Newbie confused about LSD - see pic
#51
2009 C63 P30, 2008 Grand Cherokee SRT8(RIP)
Interesting read, great info.
For the op, try to lay some more rubber on the street for a longer distance and see if one wheel spins more and has a longer mark?
Mechanical locking differential is the same thing as lsd right? And open differential is a non-lsd model?
And as for the nannies stepping in to act as a LSD that is just not true....jack up the rear of your car, turn off the ESP, hammer it and let me know exactly when those nannies step in, they won't.....ever........go out onto an iced over lake, turn the ESP off, turn the wheels to the left or right and matte it.... NOTHING will intervene UNTIL you apply moderate braking force, THEN ABS will assist.....
And as for the OPs original question regarding two black stripes......YES an open diff WILL do this under a wide array of circumstances.... The only time that an open diff KNOWS it's an open diff is when one side sees more/less traction than the other....the rest of the time it applies EQUAL power to both wheels as they have EQUAL traction.... So when both tires are on the same surface, with the same traction it WILL leave two stripes, just like a limited slip or a locker with only one exception..... With a LSD or locker the stripes will be equal in distance, but on the open diff set one WILL BE LONGER THAN THE OTHER, as available traction will change due to torque loading one axle and when this happens the open diffs spider gears will progressively send more and more power to the less tractive wheel until ONLY that wheel is spinning, ie leaving a stripe of black rubber in its path....physics does not change no matter nanny
and to be honest the best remedy to get the most out of an open diff is knowing how to use the Ebrake to balance traction to each rear tire, when you can do this correctly an open diff acts just like a limited slip(ask anyone who plays in the mud with an open diff how they keep from getting stuck)
#52
2012 C63 AMG BS, 2010 C63 AMG (sold), 2006 M3 (sold)
Thx for the explanation, as my cbs data card says 471 mechanical locking differential, I was unsure of this. Quite an interesting thread. Thx everyone for contributing and the op for starting it.
#53
Did you miss this post? -->https://mbworld.org/forums/c63-amg-w...ml#post6699217
It's called ETS which is a module of ESP (aka nannies) that is always enabled according to the owners manual. If that's incorrect, maybe you should let them know about the error.
#54
Stop spreading false information... Maybe give your owners manual a read as well. If you lost yours you can download the PDF for free (https://www.mbusa.com/mercedes/servi...owners_manuals)
Just think about what you are saying.... IF what you were interpreting the manual to say were accurate then if you did a REALLY good burnout, as in the kind when you NEVER let off the throttle, as long as the rear tires were spinning the system would continue to apply more and more and more brake until eventually you came to a stop.....
One thing I will concede though is that my car is an LSD p30 car so I can't speak for how the ESP programming in a non-LSD could differ
#55
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
There is no such thing as brake-simulated LSD in the sense it's being used here, people are getting really mixed up. It's just stability control. It won't help you put down stripes.
#56
Stability control is comprised of multiple components. They don't all have to be active at the same time. Like the OM said, ETS is a component of ESP where ESP = "Stability Control" and brake actuated LSD is either all of ETS or a component of ETS.
#57
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
The assist that is suppose to make the system act like an LSD doesn't work like it was designed on paper. It's suppose to bridge the gap between full open and an LSD, but in my real world feel on the street it is slow and will never take over from what a real LSD diff can do. Which is why they still put the LSD in the higher end models. If the assist was so good they would not need to do this.
To me the brake assist to counter balance the loose wheel with braking is slowing the car down, and in a track situation it is totally worthless.
#59
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
A standard locked differential applies exactly equal speed to both wheels.
A LSD lies somewhere between the two.
