C63 AMG (W204) 2008 - 2015
Facelift Door Mirrors
Old Nov 5, 2014 | 10:16 AM
Henrychung828's Avatar
C63 AMG
My car is 08 pre-facelift C63 and can anyone tell if I replace the door mirrors to facelift one (arrow LED), will it be any code throw out or any light on the dash? Or does it require coding?
Thank you
My C63 photo:
Old Nov 5, 2014 | 10:54 AM
cptdaz's Avatar
home the point
Nope, no coding issues. The foam padding underneath will need to be taken out because post FL mirror assembly don't fit but other than that, no other issue.
Now if you want folding, then you'll need to reflash to 2010+ firmware (as well as a folding enabled door control panel.
I think there's a DIY somewhere here that show you step by step installation.
Old Nov 5, 2014 | 11:12 AM
C63 AMG
Refresh the firmware means the ECU? Any reference ?
Old Nov 5, 2014 | 11:33 AM
cptdaz's Avatar
home the point
I meant your COMAND system not ECU. You can find more info here:
https://mbworld.org/forums/c63-amg-w...erational.html
Old Nov 5, 2014 | 11:35 AM
JeffDL's Avatar
C63
the plugs are different as well. I had to re-wire mine. they actually were not the plugs were cut off. (just remembered)
Old Nov 5, 2014 | 11:36 AM
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
Whoa whoa whoa. You're telling my that my 2010 has power folding mirrors already and all i need is the stupid button to use them. Where do I get this button and can I do the COMAND **** myself?
Old Nov 5, 2014 | 12:01 PM
cptdaz's Avatar
home the point
I didn't. Neither did this guy:
https://mbworld.org/forums/c63-amg-w...up-inside.html
Old Nov 5, 2014 | 12:11 PM
JeffDL's Avatar
C63
that would have made life easier. i think mine were euro spec? the mirrors were both like the passenger side where things are closer than they appear with the outer half being like a wide view mirror? oh no the person I bought them from cut the connector off for some reason. that's why it was such a PITA. sorry for the misleading info it was a long time ago.
Old Nov 5, 2014 | 05:01 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Lol they were probably stolen
By the way OP I have a pair for sale if you are interested.
https://mbworld.org/forums/c63-amg-w...-part-out.html
Old Nov 5, 2014 | 06:31 PM
JeffDL's Avatar
C63
i thought that too.
Old Nov 5, 2014 | 08:04 PM
C63 AMG
Originally Posted by cptdaz
I meant your COMAND system not ECU. You can find more info here: https://mbworld.org/forums/c63-amg-w...erational.html
My current one do have the power folding as well as auto-dimming, the coding / firmware upgrade is still require?
Old Nov 5, 2014 | 08:08 PM
abcut973's Avatar
They should be plug and play assuming you have facelift mirrors that are power folding and autodimming.
Old Nov 5, 2014 | 08:15 PM
C63 AMG
Great, Thank you very much....
Old Nov 5, 2014 | 08:20 PM
cptdaz's Avatar
home the point
Nope, you'd be gtg. Even if the mirrors aren't auto folding or auto dimming, it should still be plug and play, though obviously you won't have those functions.
