My Kinda Mild Build Thread
#126
Thanks! There's a lil bit of orange peel I hope to sand off. It was a tough pulling the leather guides out of the plastic channels. You need to do that in order to access six screws (3 on each side) and unscrew two nuts holding in the airbag. Otherwise, it was pretty smooth. In all, it took me 2-3 hours to pull the seats apart and get the shells off. I'm nervous about scratching the paint during the assembly. Gonna have to protect it with a couple layers of blue tape and pray!
#128
Front seat backs have been sprayed and clear coated. This took way longer than I thought, but I'm certainly happy with the results!
swilkins56 (10-23-2019)
#130
It was reasonably smooth. The tear down was difficult to pull the leather guides out of the plastic shell channels. Especially hard around the transition from the shoulder to headrest. Other than that, it was carefully unscrewing stuff. The plastic mounting holes were all very brittle. The rebuild was very easy.
QuartzBlueP31 (03-14-2019)
#137
More cleaning! I had ignored my exhaust tips for far too long. Spent two days working to bring them back to par. Various dremel sanding drums, 140, 200, 400, 600 and 1000 grit wet sanding, green scrub pad, 000 and 0000 steel wool along with black, rogue and white buffing compounds were used.
