C63 AMG (W204) 2008 - 2015
AMG3.2's DIY Headbolt Adventure
Old Sep 28, 2016 | 10:00 AM
  #126
andrew c230k's Avatar
W204 C63 R171
Originally Posted by Vladds
Do the heads separate easy?
on stud blocks that have limited work room in the bay, to separate the heads it can be hours and hours of work, the studs "cement" the heads into position.
Also, Andrew, I thought Mercedes antifreeze was blue. Did your car have green antifreeze in the first place?
The original 2008 antifreeze was yellow color, the new antifreeze is blue... blue+yellow= green my car burnt up 8L of coolant before I figured out what was going on. My car only had 35,000 miles on it or 57,000km
Also Mercedes does not use studs in these engines, there is one aftermarket solution weistec/arp stud they are about 4 times the cost of the bolts alone. They are good insurance but for my usage not worth the additional money. even if I was running a blower I might trust these new bolts but then again maybe not given the situation with the old poorly designed bolts.
The problem with these bolts doesn't seem to be a mileage related issues to me its a time frame thing they are just interesting that 2016 seems to be the year of the head bolt most of these cars are roughly 6-8 years old and they fail. Mercedes knows the cause it's more then just poor design as the bolts are coming out of most engines rusty... there is more going on then we know.
Old Sep 28, 2016 | 10:55 AM
  #127
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I have green as well since I did my thermostat a couple years back.
Old Sep 28, 2016 | 11:17 AM
  #128
AMG3.2's Avatar
C63 AMG, P30
Probably why replacing them via bolt by bolt method has been (knock on wood) successful so far if you do it prior to them failing.
Originally Posted by s.e.a.n.
I just had my head bolts and head gaskets replaced however they install new tappets and its still ticking after 15 miles of driving.
Take it back and have the shop listen. Mine are pretty dang quiet at this point.
Old Sep 28, 2016 | 11:54 AM
  #129
Vladds's Avatar
2010 C63 2019 GLA45
I'm aware that the M156 has bolts only, never studs for the heads, except for aftermarket.
The background of my question regarding the heads is that I only separated non Mercedes stud fastened heads. I wonder if bolt fastened heads like the M156 are easy to separate once the bolts are out of the way, as they don't wedge into the studs.
I thought that separating the heads is hard work, as you have to convince them to move, but not damage them at the same time.
Old Sep 29, 2016 | 07:10 AM
  #130
Vladds's Avatar
2010 C63 2019 GLA45
Originally Posted by Merc63
It's fine lol. If you removed one at a time, it's going to be fine.
Merc, so you know of others that did bolt by bolt on M156 and are running them for a while now, without problems?
Old Sep 29, 2016 | 09:24 AM
  #131
Merc63's Avatar
C63 AMG
Yes I've done a couple here and my mechanic buddy has done lots now. What would go wrong I don't get what people are worried about...
Old Sep 29, 2016 | 12:39 PM
  #132
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
They're worried about potentially upsetting the HG with 1 of 10 bolts removed which is a legit concern.
Unless you can load up a 3D model of the head and block in some sort of stress analysis software to verify, we won't really know if 1 bolt removed will do anything.
Old Sep 29, 2016 | 01:12 PM
  #133
AMG3.2's Avatar
C63 AMG, P30
Yeah - this for sure.
Even though with 9 other bolts holding things in place with tremendous force, I still let my imagination wander.
Old Sep 29, 2016 | 02:08 PM
  #134
Vladds's Avatar
2010 C63 2019 GLA45
This is something more often done in the Duramax diesel forums.
The diesel has quite a higher compression ratio, but I see one instance of blown head gasket after a bolt by bolt like 2000 miles later.
Many seem to be fine.
Again, much higher compression ratio and force fed with really high pressure.
The supra people look like they are doing this too.
Old Sep 30, 2016 | 01:10 PM
  #135
bhamg's Avatar
C63 AMG
I guess no further update is a good thing...congrats AMG3.2!
Old Sep 30, 2016 | 01:58 PM
  #136
AMG3.2's Avatar
C63 AMG, P30
Ha! Yeah, everything seems to be working fine.
