C63 AMG (W204) 2008 - 2015
Tranny feels like it's slipping?
Old Sep 3, 2015 | 01:18 PM
ek9beezler's Avatar
C63
I've noticed that the car seems to have an issue shifting. When driving in C mode and at part throttle it will seemingly over rev a bit then finally shift. This happens fairly frequently. The downshifts into 1st and 2nd seem somewhat harsh as well. When in S or S+ it shifts nice and crisp when I'm giving it 3/4 to full throttle. Car is a 2012 with 25k miles. Could it be time for a fluid flush or is this a sign of something more?
Mods are eurocharged v5, long tubes, catless xpipe and row boxes.
Old Sep 3, 2015 | 03:26 PM
nkc's Avatar
nkc
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
reset the tcu adaptations and see if it improves
Old Sep 3, 2015 | 03:32 PM
kb24forlife24's Avatar
None for now
Transmission service should be done every 39K miles.
Old Sep 3, 2015 | 10:17 PM
roadtalontsi's Avatar
10 C six trizzle
if you have the handheld try taking it back to stock and see if it still happens.
Old Sep 4, 2015 | 08:59 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
How would returning the ECU to stock help the TCU?
Old Sep 4, 2015 | 09:59 AM
INS1GNIA's Avatar
'13 C63 AMG P31
I think roadtalontsiwas was trying to figure out if the tune could be the culprit or if it was naturally an issue with the car. The shift points from the tune could affect how jerky the car is. Resetting back to stock could help rule out some things. Though like nkc said, resetting the TCU would be easier/better place to start.
The procedure to reset the ECU is as follows;
1. Turn the igniiton key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 2 minutes, the ECU is then reset.
5. ECU is now reset and you are ready to get new rear tyres.
The ECU rest procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
Read more: Easiest way to reset my ECU
Old Sep 4, 2015 | 11:16 AM
CarHopper's Avatar
E63S | X5
I'd say this is normal for your car. You can reset the TCU doing what insignia said. However, you have a tuned car on headers. Driving characteristics in C mode are quite different than how the car rolled out from the factory. My C mode is a little quirky as well with the slight up-rev before shifting particularly when the car is still cold.
However, all other modes are fine.
Old Sep 4, 2015 | 12:13 PM
ek9beezler's Avatar
C63
PurpleHeart that sounds a lot like my car. I was hoping it wasn't a real issue and it was all in my head. The car behaves quite nice in all other driving modes and is a BEAST when I get on it. Love this thing.
Thanks for all the help guys.
