C63 AMG (W204) 2008 - 2015
C63 does not spin into 2nd or even chirp the tires...?
Old Oct 6, 2015 | 05:18 PM
malaka1's Avatar
13' C63 AMG Sedan
I just recently purchased a 2013 C63 sedan w/ MCT. I had an E60 M5 with the SMG tranny and it would get sideways shifting into 2nd and 3rd and chirp 4th gear. I added a Eurcharged tune to the C63 a couple of days ago yet the car even with somewhat skinny 255's will not chirp into 2nd gear or spin the tires... I kinda miss that feeling. Is it the MCT is not aggressive enough?
Old Oct 6, 2015 | 05:30 PM
tpliquid's Avatar
too poor now
turn off the traction control then u can do it
Old Oct 6, 2015 | 06:06 PM
malaka1's Avatar
13' C63 AMG Sedan
Lol, I should have clarified traction was fully disabled.
Old Oct 6, 2015 | 06:21 PM
flubbernub's Avatar
2013 C63 P31 coupe
Reset the adaptive transmission if you haven't already and see if that helps. Also assuming you're driving in S+ or M mode.
Originally Posted by AMG055
Hey fellow Aussie. The procedure to reset the ECU is as follows;
1. Turn the igniiton key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 2 minutes, the ECU is then reset.
5. ECU is now reset and you are ready to get new rear tyres.
The ECU rest procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
Old Oct 6, 2015 | 06:48 PM
malaka1's Avatar
13' C63 AMG Sedan
I did the reset twice now just to make sure. And I hope it is clear what i am talking about. The tires spin in 1st gear but I upshift to 2nd in M mode and it just changes gear and doesnt chirp or spin nothing.
Old Oct 6, 2015 | 06:57 PM
deadlyvt's Avatar
2010 C63 AMG
Should definitely spin into second ... Especially with 255s unless you have some drag or super grippy rubber...
Your not in sport mode for traction right ?
You are holding the traction button until
"Traction off" appears in the display ?
Old Oct 6, 2015 | 07:12 PM
malaka1's Avatar
13' C63 AMG Sedan
Yes hold it down to fully turn off. Any videos of this online I couldn't find a video of a c63 chirping gears or spinning into 2nd
Old Oct 6, 2015 | 07:16 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Mine spins frist second third maybe even fourth no chirping here either lol
https://youtu.be/xLAGNIPclE8
Old Oct 6, 2015 | 07:32 PM
malaka1's Avatar
13' C63 AMG Sedan
I like it, but not really what i am looking for. I understand that if you start a burnout then upshift it will just keep burning the tires. What i want is to roll in 1st gear shift into 2nd near redline and have the tires break loose on this shift then be able to play with the rear end a little through 2nd then shift into 3rd and have a little chirp and be off!
Old Oct 6, 2015 | 07:37 PM
tpliquid's Avatar
too poor now
like how a civics change gears?
Old Oct 6, 2015 | 07:38 PM
gzim335's Avatar
mct will never bang gears like smg,smg is a automated manual basically dumps clutch on each shift,mct shifts much faster n is a lot more efficient so doesn't have that big pause inbetween shifts like smg does
Old Oct 6, 2015 | 08:06 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Who gives a s**t. If you want to impress chicks tearing out of your high school parking lot get a Honda.
Old Oct 6, 2015 | 08:20 PM
malaka1's Avatar
13' C63 AMG Sedan
Not trying to impress or be like a Honda.. I have always had manual cars and if you have enough power it is fun every now and then to short shift into 2nd and the tires let loose and you can play with the back end a little. Just for fun. I know traction is good but some times being able to have a car snap loose can be exciting.
Old Oct 6, 2015 | 08:35 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Turn the wheel, have traction control off...your tires will break loose, then you can hit a pole.
Your car may also have a LSD which would make it harder to chirp the tires. You could always rev a bit higher in 3rd or 2nd then downshift, this would probably work...just seems like unnecessary abuse. Nothing wrong with testing the car either, just don't be a douche to it.
Old Oct 6, 2015 | 08:37 PM
BLKROKT's Avatar
Here you go. This guy liked grabbing 2nd too.
Old Oct 6, 2015 | 08:45 PM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Good example for grabbing 2nd.
Old Oct 6, 2015 | 09:08 PM
computertom's Avatar
2017 911, 2012 C63
Mine doesn't grab second, it just obliterates the tires into third. I have no idea why yours is ******* that hard. Does the old slush box hit harder then the much faster MCT?
Old Oct 6, 2015 | 09:37 PM
deadlyvt's Avatar
2010 C63 AMG
I have the slush box and like you no problems overwhelming the tires
Old Oct 6, 2015 | 10:38 PM
malaka1's Avatar
13' C63 AMG Sedan
Well I think people are having a hard time understanding me... It's ok I'll drop it.
Old Oct 6, 2015 | 10:56 PM
mthis's Avatar
Anything W/4Wheels
is this what u trying to do. btw that,was with mickey toms DRs.
Old Oct 6, 2015 | 10:59 PM
mthis's Avatar
Anything W/4Wheels
here a bonus vid my friends fbo headrs and all e60 m5 mt not chirping any gears
Old Oct 6, 2015 | 11:01 PM
rage2's Avatar
C63 BS, GLA45
I couldn't spin the tires in 2nd gear in a straight line either with any of my C63s including the BS. But that's because I live up in the mountains at 3700ft and lose around 20% of my power.
At sea level, no problems spinning the tires for no reason haha.
Old Oct 6, 2015 | 11:06 PM
mthis's Avatar
Anything W/4Wheels
Thats so true. in the summer time when the humidity is high car feels like its down 50hp. winter time when its -1000da car is 1.5-2.0sec faster 60-130.
Old Oct 6, 2015 | 11:16 PM
Blown4door's Avatar
E63, 190e, s400
is it a real amg or a c250 with a kit lol. i have problem catching traction in 3rd
Old Oct 7, 2015 | 02:22 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
I was looking at your speedo/tach clip. 5 seconds 20-60 seems much slower than mine, but I don't normally get any spin going into second. Do you? If yes, what kind of tires are you running?
