C63 AMG (W204) 2008 - 2015
w205 amg steering wheel retrofit possible?
Old 09-09-2020, 01:36 PM
  #176
AMG RB's Avatar
The horses are now in the barn, 2019 E63s
I can't image that being required (the plate) or that you'd have an issue with the wheel you just bought especially if they are identical in base MB function. Now if you're trying to add the AMG Drive Unit that's a separate matter all together but no less achievable.
Old 09-09-2020, 01:50 PM
  #177
Swagg3r's Avatar
2017 AMG GT
AMG RB, I suspect that Chris the Swede is the owner of CKM designs whom I purchased the wheel through and he mentioned having to switch the ECU plate. If he could add his thoughts I would appreciate it. For right now, mine is still for sale.
Old 09-09-2020, 01:53 PM
  #178
AMG RB's Avatar
Right on Swagg3r are you familiar with Ask Carbon? They also offer steering wheels and there's several threads related to this topic in other AMG model forums.
Old 09-09-2020, 02:07 PM
  #179
Swagg3r's Avatar
2017 AMG GT
AMG RB Let me ask your thoughts. The new car is Solarbeam Yellow. I want yellow stitching on the wheel. I have seen YouTube videos where people were able to use fabric dye markers to change the color of their stitching without harming the leather. For me to do that on my current wheel I would need to first bleach the current threads white then dye them yellow. Only thing I can think of is to use a Q tip dipped in Clorox bleach on the threads. Do you think it would bleach out the black leather if I immediately wiped it off the leather?
Old 09-09-2020, 02:30 PM
  #180
AMG RB's Avatar
I don't want to get too far afield of this thread topic but lemme ask you this. Do you like the AMG Drive Unit controls? What amount of money gives you peace of mind for insurance if the DIY goes bad?
Personally, I want the AMG Drive Unit and the style of the current steering wheel in AMG GT's so that drives my decisionmaking.
Old 09-09-2020, 05:31 PM
  #181
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
If you set on changing your steering wheel then this may help.
Old 09-10-2020, 02:38 AM
  #182
Chris The Swede's Avatar
W222 S63L, ML/GLE350
What wheel you have now and for what car did you buy it?
Old 09-10-2020, 04:42 PM
  #183
AMG RB's Avatar
Swagg3r this steering wheel link is provided for reference. I've not purchased anything from this site but it's worth having for comparison and consideration. When/If I ever decide which AMG I'm gonna get, if it doesn't have this type wheel or the ability to upgrade to it and the AMG Drive Unit controls it won't be for me. I'll probably have two wheels eventually; one all Dinamica and one all leather.
Happy hunting.
Old 09-30-2020, 05:44 PM
  #184
Dragos Niculaie's Avatar
mercedes benz 2010 e 200 cdi
I got a w205 steering wheel with flat bottom and i am trying to put it in my w212. All buttons work but the new airbag has the colored cables in different positions than the old one. Do I need to cut and solder the new one so it s like the old one? Can someone help me? I will attach some pictures also.
New airbag cable
Old airbag cable
Old 10-01-2020, 04:11 AM
  #185
Dont matter. Just plug in.
Dragos Niculaie (10-01-2020)
Old 10-01-2020, 05:40 AM
  #186
Hope it won't blow up.
Old 10-01-2020, 05:45 AM
  #187
Ive done it at least 300 times....
Old 10-01-2020, 06:25 AM
  #188
ok. thank for the info bro, appreciate it!
Old 12-13-2020, 05:46 PM
  #189
2003????
Old 03-23-2021, 02:33 PM
  #190
Can I use an airbag (Flat bottom) from a B 180-200 W246 2015 on a c205 steering wheel (also flat bottom)?
Old 03-24-2021, 06:48 AM
  #191
Only if it is the sport version.
Old 03-24-2021, 03:56 PM
  #192
don't know if it is sport or not... https://www.bruktdel.no/nbf/Bildeler...e/3210-133446/
Old 03-25-2021, 04:41 AM
  #193
As you can see here its not the sport wheel. Send me a PM and I hook you up.
https://www.bruktdel.no/nbf/Bildeler...att/784388409/
Old 06-09-2021, 06:20 AM
  #194
thanx Chris the Swede for the airbag!
It didn't blow up 😅
Old 06-10-2021, 03:19 AM
  #195
It didn't blow up 😅
AWESOME!!
Old 08-09-2021, 08:44 PM
  #196
Hello Mercedes's Avatar
W204 FL C200
Originally Posted by aobr31569
Finally made the W205 wheel fully functional on pre FL W204. Column is from a facelift W204 Coupe, hence the newer design. Control circuit in W205 wheel replaced with circuit from W204 wheel. Buttons swapped out, wheel came with the "Home" buttons, had to get hold of the standard up/down and left/right versions. Not really sure it was worth the extra hassle over the FL W204 wheel, but its done now, and is a marked improvement.
May I know where you bought the steering wheel? Can you give us a link?
bjflex10 (12-06-2021)
Old 12-06-2021, 12:23 PM
  #197
bjflex10's Avatar
Mercedes c250 coupe Amg Edition-125 Custom, Mercedes Glc43 coupe Amg
W204 to w213 e class 2016 steering
I am in the porcess of doing this update will let you know the procedures and how it goes got the whole steering wheel & airbag due relatively cheap
Originally Posted by Kriston;[url=tel:6499608
6499608[/url]]I was told the W205 wheel are a bolt on part for the W204's. if you have a PFL C63 you need the updated steering column from the FL W204's or E Classes.
Cant wait for someone to try it, its a costly endeavour for me to try it. The edition 1 Steering wheel from the W205 C63 are beautiful.
Old 12-06-2021, 12:30 PM
  #198
bjflex10's Avatar
Quick Reply: w205 amg steering wheel retrofit possible?
