C63 AMG (W204) 2008 - 2015
Eurocharge V6 wishlist
Old Oct 14, 2016 | 01:30 PM
  #151
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Is our fuel system even compatible with 100% ethanol? I could be wrong, but don't a lot of cars have to replace or upgrade many of the components in their fuel systems because the seals that are made for gasoline basically get eaten away by ethanol? Like fuel lines, seals, pumps, etc - a lot of these that are fine for gasoline won't be for straight ethanol. Or at least that used to be the case. My buddy in his GTR just went through that I think...
Old Oct 14, 2016 | 01:42 PM
  #152
SuperFastYo's Avatar
C63 AMG - LSD
I highly doubt it. I was using e85 in my 335i and I replaced the lines with braided as e85 kills the fuel lines, and had to upgrade my pump to an e85 one from FUEL IT
Old Oct 14, 2016 | 03:25 PM
  #153
ritalin's Avatar
07 Z06, 2011 c63pp
Based on the picture, this looks to be similar to a meth injection kit in terms of plug and play w injection pre throttle bodies and control via the dme?
Old Oct 14, 2016 | 04:52 PM
  #154
SaphGreyC63's Avatar
2012 C63 AMG Sedan
V6 is a free upgrade for current Eurocharged owners right?
Old Oct 14, 2016 | 04:55 PM
  #155
chrisridebike8's Avatar
'10 C63
They have a reflash fee now, even if you bought when there was the free lifetime reflashes.
Old Oct 14, 2016 | 05:15 PM
  #156
rohitC63's Avatar
C63 AMG
I believe the fee is $30, can someone confirm this?
Old Oct 14, 2016 | 07:20 PM
  #157
DavesMeanE's's Avatar
Former Vendor of MBWorld
93' 500E, 95' Corolla
Great question - and I'm glad it came up
First thing to point out is that while most will be running "E85", an important takeaway is that "E85" is simply a marketing term (meant to indicate 85% Ethanol)... most "E85" is only in truth only between about 51%, and 81%... with the remainder being regular 91/93 octane gasoline. In fact 100% would be hard to ignite on a street car... so unless you are committed to running an E98 or something exotic like "Ignite Red" (which is, you guessed it, 90% + race fuel) you won't be getting close to 100% realistically.
The W204 platform has been equipped with Flex Fuel from the factory (C300's obviously not many in the USA, but very common overseas, i.e. Brazil), this means that having Ethanol safe components would be a necessity. Also, many current vehicles, including the W205 C63s have an Ethanol sensor from the factory in these countries.
A friend literally just sent me this picture yesterday, just to give you an idea of what fuel manufacturers have to say about it.
One thing to note is that special consideration must be made when thinking about the fuel delivery capacity of a given system. Its known that the BMW's that you are talking about are pretty tapped out when it comes to the fuel delivery, and that's why larger injectors, bigger pumps are required. Incompatibility with the fuel isn't an issue. To be honest, the fuel you have in your car RIGHT NOW (except for that one smart alec with race gas) has a MINIMUM of 9% Ethanol in it... in most cases its more, up to 14-15%...
With all that being said, we have personally run Ethanol for years on an E55, and its been in the C63 for months with no issues. It is also in several BMW's, including an M3 which has had the original prototype for two years. (including a stint where it sat in the garage for 4 months with e75 (75%) in the tank. That car still runs perfectly.
It's clear that auto manufacturers have known about Ethanol for a long time, and since fuel has had Ethanol in it since the early 90's, it certainly makes sense that the fuel systems they put in their cars would be compatible with it.
Not to sound like a conspiracy theorist or anything, but there has been A TON of mis-information circulated about Ethanol for years, mostly because of the threat to profits of oil companies... it is not in their best interest to support anything that cuts into them... quite the opposite - it would be opposed heavily. Ill leave it at that
Thanks!
P.S. BLKROKT - I see your car sees some track duty - how would you like to lower your engine and oil temps by about 30 degrees? Ethanol WILL do that for you easily. With combustion temperatures 300+ degrees cooler than gasoline, it puts far less strain on the oil, the cooling system, and the engine as a whole... Just food for thought
Old Oct 14, 2016 | 07:22 PM
  #158
Negative - While it can be considered "plug-n-play" it uses the stock fuel system and injectors, no injectors are added. Good question
Old Oct 14, 2016 | 09:05 PM
  #159
ritalin's Avatar
07 Z06, 2011 c63pp
I see. So, in canada where finding e85 is like coming accross a unicorn, this may not be an option for us in Ontario?
Old Oct 14, 2016 | 09:47 PM
  #160
I see. So, in Canada where finding E85 is like coming across a unicorn, this may not be an option for us in Ontario?
You can always buy it in drums/5gal pails and mix it yourself!
E85 being supplied at fuel stations (or not, as is your case) is usually due to the local demand. If you want to see more E85 become available, get all your buddies together, and talk to a local gas station owner, or start a FB page for it or something. I know it's available in Toronto, we have a kit headed up right now to be installed on a car at the Eurocharged there
Old Oct 14, 2016 | 10:05 PM
  #161
ritalin's Avatar
07 Z06, 2011 c63pp
Really. Im in the gta and as far as i know the closest station is 2 hrs away. I'll look into it.
