C63 AMG (W204) 2008 - 2015
ACG Automotive: KW Suspension Sale
Old Oct 9, 2015 | 02:46 PM
ACG Automotive's Avatar
AMG
SALE PRICING: KW SUSPENSION
Buy Now and Save with our Unbeatable Prices
***Coilovers and Sleeve Kits***
20% Off All Products
KW V3: $2,481.00 + Shipping
KW Clubsport: $3,200.00 + Shipping
KW DDC: $3,680.00 + Shipping
HLS2 Upgrade: $2,880.00
HLS4 Upgrade: $3,800.00
KW V3's including KW HAS nose lift kit
Old Oct 10, 2015 | 12:42 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Is the V3 @$2481 already discounted?
Old Oct 10, 2015 | 01:55 AM
AMG
Correct!
Old Oct 10, 2015 | 08:51 AM
mr747's Avatar
c63
How much for shipping for me my friend
Old Oct 10, 2015 | 09:10 AM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Can you please explain some of the choices - there are simple solutions like the Clubsport, as well as DDC versions. The C63 has adaptive dampers ex works. Do the KW solutions leverage that factory setup or are stand alone?
Old Oct 10, 2015 | 10:53 AM
Girard@ACGautomotive's Avatar
a car
Brad remind me your postal code in Aus again... I'll get you a transit rate first thing on Monday.
The W204 C63 has no adaptive or dynamic dampening. The suspension set up for these cars is purely static.
Switching to a KW coilover system is in my opinion one of if no the best modifications next to a limited slip diff in these cars.
I think we can all attest to how uncomfortable the ride can get with a performance packaged car/507 and the struts alone in the KW are worth the upgrade for comfort alone.
V3 are 3 way adjustable. You can obviously adjust the ride height, beyond that you have individual adjustable settings for damping in compression and rebound. These dials are located at the top and the bottom of the strut and manual adjustment is required which can be cumbersome if you are constantly switching from a track to street set up.
KW also offers a DDC (Dynamic Damping Control) which allows users to adjust the damping of the strut with a module and button or their really trick app inside the vehicle without having to physically touch the strut as well as programing 3 preset modes for the car:
The app available is extremely cool and very functional for on the fly and deeper custom adjustments to set up the DDC functions:
The clubsport is an available coilover solution for those who are looking for a very track oriented set up. KW specific top mount camber plates, stiffer spring rates and valving. These have the same adjustable aspects of the V3 but are more suited for track use and much harsher on the street.
We can tailer a High Lift System (HLS) to any coilover if you are worried about lowering the car and hitting the nose.
Let me know if you guys have any other questions. I've installed countless KW systems for the W204 C63 and would be glad to help!
Old Oct 10, 2015 | 02:44 PM
Wobble64's Avatar
LOL, I just assumed the C63 had adaptive dampers. I have seen cables going to the shock absorber. Upon taking a closer look all they were were the cables to the brake wear sensor and ABS sensor. Simple setup then - I actually prefer that. The phone control option works for iPhone only.
Hmm, food for thought. I like the idea of height adjustability.
Winter project?
Old Oct 10, 2015 | 09:23 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Definite winter project - great prices
What are the main differences between the V3 and Clubsport?
On an unrelated note, those rear fenders on the car above. Are those custom one-off? I like it.
Old Oct 10, 2015 | 09:51 PM
Wobble64's Avatar
Wanted to ask the same question re differences between V3 and Clubsport. Valve settings and camber plates?
Old Oct 11, 2015 | 12:40 AM
Phil Chow's Avatar
W204 C63
I have no personal experience with the C63 Versions, but, back on the GTIs, yes, it's essentially the Valving and Camber Plates. However, Camber Plates on the CS are an optional item, IIRC.
ClubSports are also much "Beefier", and will hold up to much more abuse.
Old Oct 11, 2015 | 08:06 AM
mr747's Avatar
c63
Hey tal 3043 buds
Old Oct 11, 2015 | 11:30 PM
Asher4799's Avatar
2009 C63/ 2015 C63 507 coupe
What's pricing on the ddc set up? Trying to decide between that and the kv3 and shipping thanks. Pm me
Old Oct 12, 2015 | 12:46 PM
a car
Bingo. Topmount camber plates, strut valving and stiffer spring rates.
They are very track oriented that can be used on the street. The V3 are going to be much more comfortable all around.
Old Oct 12, 2015 | 12:48 PM
a car
$3680 for the DDC set up. In stock.
PM me your shipping zip and I'll let you know.
Thanks!
Old Oct 12, 2015 | 12:54 PM
a car
Hey tal 3043 buds
Around $500 USD for shipping down there man. Let me know if you want to place an order
Old Oct 12, 2015 | 01:17 PM
Asher4799's Avatar
Thanks!
Pm'd
Old Oct 13, 2015 | 08:21 AM
Wobble64's Avatar
Hi Tal, what is the cost of the Clubsport set shipped to 45040 (Ohio)?
And how does rear height adjustment work? Is that also infinitely adjustable or in increments? Is the adjustable spring seat on the top or bottom - and is it easy to get to to make adjustments, or is it essentially an uninstall/reinstall kind of job?
Thanks!
Old Oct 13, 2015 | 10:42 AM
BLKROKT's Avatar
Great, thanks Tal.
Now tell me more about those rear fenders
Old Oct 13, 2015 | 10:55 AM
sheeyo's Avatar
E63S Wagon
Freight cost for V3s to 92804?
If local, is pick up an option?
Thanks.
Old Oct 13, 2015 | 11:48 AM
a car
Thanks!
Ground shipping will be about $50 to that zip so $3250.
You'll have to basically swing out the lower control arm from the diff side and remove the coil and perch to adjust ride height. Not too cumbersome if you have a lift but can definitely be done on jack stands.
The adjustment perch sits in between the chassis and the spring so it's on the top side.
Thanks!
Originally Posted by BLKROKT
Great, thanks Tal.
I wish I could.... It hasn't been the most enjoyable process getting them so far.
Thanks.
About $40 from us here in SD. You could definitely pick them up if you want, or we could install and align here at our shop
Old Oct 16, 2015 | 06:58 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Just because vivid keeps creating not so "special" kw suspension sales threads with no prices. I'm going to bump the great guys at ACG for being transparent with their special mbworld prices!
Old Oct 16, 2015 | 07:08 PM
AMG
Old Oct 21, 2015 | 01:41 PM
AMG
We installed KW V3s on this awesome weistec build we did a few years ago.
Old Oct 22, 2015 | 09:03 PM
BLKROKT's Avatar
Nice
Old Oct 23, 2015 | 06:47 AM
Wobble64's Avatar
Hey Tal, is this a manufacturer promotion with a deadline or will you be able to hold these prices into the winter? I am considering a suspension upgrade as winter project.
