyond the safe limits of the bolt to secure them properly or you'll get movement that again will increase the stress on the bolts, either scenario is not ideal...
bottom line is I think it would be much safer as-is VS using small non hub centric spacers... you def have enough clearance there with a fixed mount caliper
