C63 AMG (W204) 2008 - 2015
MB Oil Spec 229.5
Old Sep 25, 2016 | 04:31 AM
  #76
velic63finland's Avatar
C 63 AMG 2009
I Use
http://www.opieoils.co.uk/p-1002-red-line-high-performance-synthetic-motor-oil-5w-40.aspx
and 6000-8000km and newer burning oil. Used about 50k km. Very good oil.
Old Mar 14, 2021 | 01:02 AM
  #77
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
$10 a gallon, beat it!
Old Mar 14, 2021 | 08:35 AM
  #78
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
What is the challenge, find the cheapest oil you should not use in your car?
Old Mar 14, 2021 | 10:50 AM
  #79
deadlyvt's Avatar
2010 C63 AMG
haha this
Old Mar 14, 2021 | 11:01 AM
  #80
Originally Posted by skratch77
what do you guys think of liqui moly high tech 5w40? sorry if it's been discussed
No turbo? Your engine can run on ANY oil in the store. Dino oil? Just use the "STANDARD OIL" option when resetting the OC indicator. 0w-20? No problem in Arctic cold. 20w-50? Perfect for Texas summer or Saudi Arabia.
People loosing their minds over 229 spec oils, they are no different than other manufactures specs.
https://online.lubrizol.com/relperftool/pc.html
Show me an oil that I cannot use in my V6
Old Mar 14, 2021 | 11:06 AM
  #81
lol, do you know a lot about CK-4 oil specs? I didn't think so. Do you have any data other than your keyboard guesswork? I didn't think so. Do you even have a technical background? No,
https://online.lubrizol.com/relperftool/hd.html
This is the kind of idiocy we find surrounding technical discussions, opinions but no data.
If you want to teach me a lesson, send me a bunch of Mobil Delvac 10w-30 and I'll use it in my poor engine.
https://www.mobil.com/en/lubricants/...-super-15w-40/
Mobil Delvac 1300 Super 15W-40 diesel engine oil is recommended by ExxonMobil for use in:
  • The latest heavy-duty diesel engines, including those equipped with aftertreatment systems and EGR
  • Diesel applications using older and naturally aspirated conventional designs
  • On-highway heavy-duty trucking and off-highway applications including trucking, mining, construction, agriculture and marine
  • On-highway applications operating in both high speed/high load and short haul pick-up/delivery service
  • Off-highway applications operating in severe low speed/heavy load conditions using up to 500 ppm sulfur fuels
  • High-performance gasoline engines requiring API SN and mixed fleet operations
  • Diesel-powered equipment from American, European and Japanese OEMs
But you're the expert since your little sister lets you change her oil.
Specifications and Approvals
This product has the following approvals:
10W-30
15W-40
DEUTZ DQC II-10 LA
X
X
Detroit Fluids Specification 93K218
X
X
Detroit Detroit Fluids Specification 93K222
X
X
Mack EO-O Premium Plus
X
X
MACK EOS-4.5
X
X
MAN M 3575
X
X
MB 228.31
X
RENAULT TRUCKS RLD-3
X
X
VOLVO VDS-4
X
X
VOLVO VDS-4.5
X
X
This product meets or exceeds the requirements of:
10W-30
15W-40
API CH-4
X
X
API CI-4
X
X
API CI-4 PLUS
X
X
API CJ-4
X
X
API CK-4
X
X
API SN
X
X
JASO DH-2-17
X
X
ACEA E7
X
X
ACEA E9
X
X
CATERPILLAR ECF-3
X
X
Cummins CES 20086
X
X
ISUZU DEO (w/ DPD Equipped Vehicles)
X
X
MAN M 3275-1
X
Properties and Specifications
Property
10W-30
15W-40
Grade
SAE 10W-30
SAE 15W-40
Ash, Sulfated, mass%, ASTM D874
0.9
0.9
Density @ 15 C, g/ml, ASTM D1298
0.867
0.8751
Flash Point, Cleveland Open Cup, °C, ASTM D92
218
225
Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D4683
3.6
4
Kinematic Viscosity @ 100 C, mm2/s, ASTM D445
12
14
Kinematic Viscosity @ 40 C, mm2/s, ASTM D445
82
109
Pour Point, °C, ASTM D97
-39
-33
Total Base Number, mgKOH/g, ASTM D2896
9.6
9.4
Old Mar 14, 2021 | 11:19 AM
  #82
502? lol, no.
502 is the weakest spec in the business, an RS4 owner should know that.
Old Mar 14, 2021 | 06:39 PM
  #83
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Hey Audi guy. Go away. Stop spamming.
Old Mar 14, 2021 | 07:49 PM
  #84
Gazwould's Avatar
S204 C250 CDI Sport
VW 502.00 505.00 is old hence it's poor oil performance profile .
And yes you'll get Audi drivers with RS4 etc using it because their frozen in time handbooks says to use it !
Oil technology moves on...
I use a VW spec in a Merc , sometimes an oil can carry both specs .
VW
Old Mar 15, 2021 | 01:29 PM
  #85
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by Vladds
Can you provide more details about this? Thanks.
Seems easy enough to follow MB recommendations.
Attached are the specs for the various engines. M156 requires oils made tov 229.5. Also attached current approved oils listing.
Regards,
Joe
File Type: pdf
Old Mar 15, 2021 | 01:31 PM
  #86
Valvestud's Avatar
Originally Posted by BerBer63
What's difference between these two mobil oils and are they both useable for the c63?
The ESP is not on the approved list. I've attached below.
