09 c63 serpentine belt diagram
EDIT: The other option is this routing BUT less wrap around the water pump pulley.
You should start with unplugging the speed assist.
Already know what that feels like so if the system stays that's what I will do.
Ive done the same thing as i race mine too, twice it has shredded the belt, first time ripping trans pipe from cooler and water hose to tank.... a bit messy. Any input would be great before i start hashing things. Also thinking about remote mounting power steer reservoir to lessen the heat.
cheers
https://www.rockauto.com/en/moreinfo...=3822177&jsn=1
cheers
EDIT: The "green" spot is where the AC compressor was.
