Data cable too short - remedies?
The OEM MBZ cable for use with my iPhone 5 is so short I have to basically leave the phone in the center console. I have not located an Apple extension cable that is female on one end and male on the other. What workaround have you fine folks figured out?
I don't have the center console connection, but are you in need of a usb to lightning cable? If so, I've seen ones up to 3 meters at the Apple Store.
No. I need a female lightning on one end (to connect to the too-short MBZ cable) and a male lightning on the other (to connect to my iPhone).
I see. Well, maybe you can somehow remove the too short one and replace it completely with a longer one? Depends on how the too short one connects to the interface, of course. If it's just a short cable plugged into it, then maybe this will work. Or search for a female to female adapter that you can plug another cable into. Or try a wireless Bluetooth adapter of some sort (but then you won't have charging capabilities).
Received 2,071 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Jive cable lightning cable extension... $15 on amazon .. It works great
Sometimes these aftermarket things don't work. All of my aftermarket cables that I used to use with my 5 stopped working with the 5s and also the 6. Fyi.
Believe me I know. I've run through the Chinese stuff in mass quantity and it all breaks within 2 weeks, if it goes that long.
