C63 AMG (W204) 2008 - 2015
measuring brake rotor thickness with caliper
Old Jan 10, 2015 | 01:49 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
if i use a vernier caliper such as this one:
http://www.ebay.com/itm/Electronic-Digital-LCD-Steel-Vernier-Caliper-Gauge-Micrometer-Tool-150mm-15cm-6-/400616652836?pt=LH_DefaultDomain_0&hash=item5d469d0024
... to measure thickness, how does it clear the outer lip that forms on the rotor? is this the wrong type of caliper? i would think the measuring surfaces would need to be bowed out a bit so that it can clear the outer ridge lip and then come back to center to measure the rotor surface (which is thinner than the outer lip).
Old Jan 10, 2015 | 02:54 AM
Nvm, I found what I need.
Old Jan 10, 2015 | 08:59 AM
jcfay's Avatar
2018 AMG E63s
Yeah, you can just use a spacer as well of uniform thickness to clear the outer edge
Old Jan 10, 2015 | 09:11 AM
Quadcammer's Avatar
96 and 08 911 turbos
micrometer is better for that task.
Old Jan 10, 2015 | 09:20 AM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
C-mics are normally used
Old Jan 10, 2015 | 12:41 PM
Thanks guys. I found a micrometer online.
Old Jan 10, 2015 | 02:32 PM
Merc63's Avatar
C63 AMG
Caliper works fine. Just add a couple quarters to each side of the rotor so the caliper clears the lip. Then measure the quarters used and subtract from the measurement of the rotor with quarters.
