To mod or keep stock?
I wanted to get some feedback from those who have tuned their cars. Is it worth it? I'm a lot older and think 507HP is probably good enough....then again 550HP would be a nice upgrade too
So what do you suggest? And if it's worth modifying, I'd be looking for suggestions on reputable products I can get installed at a reputable place in Western Canada or Northwestern USA (Seattle area).
Thanks,
Jason [MSFT]
Thanks,
Jason [MSFT]
after you get bored with stock, start with tune and a either a xpipe or hpipe in place of the cats & resonator. Car doesn't get too loud at idle but you'll notice it at over 4k rpms.. When you get bored of that you can get more power and noise with a nice set of long tube headers. (IMO, id rather spend 3k on the headers instead of the 3k on aftermarket mufflers).
Thanks,
Jason [MSFT]
But you will need LTH to achieve 550....
Then its the next significant step of superchargers...
550 is more than enough for daily use... unless u are chasing numbers...
Thanks,
Jason [MSFT]
Going back to stock is easy, takes about 5 minutes with the programmer that you would have.
Thanks,
Jason [MSFT]
. As far as the tune, it will pick up a little hp but the main diff would be how the car feels after the tune. I went with the Eurocharged V5 tune and was amazed. The sounds and feel is a big improvement. Not sure if the car already has ROW airboxes since you are in Canada but if not, ECS tuning can help out with that and filters: https://www.ecstuning.com/News/Merce...012_2013_2014/
If you are looking for exhaust, I would suggest replacing 2nd cats with straights. I have this done and it keeps the AMG sound but makes it more throaty/healthy sounding and a bit louder (a def must I would say). Then if you are looking for more sound later you can always remove resonator, do h or x pipe or add headers.
The intake system is fine, I wouldn't touch it. Waste of $, maybe ROW airboxes.
If you need any work done or anything installed at a very reasonable rate, just let me know, I know a very good guy in your area.
I have never understood going the cheap route with just replacing the resonator or rear cat delete pipes, I say do it right:
1)Tune (Eurocharged, Weistec, OE)
2)Headers with mid pipes and X-pipe (MBH)
This alone will transform the beast and take it to another level.
Beyond that, smaller returns but worth it:
ROW air boxes
High flow air filters
Keep your engine clean with a Weistec oil/air separator.
I just always figured if I'm going to be louder and get attention, I better be able to back it up when called upon....which is why headers and tune add a good amount of extra go fast when needed.
ROW air boxes
. I do agree though, headers do add a bit and help overall.
MBH Long tube headers, mid, X, and hi-flo cats - $4600 (or weistec - $5600)
+Install +$1,000
Tune - $1,500
Total ~ $7,000
Get bored and need that supercharger...
Weistec Stage 2 - $13k
Install - $3,000
Tune - $1,500
Total now - $24,500
Realizing you just spin your tires and need some rims and wider tires...
Rims - $3000
Tires - $1,200
Track rims and Track tires - $4,000
Total now - $32,500
Does that sound about right? Honestly I'm just trying to figure out how much I'm going to spend on mods in the next...oh...5-7 years or so...
Would I need to dyno the car or would you have a tune for Edmonton (~2400ft)?
+Install +$1,000
Tune - $1,500
Total ~ $7,000
Install - $3,000
Tune - $1,500
Total now - $24,500
Rims - $3000
Tires - $1,200
Total now - $32,500
