C63 AMG (W204) 2008 - 2015
Become a Street Assassin, Murder the corners with KW's, H&R, or Fortune Auto
Old Sep 23, 2014 | 01:23 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Springs not doing it for you? Want to attack the corners? We're here to help. Vivid Racing now offering you at member pricing a variety of coilover setups to aid you in your quest to conquer the street or track like a boss.
You got an awesome car now give it an awesome ride without sacrificing quality.
MB World Members Get Additional Discounts!!!
Call or PM me for Member Pricing and Details.
Jacky
480.966.3040 x229
H&R Street Performance Coilover (RWD and Sedan Only)
MSRP $1650
H&R Street Performance Coil Overs are the perfect suspension solution for discerning drivers from daily drivers to serious tuners who can appreciate the awesome handling and superb ride comfort. Each coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system. The fully threaded shock body allows for adjustable vehicle height. This feature helps balance vehicle weight, resulting in a lower center of gravity and improved performance and control.
Approximate Front Lowering: 1.2 - 2.3 in.
Approximate Rear Lowering: 1.0 - 2.2 in.
Fine tune lowering to what you want.
Fortune Auto Generation 5 500 Series Coilovers (Custom Order 4-6 Weeks)
MSRP $1200
Can be Upgraded with swift springs, radial bearings mounts, and rear adjustment extenders.
Best bang for the buck coilovers.
KW Variant 3 V3 Coilover (Specify Sedan or Coupe)
MSRP $3100
For the True Enthusiast
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
with adjustable compression and rebound damping
TÜV approved
Front lowering adjustment ranges (min.-max.): 5-30 mm (0.2-1.2 inches)
Rear lowering adjustment ranges (min-max): 0-30 mm (0.0-1.2 inches)
Front Spring Rate: Progressive
Rear Spring Rate: Progressive
Jacky
480.966.3040 x229
Old Sep 23, 2014 | 01:42 PM
itzjonjon69's Avatar
12 C63 Coupe
How much for a set of the Fortune Auto/Muller coilovers?
Old Sep 23, 2014 | 01:54 PM
PM'ed
Old Oct 1, 2014 | 07:14 PM
Come get it.
Old Oct 2, 2014 | 07:43 PM
Kriston's Avatar
C63 AMG
Lol this thread title cracks me up.
Old Oct 3, 2014 | 09:03 PM
Yes, Kriston. You too can become a street assassin.
Old Oct 6, 2014 | 08:09 PM
Heaven forgives all who use these coilovers in it's name.
Old Oct 7, 2014 | 08:39 PM
Bump
Old Oct 7, 2014 | 09:59 PM
Worth the wait's Avatar
2006 E55
Vivid is slipping if it has come to using terms like "street ASSASSin"
One thread, three asses(included Jacky)
Old Oct 8, 2014 | 12:12 AM
I just don't like making boring posts with technical specs and the usual bull. Get used to seeing more and more. Flame all you want because my inbox is full of inquiries.
Old Oct 9, 2014 | 11:08 PM
bump
Old Oct 20, 2014 | 08:17 PM
Adjustable
Old Oct 24, 2014 | 08:32 PM
bimp
Old Oct 31, 2014 | 08:10 PM
Bamp
