C63 AMG (W204) 2008 - 2015
Front rotor fittement
Old Nov 4, 2015 | 01:39 PM
Robert AMG's Avatar
Cls63 & C32
Does the cls219/w230 55 AMG P30 rotors/calipers 38cm double piece fit the w204 63?
thanks.
Old Nov 4, 2015 | 03:44 PM
Girard@ACGautomotive's Avatar
a car
No sir. Those are 390mm
Old Nov 4, 2015 | 05:08 PM
Robert AMG's Avatar
Cls63 & C32
the one i am talking about are 38cm, the 39cm are for 65 engine and black series, i have both in hand, so they don't fit?
Old Nov 4, 2015 | 05:11 PM
a car
The C63 uses a 360mm rotor... so no those would not fit.
Old Nov 4, 2015 | 05:36 PM
Robert AMG's Avatar
Cls63 & C32
i mean both rotors and calipers swap.
Old Nov 4, 2015 | 05:50 PM
a car
I highly doubt they will bolt up to the spindle without adapters.
Old Nov 5, 2015 | 04:50 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
There is a detailed thread on a RacingBrake upgrade to go from the stock C63 brake dimensions (360mm diameter front rotors, 330 mm rear rotors), to a 390/360 setup (i.e. Black Series dimensions). I actually have that setup installed.
In order to do that, the front calipers need adapters and in the rear I had to swap the stock calipers against Black Series calipers, that have longer 'legs'. In the rear an adapter does not work.
A 390 mm front rotor also needs at least 19 inch rims, so you could not run 18 inch rims (e.g. in winter).
If you want to reuse your 390 mm caliper, you need the adapters and would have to make sure that the offset of the rotor matches the stock C63 rotor. It cannot be further towards the inside or further towards the outside than the stock rotor. That latter is probably the case, since they are all Mercedes, but not 100% certain.
