C63 AMG (W204) 2008 - 2015
Transmission problems.
Old Jan 18, 2016 | 11:52 AM
unelldl's Avatar
2015 Mercedes C63
My new C63 delivered in New Orleans March 3rd, 2015. Did not like the way the transmission shifted in any mode. In addition on occaision, when accelerating from stop it would simply not go! No change from idle. In a second or two it would surge forward. This would happen maybe once or twice a week. I was in the process of moving to Tampa and since the local dealer said there was nothing wrong. Decided to wait till I moved to Tampa. In Destin on the trip to Tampa that anomaly happened twice Scary in traffic and no brake lights and no movement. Car is in shop now at MB Tampa. Would like to know if anyone else has that problem and their solution.
Mercedes advertises:
The 7G-DCT dualclutch transmission operates without any interruptions in tractive power andoffers the comfort of an automatic transmission combined with the efficiency ofa manual transmission.
Mine never had this.
Old Jan 19, 2016 | 04:20 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 AMG forum...
Old Jan 19, 2016 | 05:42 PM
JoelSolid's Avatar
2016 C63 S
I don't think this is a W205. Secondly The C63 doesn't have a DCT. Then again neither did the W204.
Old Jan 19, 2016 | 05:51 PM
mister2d's Avatar
15 AMG C63S ED1
His profile says 2015 C63. Looks like a W205 to me.
Old Jan 19, 2016 | 08:35 PM
Trim105's Avatar
C63S Coupe/Range Rover Vogue SE
But the thread itself is titled "My C63 2015 Coupe Silver", could be a bit of an error, who knows...
Old Jan 19, 2016 | 10:29 PM
RDOCA's Avatar
2016 C63S Sedan
If it is a 15 C63 Coupe it would be a 204 would it not?
It still would have a MCT.
Old Jan 19, 2016 | 11:47 PM
rohitC63's Avatar
C63 AMG
2015 C63 coupe is the W204 body
Old Jan 20, 2016 | 06:46 PM
westwest888's Avatar
'15 Boxster, '10 S4
He started another thread saying he has a coupe, but he means a used W204. Very confused person or robot.
Old Jan 22, 2016 | 09:36 AM
unelldl's Avatar
2015 Mercedes C63
My C63 is a coupe (2 Door) manufactured by AMG in October, 2015. Does anyone have or experienced the pressing accelerator pedal from stop and no change in RPM?
Old Jan 22, 2016 | 11:32 AM
PeterUbers's Avatar
Yes this has Happened to me and several other e63S owners
I haven't had this since about a year ago when I got an Ecu update but the mct is a crappy transmission in stop and go traffic
Old Jan 22, 2016 | 01:43 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
I'm not sure if this is even an MCT issue. I've had it happen on both a 2015 E400 and a 2015 GLK350. I think it has more to do with electronic controls that MB uses for throttle and transmission control.
Old Jan 22, 2016 | 02:40 PM
unelldl's Avatar
2015 Mercedes C63
MCT Malfunction
Have you experienced or know of anyone that reported from stop where the engine Rpm goes up but car doesn't move. Then you feel a shudder and suddenly it catches!
Old Jan 22, 2016 | 02:44 PM
unelldl's Avatar
2015 Mercedes C63
SteveE400, what did dealer do.
Old Jan 22, 2016 | 02:46 PM
RDOCA's Avatar
2016 C63S Sedan
Sounds like clutch not engaging (fluid coupling replacement) and could be caused by soft wear or hardware. Possible one of the clutches inside the trans is not locking up also but good chance it is soft wear.
Have you asked the dealer for a transmission update (flash)? Does it save any codes?
Old Jan 22, 2016 | 03:01 PM
PeterUbers's Avatar
Never had this problem... This is a wet clutch engagement problem
Old Jan 22, 2016 | 03:49 PM
SteveE400's Avatar
I've not had any "over-revving" at all -- only the "moment of silence" as the computers try to make sense of your input to the throttle and get the engine to react. The transmission has always been ready to go, as soon as the engine wakes up.
As a side note, I have had similar hesitation on many brands of cars - Lexus, Nissan, Hyundai, Ford, etc., so I do believe it is endemic to the drive-by-wire throttle and how it is programmed. I can see why so many cars are now using electronic throttles (can you imagine how messy the linkages would need to be to operate the newer intake systems?), but I wish manufacturers would spend more time refining drivability.
Old Jan 22, 2016 | 11:10 PM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Op, based on your description you have a 204 chassis not a w205. 2015 c63 coupe is the 204. The moderator may have mistakenly moved your thread here.
Also it appears that you complained about pressing the throttle but no rpm increase. Then again you complain about pressing accelerator rpm increasing but clutch engaging irregularly. I am paraphrasing of course. Which of these two is it?
Old Jan 23, 2016 | 12:15 PM
unelldl's Avatar
2015 Mercedes C63
Transmission Problems
I have both of the problems described above. The problems with MCT are well documented. Software seems to blame. Picked up car yesterday 1/22/2016 from the dealer and the no rpm change under acceleration exhibited when turning on to a side street. Most of the time this car sounds and accelerates much better than the F430 I drove on a racetrack. Most of the time it would take a surgeon to get the smile off my face. The special tune, headers and intake mods turned this beast into a MONSTER!
Old Jan 28, 2016 | 08:14 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
ok, moved to W204 AMG forum...
Old May 31, 2023 | 04:49 PM
jig62's Avatar
c63 AMG
I had similar problem, Its a wet clutch engagement problem
Old May 31, 2023 | 07:34 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
thank you for clearing this up so concisely after over 7 years. Would read again.