Old Oct 14, 2016 | 11:04 PM
  #162
'10 C63
Don't most people get worse gas mileage with e85? I don't care about mileage but with the small tank, I'm already filling up every other day. I can't imagine filling up every day. I do like power though...
Old Oct 14, 2016 | 11:22 PM
  #163
Another GREAT question!
We have been compiling data on that subject exactly! The test car is getting about 330-350 miles per tank, and reports getting about 20MPG while driving normally, and down to 12MPG when he is beating it... Fuel cost has to be taken into consideration here, if you are buying 91/93oct - Ill just use myself as an example... E85 costs me $1.79/gallon, 91/93 is at about $2.62/gallon... So for example's sake, lets say I had to make a 1000 mile trip, and driving hard on E85, getting 12MPG, we'll burn about 83.3gallons, 83.3x1.79 = $149.16 in fuel costs for the trip using Ethanol. Now the same trip on 91/93oct - we'll give it the benefit of the doubt and say 20MPG driving hard, which gives us a fuel usage of 50 gallons... 50x2.62= $131, so using this example, you spend about $18.16 more using Ethanol (use your own MPG to calculate for yourself). So in WORST CASE scenario, at $18.16 per 1k miles, and well just say 12K a year, you spend $220 more dollars to have WAY more power, a cleaner, less stressed engine, more fun, plus the SMELL! Burning Ethanol smells great
Thanks for the question
Old Oct 14, 2016 | 11:36 PM
  #164
Phil Chow's Avatar
W204 C63
Too bad E85 not an option for me in HK!
Old Oct 15, 2016 | 12:07 AM
  #165
Great news!
http://www.wikihow.com/Make-Ethanol-Fuel
Easy...lol
Old Oct 15, 2016 | 08:57 PM
  #166
efiftyfizzle's Avatar
W212 E63 AMG S Model
Any options for M157 motors to run E85?
Old Oct 16, 2016 | 11:29 AM
  #167
Not currently, the M157 is a direct injected motor so will require a different system. It's on the Horizon though!
The M157 vehicles have a ton of potential as it is. We offer tune/downpipes/turbos that can massively increase the power.
efiftyfizzle - what do you have done to you car now?
Old Oct 16, 2016 | 04:15 PM
  #168
'10 C63
What about issues with cold start? I know some people have issues with cold starts on e85 in ofher platforms.
Old Oct 16, 2016 | 08:46 PM
  #169
Great question - One of the reasons we have a kit being installed in Canada... doesn't always get cold enough in Texas to prove out such things
I will say that with Ignite Red 90% (other 10% is racing fuel) in the tank of the E55 (and 2 step colder plugs) that car has ZERO cold start problems. Tough to say, as the coldest cold start I have tried in only about 50 degrees... C63 test car has reported no cold start concerns, but the same temps apply since he only about 20 miles away.
Once we get some Canada weather testing in, we'll let you know!
The headers should be on the C63 in the next couple of weeks, so get excited for the numbers coming out of that car.. We will be trying to run it at the track before the weather turns on us as well to get some good fast passes in
Keep coming up with and asking these great questions, we want to be as thorough as we can before it goes full production! Obviously WE are very confident in it, see the results (as do our guinea pigs ). All we can really do is keep piling miles on the cars, getting great dyno/track results to show it off !
Old Oct 17, 2016 | 09:09 AM
  #170
I have just a tune right now, but I don't really see the big gains in upgraded turbos as far as track times. The software really limits these cars.
Old Oct 17, 2016 | 02:34 PM
  #171
vipertoad's Avatar
97 Viper, 14 SRT Jeep
Yes. Yes. Yes.
What will be the cost to go from V5 to V6? And approximate cost of the E85 Flex kit?
Just got V5 from you guys 3 months ago and has made me love the car 10x as much!
Old Oct 17, 2016 | 03:00 PM
  #172
'10 C63
My car has 74k on it. I'd imagine I'd have to replace the fuel filter shortly after starting to run ethanol as I've heard it cleans out any gunk that's estabilished itself and eventually clogs the filter. I heard that's a PIA to replace on the C63. Not sure I want to deal with that.
Old Oct 17, 2016 | 09:41 PM
  #173
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Wow very excited about this flex fuel thing. Never knew so much was to gain on an na car. Now the big question what is the cost estimate for it????? I really hope it's reasonable please. Also when do you think we could see this for sale as a final product??
Old Oct 17, 2016 | 10:22 PM
  #174
AMGonFire's Avatar
Eurocharged this appears to be the flex system you are using correct? Are you rebranding it then? http://www.advancedfueldynamics.com/#
cost looks to be 999 on there site?
Old Oct 17, 2016 | 10:39 PM
  #175
BLKROKT's Avatar
This is why we can't have nice things
Why don't you calm down a little bit and hold off on the detective work Sherlock and let them make the announcement when they're ready?
