CEL P0300
As well which cylinder is misfiring? P0300 is the generic code.
You are saying you changed your plugs/ coils and fuel pressure sensor. Could be faulty head gasket
Curious whats required for the detailed info? Star diagnostics?
http://www.toptiergas.com/retailers.html
I usually end up at QuickTrip since theyre typically cheaper, or chevron.
if you're using Mobil it should be fine .surprised they still have Mobil stations there, they all converted to Exxon here
Weird though BP is on that list of top tier.
Coils and spark plugs might have not
Done it right. They rechanged all the spark plugs and everything was fine and after a week, same shaking problem
P2629 - G3/3 (Left O2 sensor, before TWC [KAT]) : Open circuit , never got the code before...may got fouled or damaged from prior misfires. Would check the sensor and see if can be cleaned or may need to be replaced.
and then it was fine after that.
To change my whole exhaust so they wont help me much.
Since its modified they wont warranty anything even with my
Extended warranty
Fuel pres. 74.4
MAF 3.0
Still dont know what to do
