C63 AMG (W204) 2008 - 2015
High idle cold start with Eurocharge V5
Old Nov 1, 2014 | 06:21 PM
derspi's Avatar
2009 C63
Anyone else experience this after switching to the V5 tune from Eurocharge? Been running their V3 and V4 tunes before with no issues but as soon as I flashed to the V5 tune about a month and a half ago, my cold start has been abnormally high (about 1,600 RPM compared to 1,100 RPM stock). I ran the V5 tune for a couple of weeks hoping maybe the ECU will adapt or sort itself out but no dice. Flashed back to V4 tune and voila, the cold start idle goes back to normal at 1,100 RPM.
I've emailed EC but it's been over a week and haven't heard back so I'm hoping perhaps other forum members have had this happen as well and came to a solution.
Old Nov 1, 2014 | 06:29 PM
ToXicXxX's Avatar
2011 C63 AMG P31
By cold, do you mean winter cold? Because my 63 will idle quite high when it's freezing out. But in my heated garage 1000RPM is normal.
Old Nov 1, 2014 | 07:02 PM
rentzington's Avatar
2010 C63 P30
mine idles high for maybe 30seconds or until i put the car in gear or hit the brake on cold start, then its normal after that
Old Nov 1, 2014 | 07:54 PM
PanzerLehr's Avatar
2014 C63
Pretty normal for mine, it settles down after a few seconds? No big deal for me, I have a Jetta that goes to 2500 on cold start, sounds like someone is giving it gas but seconds later it is at normal idle.
Old Nov 1, 2014 | 08:59 PM
derspi's Avatar
2009 C63
No, by cold start, I mean when the ECU decides to elevate the RPM to 1,000 - 1,100 to warm up the catalytic convertor faster. For me, this usually occurs at the first start of the day as I park in a heated garage at home and at work. Ever since flashing to the V5 tune though, the cold start is at 1,600 RPM which is awfully strange and sounds just weird.
Old Nov 1, 2014 | 10:47 PM
AMG893's Avatar
2010 C63 Estate
If switching from V4 to V5, and then back to V4 and it eliminates your problems, there is obviously something up with V5 Tune on your car.
While i dont have V5 tune, i think the OP is looking for guys who have the V5 tune to comment on if after loading the V5 does this happen to them.
I know exactly what you mean though. 1600 is abnormally high for our cars.
Mine is about 1100rpm on first start of the day.
Old Nov 2, 2014 | 08:51 AM
2010 C63 P30
Ill check mine on start today and see the actual rpm but ive got the v5 tune and it is usually a lil high for a bit until its in gear or brake pressed
Old Nov 2, 2014 | 11:34 AM
Mort's Avatar
I also start mine in cool but not cold conditions ~ 60 - 70*F (16-19*C) and the idle raises to ~1100 rpm as you said. I am running V5.
Old Nov 2, 2014 | 12:16 PM
chrisridebike8's Avatar
'10 C63
Running the v5. Oil temp was 71 degrees. The revs shot up like normal and then settled to 1100 for maybe 15 seconds and then back down to normal idle.
Old Nov 2, 2014 | 01:28 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
I don't have high rpms with my V5. It was freezing outside this morning, but my engine was still in the 60ies when I started. I don't think I even have seen 1100 rpm yet.
Old Nov 2, 2014 | 01:51 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
V5 here and no difference from V4 or V3 for cold start idle.
Old Nov 2, 2014 | 02:17 PM
sinape62's Avatar
Veteran: Air Force
2013 C63 Coupe
I have the V5 tune, upgraded from V4 about 6 months ago. Did a cold start today outside air temperature was 67F degrees, initial idle was 1100 rpm, then settled down to 700 rpm after a few minutes. I have ROW boxes and Hi-flow Airfilters for Weistec.
Old Nov 2, 2014 | 03:14 PM
2010 C63 P30
Nope looks like the same as the rest, bout 1100 for a few seconds then under 1000
Old Nov 2, 2014 | 11:49 PM
Carreracat257's Avatar
2009 c 63 amg eurocharged
I checked mine today . 1,100 rpm until the engine oil hit 82 then it went back down. I did notice with my old tune it was more raspy now just idles high then goes back to normal
Old Nov 3, 2014 | 02:03 AM
derspi's Avatar
2009 C63
Thanks for the replies with your experiences. Looks like I got a "faulty" file. Hopefully Eurocharge will reply with a solution for me soon.
Old Nov 4, 2014 | 08:01 PM
AMG Boost's Avatar
2010 C63 P30
I highly doubt you got a "faulty" file. This sounds perfectly normal. I dont have experience with other tunes however.
I have Eurocharged V5 also and I do believe it idles up to 1600 for a few seconds on cold starts of less than 5c temperature. I will double check tomorrow.
Old Nov 4, 2014 | 11:49 PM
derspi's Avatar
2009 C63
Well, not faulty but something ain't right with my V5 file if under all the SAME conditions, the cold start idle is at 1,600 rpm and only 1,100 when flashed to stock or any of the previous files from EC. In terms of drivability and the more aggressive downshifts in M mode, the V5 file delivers as promised with no issues. But, by all accounts, a 1,600 rpm cold start idle just isn't the norm.
Please let me know what you find tomorrow, thanks.
Old Nov 6, 2014 | 10:31 PM
menteleum's Avatar
2009 c63
Mine idles high too on cold start. My C63 used to sound like godzilla waking up from a nap before Eurocharged tune. Now it sounds like a regular old iguana.
I am sure they purposefully just put the idle set-point higher. The reason for it I don't know. If they tell you that they will reflash for free with a lower cold-start idle set-point I'd like to get it done too. I miss it, but my neighbors probably don't.
