C63 To lower or not to lower?
Springs and shocks need to be matched otherwise the ride is bad and sometimes even dangerous.
Based on my experience, I wouldn't do it. But a good set of coilovers. Or leave it stock.
Look wise, I'm not an expert in low rides, can't comment on that.
Unless you either plan to only use your car on billiard table smooth race tracks, or else you know a good chiropractor and/or only plan on owning the car until just before it falls apart, I would not recommend lowering it.
H&R springs with oem shocks for 3 years no problem. Handles great, no rubbing with my HRE/ 275-30-19 PSS & more comfy than OEM springs.
I would suggest to lower it since your wheels make ur car looks higher... but again, you might rub looking at your rear wheels offset.
Really I think it sits nice as is, if the roads are bad i wouldnt lower at least not with springs maybe adjustable suspension to get a good balance of height and driveability
Forget about spacers, it will bring ur offset even lower. And in ur case, don't lower it.
And having the wrong offset wheels or wrong size tires are limiting u in any lowering options, so I doubt coilovers will help ur case.
It's really unfortunate cuz those wheels (or any aftermarket wheels) will never do ur car justice w/o the right drop, that's just my opinion though.
If the inner side of the tire is rubbing, by rolling the fenders and running some spacers he can avoid this.
Having said that, if you are looking like you will rub on the outer side of the tire already, with the minimal gain you get from rolling these fenders, you still will not be able to run spacers. I only say this because after looking into rolling the fenders on this car myself, I quickly noticed how little space can be gained as the lip is already very narrow.
Now, if you want to get into pulling the fender, meaning rolling them beyond just the inside lip, then you are talking about gaining some more space, but you will ultimately take the chances of cracking paint (probably not, if rolled properly, but still a chance), and deforming the outer edge of that fender. I don't recommend this.
Your wheels look great on your car, but unfortunately do not leave you with many options at stock ride height, let alone following a drop.
Running negative camber really isn't going to help your cause here either, a narrower tire may help out some.
I hope it is not from a vendor here because that would be poor service.
20" wheels on a C63 IMO is too much but do-able. You just have to have the right specs.
In this case, OP did realized this will eliminate one problem but cause another. Lol
20's on our cars can be tricky.
OP, I'm glad u don't rub the inner part anymore. If u can live with the wheel gap, then all is well.. Or else sell the wheels & get the right offset so u can have the perfect stance.
