C63 AMG (W204) 2008 - 2015
too much water dripping
Old 07-13-2015, 04:16 AM
Paculdo's Avatar
06 CTT-S
just got the car serviced a day ago.. parked the car and noticed water dripping from the front (driver side).. car parked for about 8 hours and water is still dripping.
while this may be water from a/c condensation.. but this seems to be to much water (??)
anything/anywhere else to check?
Old 07-13-2015, 07:56 AM
Quadcammer's Avatar
96 and 08 911 turbos
water from the AC drips from the evaporator drains which are more towards the middle of the car.
That looks like coolant from a leaky radiator.
Old 07-13-2015, 12:31 PM
latreille's Avatar
c63 amg
Windshield fluid washer bottle is there as well.
Old 07-13-2015, 12:39 PM
who8myrice's Avatar
c63
I had my windshield pump go out on me recently and had a pool of liquid coming from the same area of the car as your picture, although mine was on a flat surface.
The windshield fluid pump went out and got it replaced under warranty.
Old 07-13-2015, 01:14 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
What color is the fluid? If bluish and driver's side, it's probably washer bottle related. For me, it was a bad washer pump seal at the bottle.
Old 07-13-2015, 02:13 PM
Paculdo's Avatar
06 CTT-S
can't tell what the color is.. but definitely water(y).. i mean not coolant as it doesnt smell anything (right?)
im worried that it was coolant.. drove the car, monitored water temp and seems steady at 197/200 range (for a 30 min drive at 100F outside temp traffic)
i'll check later if the windshield spray works (or if it has water, etc).. service B includes check/refill this..
Old 07-13-2015, 04:32 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Most likely your windshield washer reservoir. It can develop a leak partway down. It leaks like a pig when refilled. It stops leaking before it gets down to the low-level alarm point. If you are still under warranty, it's usually covered.
https://mbworld.org/forums/c63-amg-w...luid-leak.html
Old 07-13-2015, 05:10 PM
Quadcammer's Avatar
I'm a dope, completely forgot about that.
Old 07-17-2015, 06:02 AM
jl9j's Avatar
2009 C63 AMG
I hadn't driven my car in a while and notice this in the garage. The puddle wasn't as big. I too freaked out thinking it was the coolant. when I wiped the floor with paper towels, it got soapy. so yea, it's the washer fluid.
Posted from Mbworld.org App for Android
Old 07-17-2015, 06:22 PM
papashango's Avatar
This and that.
Most likely the washer fluid. I had this issue with mine but would only happen when I was topping it up. After a certain level it would stop dripping and I wouldn't get any errors saying it's low because it was most likely still not low enough to trigger the warning. Anyway got it fixed under warranty.
Old 07-17-2015, 08:12 PM
jl9j's Avatar
2009 C63 AMG
is there a common issue that can be DIYed or is it pretty much a 'depends on the car' situation?
Old 07-20-2015, 02:28 AM
papashango's Avatar
This and that.
Mine was most definitely not a DIY as I had to take it to Mercedes. I assume they removed the bumper to get to the reservoir to do whatever they had to do.
Quick Reply: too much water dripping
