Negative camber for track cars
kinda late to the thread but i also experienced some issues when i tracked my car last once last year with lack of turn in and understeer. Luckily i have a supercharger to help rotate the back of the car, however we're fighting the laws of physics on this one guys. It's a fullsize sedan not a miata lol.
The "crash bolts" not sure who decided to start calling them this. They are simply adjustment bolts will only get you about 20 minutes of extra camber.... 60 minutes in a degree = 1/3 degree. yah! i can do math.
A stiffer front sway bar is possibly the worst thing you could do - saw that mentioned earlier in the thread.
More camber good idea and should help.
More Toe out in the front end should help as well. typically most benz's are running 20-30 minutes of total toe IN. Track prepped cars are running 10-20 minutes of toe OUT. this will kill your tires much quicker on the street but something to consider if you're that hardcore. tire life reduced to say 3k mi rather than 10k mi for the fronts.
Widest front tire possible or since this isnt all that easy - consider running a smaller one in the back to help rotate the car with more throttle.
stiffen the dampening in the rear to promote oversteer, soften front end dampening to allow for maximum grip and traction
Lower isn't always better. This always depends on each individual setup, just because lower center gravity is better and looks cooler, ruining suspension geometry to get super low can make the car handle way worse than it would with stock ride height.
some of this is common sense but i think most of the focus has been solely on camber in this thread thus far. And for you big time track rats- keep in mind if you drive your car to the track and make alignment adjustments to the camber this directly affects the toe! I've seen and known plenty of people that have marks on there centrics/cam bolts for camber and mark where to set them back to for track and street settings. Thats great and you gained your negative camber temporarily for the track day but you totally screwed up the toe settings for it which may make the change to camber negligible, so unless you really know your **** or like playing with tape measures and strings keep that in mind.
Glad to see people actually tracking these beasts! keep it up!
i dont really think going too big in the front of our car is even possible - short of an awful rocket bunny kit and running 355 width tires lol, but yes that's true if you somehow corrected the understeer issue and needed to bring balance back. Does anyone even make an upgraded sway for our cars yet? Usually all benz run a nasty stiff sway bar so they can go softer on the overall spring rate to achieve a better ride quality with good cornering feel. Heck, i wonder if anyone has tried to slap on a regular c350/300/c250 sway bar and thrown some different higher rate springs in - that could actually be on the money, even without the springs it might work as long as you have the clearance for wheel travel.
Always keep in mind that stiffer isnt necessarily better. The only reason race cars run insane stiffness is because they have insane downforce and it rides like dog **** at low speeds because at high speeds that 1000lbs of extra down force is being applied to the suspension. My lotus taught me this best, that to handle good it doesnt have to be stiff. The softer it is the more mechanical grip the suspension can use when setup properly. Hence why most of these adjustable electric dampener cars actually have faster lap times in comfort mode rathar than sport or sport plus.
Thanks for the input.
I am running KW V3 with K-Mac plates (Thanks Kevin). My alignment settings are -3.5 front and -3 rear with 0 toe all around, I will try pulling less camber out in the rear. No track time yet but the K-Mac plates really help with turn in and you can definitely feel the difference on how the car rotates - less resistance when dealing with the front heavy bias.
Great to see the front adjustable strut tops have allowed you to achieve the 3.5 degrees Negative Camber!
Do point out that the K-MAC front bushes (replacing the 4 major highest wearing bushes) will allow to increase this to 4.5 degrees plus 30mm increase in track width!
The design also does away with the OEM oil and air voids yet still with 2 axis movement. Result is noticeably improved brake and steering response.
Method is to record both Street and Track (from Toe settings). The 4.5 degree Camber setting can then be easily adjusted from engine bay on track days. Dramatically reducing understeer in the quest to hit those corner apexes every time and allowing to go deeper into the corners with increased traction and braking response - to further lower those lap times!
REDUCING THE EXCESS NEGATIVE CAMBER ON THE REAR:
Unlike upper rear Camber arms that need to move top of tire outwards and are difficult to access – we have designed the K-MAC adjusters to move lower arm inwards and easy access – single wrench. With the aid of tire heat probe at track side can quickly fine adjust settings for maximum traction.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
I ran 255/35-19 MPSC2 fronts on custom offset 9" wide wheels at Mosport for a good three hours (four tanks of gas) with no issues, and on the street for about a month before switching to the winters (put the winters on a tad early as the MPSC2s were shot and on the street worse to drive in colder temperatures than the MPSS). I have a Canadian 2013 APX Coupe, which in additon to the USA P31 + LSD package also retains the track-tuned, 10mm lower & stiffer suspension from the old USA P30 package. The alignment is OEM. Will be running 255/35 F & 275/30 R MPS4S this summer.
I can tell you the whole story about the wheels and try to calculate an approximate offset, but it would be still be approximation because I don't know what the starting offsets were when they were 8.5" wide. I can made an educated guess, but it's still going to be a guess.
#32
C63 507 with BS Body; 2008 SLK 55
I am running 255/35/19 and 265/30/19. I have tried both Michelin PSC-2s and Pirelli Trofeo Rs. The Trofeos are even a bit stickier than the PSC-2s. Both, however, were very well balanced with the rears without excessive understeer.
I was running about 3.5-4 degrees negative camber. 4 is a bit much and you can feel front grip while braking, diminish. 3.5-3.7 is probably the sweet spot.
#33
#34
#35
Great to hear that another track guy was successful with fitting 255/35 in front with stock fenders and 9" wide wheels. A local guy has the W212 wheels for sale that another post in this thread mentioned would work. I'm also going to see how much of a spacer would be needed if I used the 9" rear wheels up front. Not too hip on using a spacer unless it was reasonably small. Thanks for your help on this.
#36
C63 coupe, Z3M Roadster garage queen
You missed the earlier post in this string:
OEM W212 E63 wheels on a C63 with 255/275 tires
https://mbworld.org/forums/c63-amg-w...tment-c63.html
#37
Thanks,
Doug
#38
#40
Its not a direct comparison but I track my W212 E63 with the stock 19" wheels and run a 265/35 up front with no rubbing - could probably move up to a 275 but fitting the K-Mac camber plates first and then rechecking fitment.
#41
Gentlemen, looking to purchase W204 Front Camber and Caster bushing Kit #502616K to do some front wheel correction. Just have a question before I purchase. Hopefully someone who has this already can verify.
1. What range do the bushings alone provide. The listing on the KMAC site does not provide the range. Based on what I read here, it claims 4 times the range of the stock bolts so I'm assuming its 1.2 +/- degrees of adjustment?
