C63 AMG (W204) 2008 - 2015
Curbed
Old Oct 8, 2014 | 11:49 PM
dailo's Avatar
W463 G63, W213 E63S, W204 C63
Curbed
Hi Guys
Wanted to get some advice from you all.
Long story short, friend hit a curb with some speed, caused the front alignment to be off. All parts replaced, steering, control arms, tie rods etc..
The top mount of the suspension seems to have moved as in then attached pics.
I have KWs, and wondering if this is just a simple adjustment or this is a much larger issue before I head back to the dealer next week. I would like to get your opinion if the suspension is just loose and can be moved around, or the actual mounting holes have been damaged.
Cheers!
Old Oct 9, 2014 | 12:36 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
This does not look good. Did the dealer do the front end work?
Old Oct 9, 2014 | 04:50 AM
dailo's Avatar
Yup they did!
Old Oct 9, 2014 | 06:53 AM
-Marlin-'s Avatar
2011 C63 AW
Those holes look like they became slotted from the impact. I think they are supposed to be round and true.
Old Oct 9, 2014 | 06:58 AM
bhamg's Avatar
C63 AMG
That looks ugly. I would take it to a body shop that really knows their stuff. Been there, done that in a similar situation. The body shop caught the bent stuff that the dealer missed.
Old Oct 9, 2014 | 04:30 PM
bhamg's Avatar
C63 AMG
It doesn't look as bad as I thought - when I first looked at the photo late last night there appeared to more upward twisting to the three heads - now I can't really tell. Are they flat on the tower? They look both displaced and slightly bent to me.
Old Oct 9, 2014 | 04:48 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Agreed,
If something goes wrong, the dealership will always blame the aftermarket parts. If you can, take it to a trusted body or a performance shop for a second opinion.
Old Oct 9, 2014 | 04:49 PM
Ingenieur's Avatar
C63 AMG
Did the dealer align the car after the repairs?
Doesn't look real bad but the strut should be removed and inspected and the mounting points should br measured to make sure things are square/plumb
Old Oct 11, 2014 | 10:29 PM
dailo's Avatar
Yes the dealer aligned the car although they couldn't do an alignment with my wheels, 20" and their equipment doesn't fit. So they put the stock wheels on.
I also changed the KW shock.
Hoping its a simple problem but the wheel at the top looks further under the bumper with increased camber compared to the left side.