Old Oct 3, 2016 | 08:02 PM
  #137
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by AMG3.2
Winner!
http://i77.photobucket.com/albums/j4...ps5suyliym.jpg
Fluid would change color to yellow/green if exhaust vapor was entering cooling system. This is the fluid after about 4 minutes of testing. Directions state to test for 2 mins.
Here's mine after 5-6min. Vid starts at the 5min mark.
I want to give it another go with my mitty vac connected to draw more air through (don't want to mess with a vac line). Did yours bubble this slowly as well? I'm just concerned about a false positive.
Attached Thumbnails AMG3.2's DIY Headbolt Adventure-img_20161003_1952274.jpg
Old Oct 3, 2016 | 09:22 PM
  #138
AMG3.2's Avatar
C63 AMG, P30
So mine actually have a little pump thing at the top to suck up air from the resevoir. Basically a turkey baster design like this. http://contentinfo.autozone.com/znet...27145/image/3/
Also, what do you mean false positive? Is blue considered exhaust vapor for your tester fluid?
I didn't see anything change...
Old Oct 3, 2016 | 09:40 PM
  #139
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I have the 7550 that you connect to a vac line. http://www.lislecorp.com/divisions/p...s/?product=406
False positive, as in, not enough gasses passing through to change the fluid colour even if there's combustion gasses in the cooling system. No idea how sensitive that fluid is.
Without negative pressure in the cylinder tube it was bubbling slowly which is why I want to give it another try with my mittyvac connected.
Old Oct 4, 2016 | 02:23 AM
  #140
AMG3.2's Avatar
C63 AMG, P30
Oh gotcha. Yeah, I'd think you'd want to be sucking air in there either with a Mityvac attachment or with the little siphon pump thing.
This is the one I used in the video. Around the 6:18 mark, you can see a good amount of air coming through each pass. This is what I did for 4 minutes as opposed to just sitting it on top. To your point, I could probably see that being less thorough
Old Oct 11, 2016 | 01:45 AM
  #141
AMG3.2's Avatar
C63 AMG, P30
Update: About 320 miles in and running strong...
Old Oct 11, 2016 | 07:27 AM
  #142
Vladds's Avatar
2010 C63 2019 GLA45
This is great. The VDC code never came back?
Old Oct 11, 2016 | 01:35 PM
  #143
AMG3.2's Avatar
C63 AMG, P30
Never came back.
Only thing I can think of is some sort of electrical gremlin due to disconnecting the battery...
Old Oct 11, 2016 | 02:28 PM
  #144
Vladds's Avatar
2010 C63 2019 GLA45
Nah, I'm working on replacing the intake manifold gaskets and did not even disconnect the battery, just so that I don't bump into this problem, but got the same outcome, no ABS, VDC.
Old Oct 11, 2016 | 03:08 PM
  #145
AMG3.2's Avatar
C63 AMG, P30
Strange. I couldn't clear it with a regular scanner. Only STAR seemed to do the trick.
Old Oct 16, 2016 | 03:30 PM
  #146
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
2010 with 115K km (71k miles). They're not as bad as I was expecting. Looks like at some point they started putting sealant on the thread.
Right Bank
Left Bank
Attached Thumbnails AMG3.2's DIY Headbolt Adventure-hblb1.jpg   AMG3.2's DIY Headbolt Adventure-hblb2.jpg   AMG3.2's DIY Headbolt Adventure-hblb3.jpg   AMG3.2's DIY Headbolt Adventure-hblb4.jpg   AMG3.2's DIY Headbolt Adventure-hbrb1.jpg
AMG3.2's DIY Headbolt Adventure-hbrb2.jpg   AMG3.2's DIY Headbolt Adventure-hbrb3.jpg
Old Oct 16, 2016 | 05:58 PM
  #147
W204 C63 R171
Was wondering how you made out this weekend. Any cracks under the bolt caps or caved in driver areas from over stretching?
My 2008 had tread sealant as well
Old Oct 16, 2016 | 06:15 PM
  #148
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nope, they were all fine. The closeups above are of the worst ones. A couple of them looked good enough to resell lol.
Old Oct 16, 2016 | 07:00 PM
  #149
AMG3.2's Avatar
C63 AMG, P30
Nice. Looks like we both got lucky.
Are you still mid project?
Old Oct 16, 2016 | 07:13 PM
  #150
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Unless there's 20 more bolts to go.
