C63 AMG (W204) 2008 - 2015
AFR Gauge install tips requested - wire harness, mounting ideas, etc
Old 03-24-2015, 06:48 PM
unruin's Avatar
Range Rover Sport, 2012 C63 Coupe P31
That's not very nice.
Old 03-24-2015, 09:43 PM
Merc63's Avatar
C63 AMG
Sounds like u got it all figured out buds. Nope I was curious why u want to monitor AFR. Keep building that top secret rocket, lefty righty yep you got it lol.
Old 04-12-2015, 06:15 PM
LOLLSX's Avatar
2005 MB E55 AMG
Well.... That was interesting. And I'm also installing a WB on mine. I would trust the electronics more if I haven't seen STOCK 55K cars melt down because of leaning out. And I'm one for being able to monitor everything myself. Kinda like the no dip stick thing drives me nuts. But what do I know. MB is a new to me.
Old 04-12-2015, 06:18 PM
BLKROKT's Avatar
Received 2,834 Likes on 1,674 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Installed over the weekend. Still modifying the ashtray to mount the gauge... it's a tight fit.
I agree that it's always nice to monitor AFR if you can. Apparently others choose to just blindly trust that everything is running correctly...
Old 04-13-2015, 04:18 PM
unruin's Avatar
Nice. Lookin forward to pictures.
Do you think you'd be able to fit 2-3 gauges in the ashtray area if you took it out?
Old 04-13-2015, 04:26 PM
BLKROKT's Avatar
Maybe if you take it completely out. 2 for sure. 3 possibly.
I'm keeping the ashtray door etc to keep it looking OE when I'm not using it. Took some work, but Dremeled out the underside of the sliding door and cut out the bottom, and can fit one gauge in there with a CF plate cemented in to keep it in place.
Old 04-14-2015, 01:37 AM
  #32
pNutz's Avatar
2008 Mercedes C63
Seems like every other thread I click on has an argument in it. Lol!!! Stop pmsing and relax guys.
I've been looking for a good place to put some gauges. Looking forward to seeing pictures.
Old 04-14-2015, 02:17 AM
  #33
clichere1's Avatar
W205 C63S E.1
Glad you work it out, can you post some pictures
AFR usually used for custom ECU tuning, to make the perfect air fuel ratio.
OR
you going to turbo charged your engine.
Subscribe.
Old 04-14-2015, 02:22 AM
  #34
clichere1's Avatar
W205 C63S E.1
Old 04-14-2015, 10:49 AM
  #35
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
Subscribed to see how the mounting turns out.
Monitoring with a secondary AFR WB on a closed loop WB platform is redundant though.
Both will have slight discrepancies (as the sensors degrade) so which one do you trust? Your secondary (primary) sensors will either show a false positive or false negative at some point.
What is your game plan if your secondary AFR system shows lean?
What is your game plan if your secondary AFR system shows rich?
Would have been better off tapping into the signal from the OE sensors instead. Just some constructive criticism, so feel free to ignore .
Old 04-16-2015, 02:35 PM
  #36
BLKROKT's Avatar
Installed and working great
Haven't had a chance to do a long WOT pull yet. Got on it a bit this morning and saw 12.7-12.9 but couldn't stay in it long enough to get a solid reading.
AFR Gauge install tips requested - wire harness, mounting ideas, etc-img_2318.jpg
AFR Gauge install tips requested - wire harness, mounting ideas, etc-img_2321_1.jpg
Driver view no problem clear as day to read on the fly
AFR Gauge install tips requested - wire harness, mounting ideas, etc-img_2323.jpg
The ashtray mount took a bit of cutting, both to the tray (gone) as well as to the underside of the door. Also had to cut out a plastic bracket underneath everything for the gauge and wires to fit. All-in-all not so bad, just a lot of test fitting, and looks OE when the door is closed. A little disappointed that the CF sheet doesn't match the internal trim, but I'll correct that over the summer.
Quick Reply: AFR Gauge install tips requested - wire harness, mounting ideas, etc
