C63 AMG (W204) 2008 - 2015
Will 255/35R19 or 265/35R19 work on the rear?
Old Jan 17, 2016 | 11:35 PM
Jazz0909's Avatar
C63 AMG Edition 507 Sedan
Looking to get some new summer tires. I have winter tires on 18" wheels and I like the ride - it's my daily driver and I don't want to sacrifice that much when going back to the 19's
Do you think I can bump up from a 30 series to a 35 series on the rear for my stock 507 wheels on stock suspension (it's a sedan if that makes a difference)? I see a bunch of threads about using this size on the front, but nothing for the back.
I know most people go wider, but going wider and a higher aspect ratio is really gonna put me in trouble...maybe I could squeeze a 265/35 under there?
I'm hoping sticking with the 255, but buying a quality tire (something like a MPSS) makes up for the lack of width - and then teh aspect ratio takes care of the ride.
Old Jan 18, 2016 | 01:18 AM
CarHopper's Avatar
E63S | X5
I would recommend a 265/30/19 for the rear. I understand wanting to bump it up but you really aren't sacrificing much in terms of comfort.
The 265/35 is likely to be too tall of a tire which may lead to rubbing issues, even on a stock suspension, particularly on the rear passenger.
Old Jan 21, 2016 | 11:08 PM
Jazz0909's Avatar
Well that sucks, lol
I'm running a 245/40/18 for winter which are 25.7" diameter with no issues, so I was hoping I could run a 255/35/19 which is only 0.3" taller (though I guess the extra 10mm of width compounds the issue).
Back to stock size, who is running a 255/30/19 Michelin Pilot Super Sport - according to TireRack they have a 10" wide tread width which is 0.5" to 1" wider than most other tires that size that must be a typo correct?.?.?.?
Old Jan 21, 2016 | 11:41 PM
Phil Chow's Avatar
W204 C63
I'm running 255/30/19 Michelin PSS on the AMG Multispokes without issue.
And yes, PSS tires typically run wider than other brands of the same size.
Old Jan 22, 2016 | 12:47 AM
Jazz0909's Avatar
Is the tread really that much wider than other brand/model tires of the same size?
Old Jan 22, 2016 | 12:49 AM
Phil Chow's Avatar
W204 C63
Yes.
Same with Yokohama ADVAN Neova AD08/AD08Rs, they also run wider.
255/30/19 Michelin PSS, runs close to some sizes 265/30/19.
Fun Fact: Hankook RS3s also did this too, their 255/40/17 was known as a "cheater tire".
Old Jan 22, 2016 | 01:34 AM
Jazz0909's Avatar
Yes.
that will make costco happy too that I'm using the stock size
Old Jan 22, 2016 | 06:50 AM
yellows2k's Avatar
so will a 265/30/19 pss be too wide then? cos that s what im looing at moving to soon
Old Jan 22, 2016 | 07:50 AM
c32_amg_79's Avatar
2011 C63 AMG, 2011 Audi A4
265/30/19 is fine. That's what I have for my summers.
Old Jan 22, 2016 | 07:53 AM
yellows2k's Avatar
Great. What about the fronts. I'm thinking of going to 245/35/19
Old Jan 22, 2016 | 08:00 AM
c32_amg_79's Avatar
My fronts are 235/35/19. The tire shop recommended that size.
I'll let the other members comment on 245/35/19. I'm not sure if they will fit or not.
Old Jan 22, 2016 | 11:57 AM
Phil Chow's Avatar
W204 C63
The widest people run is:
245/35/19 and 275/30/19. However, if you're running Michelin PSS, you must run a 19x10 +50 or higher in the rear for it to clear. And you won't be able to go too low with that setup either.
In regards to front, 245/35/19 is perfect. Most people run it with an 8.5 +45 / 8.5 +40, 9 +40 will also work too, even on a PSS.
If you're looking to run a 8.5 / 9.5 +45 setup, then you can still run a 245/275 setup, but you need to run a Hankook V12, as they run skinnier.
Hope that helps!
Old Jan 22, 2016 | 03:41 PM
Asher4799's Avatar
2009 C63/ 2015 C63 507 coupe
I also run 275/30/19 rear and 245/35/19 fronts with H&R springs .75 drop no issues and on drag set up 285/35/18 rears these are nitto 555r drags and they almost rub depending on inflation as for the street 275/245 its the nitto nt05's
Old Jan 22, 2016 | 08:50 PM
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
Dropped with 275 rears and no rubbing?? What tire are you using? I would love to do this. Also what width is your rear wheel?
Old Jan 22, 2016 | 08:58 PM
Asher4799's Avatar
Nitto nt 05 but the issue is they wear very fast I would go through a set of rear every 4,000 miles
Old Jan 22, 2016 | 09:57 PM
Phil Chow's Avatar
W204 C63
You can be lowered and run 275/30/19 PSS too, just with the right offset.
Old Jan 22, 2016 | 10:01 PM
Asher4799's Avatar
What Phil said the NT05s are great but don't last go with the PSS
Old Jan 22, 2016 | 11:04 PM
avery.whss's Avatar
S550 on order
you can run 295/25/20's on the rear without much rubbing ..i ran that and 285's for well over a year..although i wouldn't recommend it as your rims will take a beating
Old Jan 22, 2016 | 11:41 PM
Asher4799's Avatar
So then if it doesn't work without rubbing why would you suggest it?
Old Jan 22, 2016 | 11:46 PM
avery.whss's Avatar
S550 on order
it doesn't rub 99% of the time unless you have 3 people in the back and even then it wasn't much
Old Jan 23, 2016 | 12:10 AM
Asher4799's Avatar
That's an answer I will accept.
Offset?
Old Jan 23, 2016 | 01:46 AM
Jazz0909's Avatar
This thread seems to have become a quick reference for wider tires lol
I was talking about taller, but I guess nobody goes that route
Old Jan 23, 2016 | 02:47 AM
avery.whss's Avatar
S550 on order
Offset?
+52
Old Jan 25, 2016 | 01:03 AM
Naverino's Avatar
2013 C63 w/PP, 2014 ML63 AMG w/PP
so would 265/30/19 w/PSS tires on a 19x9 rim et45 work ok on stock height? Keeping in mind my C63 has the "saggy butt"
Old Jan 25, 2016 | 09:38 AM
Asher4799's Avatar
Yes it should
