C63 AMG (W204) 2008 - 2015
Is redlining OUR C63's bad
Old 04-19-2015, 06:32 PM
JZ_63AMG's Avatar
C63 Amg
Exclamation Is redlining OUR C63's bad
Today I was on the freeway and decided to downshift in S mode into 3rd gear, well in the process of doing all the multitasking i forgot that i was not in shifting mode therefore redlining my car to the point where the car had to shift it self to 4th gear I want to know if i caused any harm to my engine or if redlining our AMGs is bad .... Is clicking noise normal for our cars too?
Old 04-19-2015, 06:36 PM
chrisridebike8's Avatar
'10 C63
The car won't let you harm the engine. Running the car to the redline all the time will cause more wear and tear in the long run. But the car was built to be driven hard. As long as it's properly warmed up first, I wouldn't worry too much. As far as a clicking sound, can you elaborate? It sounds like you might be talking about lifter tick that goes away after the car is warmed up and oil pressure builds.
Old 04-19-2015, 06:44 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
you good bro... when I roll race someone I just hold left paddle n it drops to the lowest gear and floor it. car will shift itself at redline each gear. short shifting loses races !!
Old 04-19-2015, 07:05 PM
rentzington's Avatar
2010 C63 P30
yeah, unless youre in M and just drive around in 1st gear with the needle in red the entire time
red every now and then wont hurt.
Old 04-19-2015, 07:09 PM
JZ_63AMG's Avatar
C63 Amg
I talked to a couple of mechanics asking them what is that little ticking noise and some say lifters and some say fuel injectors but end of conculsion they state its normal but maybe im not use to these naturally aspirated monsters
Old 04-19-2015, 07:15 PM
g-f
g-f's Avatar
996TT
Redlining the engine is not bad at all.
It's built for that.
Old 04-19-2015, 11:24 PM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
Gotta let the car know who's boss
right_mr (09-13-2019)
Old 04-20-2015, 12:27 AM
MaroonC63's Avatar
2009 Barolo red C63 AMG (SOLD).13' P31 c63 coupe 2012 porsche panamera
Lol. Redline it as much as you want in good health bro.
Old 04-20-2015, 08:30 AM
mrbrannin1's Avatar
2007 civic Si 2004 Acura TL 2013 MB C350
I wish you Godspeed and redline onnnnnn my friend!!!!
Old 04-20-2015, 12:36 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Just a small qualifier... bumping off the redline is not a problem for as long as the oil is up to operating teperature. You just don't want to do it when the oil is too thick to properly flow and lubricate (< 90 C / 200 F).
Old 04-20-2015, 06:35 PM
Southways's Avatar
C63 Coupe, 2014, 507
I tried to find a video of some work I did a few years ago on Chevrolet V8s hitting the limiter. If you watched the brutality happens with the timing belt (or in our case, chains); the crankshaft twist; the camshaft(s); the FEAD; & the unbalance introduced... you would avoid touching the limiter unless you really wanted to test the MB warranty.
For the love of driving tomorrow, show some mechanical empathy.
Old 04-20-2015, 08:15 PM
Diabolis's Avatar
That is all true and I completely agree. I think the OPs question was whether he had damaged anything by that single incident, to which the probable answer is no - that is, if you happen to hit the limiter on an upshft once in a blue moon (like every four months). Bouncing off the limiter all the time is certainly not healthy and is indeed going to shorten the engine life by a big margin.
Old 04-20-2015, 08:34 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Rev in moderation.
Old 04-20-2015, 08:43 PM
2010 C63 P30
Yeah, I don't see a need to go around hitting red all the time.
I only get close when I hold down the left paddle to force a downshift and that never goes redline.
If I was to drag race I'd probably do it though
Old 04-20-2015, 09:09 PM
solekeeper's Avatar
A V8
woops just redlined while typing this post.
Old 04-23-2015, 03:51 PM
bob2011's Avatar
2011 E550
I used to redline my E550 once a month for fun, after reading this thread I'm terrified to redline.
Old 04-23-2015, 04:00 PM
unagi1's Avatar
y? we have soft and hard limiters for a reason Not saying redline every gear out but these safety mechanisms are there regardless
Old 04-23-2015, 11:15 PM
MTV10's Avatar
E55 AMG & C63 AMG
I redline my car every.single.day.
Keep up on the lube and drive her hard every day. That's how your engine will last.
Old 04-23-2015, 11:40 PM
unagi1's Avatar
and if u run out of lube?
Old 04-24-2015, 12:32 AM
OC6.3AMG's Avatar
W205 C43, C204 C63, & Honda Fit
LOL - Love it.
@OP, no you're fine.
Old 04-24-2015, 12:39 AM
Diabolis's Avatar
The safety mechanisms are there so that your pistons don't become intimately acquainted with your valves or the conrods don't snap and punch holes through the side of your block. It certainly doesn't mean that just because the ECU won't let you destroy the engine by pressing the accelerator pedal too far, revving it near redline is without consequences when it comes to longevity and wear and tear. You are still beating the crap out of the motor.
Old 04-24-2015, 12:53 AM
solekeeper's Avatar
A V8
i definitely think redlining an e550 is not a good idea.
and besides that, who drives an e550 that hard?
Old 04-24-2015, 02:29 AM
Diabolis's Avatar
Er... not.
Old 04-24-2015, 02:09 PM
bob2011's Avatar
2011 E550
Well I don't drive my car hard all the time, just once or twice a month. Plus I can't be the only one who drives their e550 hard, Right?
Old 04-24-2015, 02:58 PM
'10 C63
E550 has more power than the original E55. My dad drives his pretty spiritedly. It might not be an AMG but it's still a pretty good NA V8...
Quick Reply: Is redlining OUR C63's bad
