C63 AMG (W204) 2008 - 2015
michelin pilot super sport
Old Mar 19, 2016 | 04:32 PM
beaststunt's Avatar
09 c63
Just purchased a new set of rim ,tires what pressure are you guys running in michelin super sport 235 front 265 19 rear, for street use, also I had pressure sensors installed ,the warning light came on what do I need to do to get rid of the warning light, thanks
Old Mar 19, 2016 | 04:40 PM
CarHopper's Avatar
E63S | X5
44psi front, 46psi rear.
Old Mar 19, 2016 | 05:14 PM
beaststunt's Avatar
09 c63
Old Mar 19, 2016 | 06:19 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
You have to drive the car for a short while before the TPS warning clears.
Old Mar 19, 2016 | 06:25 PM
AMG 17GT's Avatar
R Nine T
And that's a hot PSI BTW
Old Mar 19, 2016 | 06:39 PM
CarHopper's Avatar
E63S | X5
Which is also located on the inside of your drivers door.
The low pressure warning shouldn't take very long to clear, few miles.
Old Mar 19, 2016 | 07:09 PM
Mort's Avatar
Once you have the tire pressure set you can restart the TPMS.
-Key in position 2
-arrow over to the Service Menu
-arrow up or down to the Tire Pressure
-Press OK
-Tire pressure will be set after driving a few minutes
or
-Arrow down to Use current pressures as new reference values
-Press OK - Tire press. monitor restarted.
I know it can be a pain in the butt but try to "RTFM"
Old Mar 19, 2016 | 07:30 PM
beaststunt's Avatar
09 c63
-Key in position 2
-Press OK
or
hahaha the forum is my manual
Old Mar 19, 2016 | 09:19 PM
1Lop2K5C's Avatar
C63
Interesting, why so high? I do 39-40 all around.
Old Mar 19, 2016 | 09:42 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Same here. 40 front and rear.
Old Mar 19, 2016 | 10:08 PM
CarHopper's Avatar
E63S | X5
I'm just relaying what is on the inside of the door.
I'm right around 40/42 I believe. Been a minute since I've checked the pressure and am about to replace the front tires anyway.
Old Mar 19, 2016 | 10:46 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Mine is exactly the same, can definitely tell a difference in ride quality if any higher/lower.
Old Mar 20, 2016 | 01:25 AM
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Too high.
Old Mar 20, 2016 | 09:34 AM
AA717driver's Avatar
‘04 996 C4S, ‘18 GLC, ‘19 Alltrack
The dealer set mine at 44/46 hot. (ContiSport 18" 235/255's)
TC
ETA: When I first got mine, it had been sitting in the cold for a few weeks and I got a warning for low pressure. I believe the door panel says 40/42 cold
Old Mar 20, 2016 | 11:10 AM
Mort's Avatar
The gas door says 41 front and rear cold with a medium load on my 2012 and 18" wheels. Is it not advisable to go up a couple of pounds on 19s?
beaststunt's Avatar
09 c63
I went with 40 all around seems perfect ,light went out didn't realize the tire rim setup I ordered only had 27 front and rear
Old Mar 20, 2016 | 12:11 PM
CarHopper's Avatar
E63S | X5
Originally Posted by Mazspeed
Too high.
K.
Old Mar 20, 2016 | 01:43 PM
kukimonsta's Avatar
c63 p31
Should it be 44/46 hot? Or cold?
Old Mar 20, 2016 | 05:43 PM
Mort's Avatar
Tire pressure should always be done cold. If it is not possible to do it cold you should set it and check it later when it is cold. Best thing is probably first thing in the morning.
Old Mar 22, 2016 | 09:41 AM
Dogtag114's Avatar
2009 c63
I actually go 38 all around and check often... on PSS.
On the PZeros, I followed factory pressures and wore out the middles badly in 7k miles.
Old Mar 22, 2016 | 10:38 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I do 42 all around.
Old Mar 22, 2016 | 10:42 AM
Phil_T's Avatar
C63 AMG Saloon
In UK inside fuel cap says 38f 43r
Old Mar 22, 2016 | 06:27 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I like 38/40 cold
Old Mar 24, 2016 | 02:16 PM
Girard@ACGautomotive's Avatar
a car
Dang you guys run them high. ~32 psi front and rear on mine. My back can't handle much more lol.
Old Mar 24, 2016 | 02:30 PM
kukimonsta's Avatar
c63 p31
I'm confused as to why fuel cap states different numbers than the door.
What's the ideal air pressure for street with occasional spirited mountain driving?
Is lower pressure for comfort only and higher pressure for cornering? I know with drag races the lower pressure in the rear is ideal.
I also noticed fuel cap stating 93 even though in Cali there's only 91
