C63 AMG (W204) 2008 - 2015
Secondary Cats and Resonator delete DID SOMETHING BAD....seemingly
Old Mar 23, 2016 | 01:28 PM
Dally's Avatar
C63 Coupe
Like I said, SEEMINGLY, after the res and 2nd cat cut and replace with a stainless X pipe and tubes its loud...ya, that's the good part.
and it never did the bad part before this cut and replace...
The BAD part is, hot or cold, driven hard or soft...completely at random for no reason I can think of it intermittently doesn't have half of the snappy rev it can and should at all times, when being revved in idle.
Other times, it does. It snappily revs and sounds like a beast on fire.
But, it completely unpredictably doesn't at times...Its almost as if it just simply doesn't respond for a second or two to punching the gas pedal...or it simply hesitates and then climbs the revs really slowly and weakly.
The needle jumps a millimeter or so up and down and you can feel the car shake a little from time to time as well...
What I can do however is rev the snot out of it, till it seemingly realizes its a C63 and then gets back to its normal snappy revs like we all love.
What in the ...?
No other mods, no chips, no filters, nothing...
30k kms on it...oil changed 4k ago...NO CEL, no other issues.
Thoughts?
Old Mar 23, 2016 | 02:02 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Could it be a leak? You could always take it back to the shop and ask them to run through it to makes sure everything is sealed up.
Also reset your ECU.
The procedure to reset the ECU is as follows:
1. Turn the ignition key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 2 minutes, the ECU is then reset.
5. ECU is now reset and you are ready to get new rear tires.
The ECU reset procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
Read more: Easiest way to reset my ECU
Old Mar 23, 2016 | 02:28 PM
Dally's Avatar
C63 Coupe
I figured the same thing. I was thinking it seems like the car is having a hard time matching the fuel to the air if the pipes are hot and swelled and sealed or cold and sealed or vice versa... but then again, its very random and hot or cold so I'm stumped.
I think ill try the ecu reset...problem is I have keyless push start button...
Old Mar 23, 2016 | 02:37 PM
Shadykit's Avatar
C63
You can always pull the start button out to use your key. It pops right out
Old Mar 23, 2016 | 02:46 PM
Dally's Avatar
C63 Coupe
Geesus...learn something new everyday
Cheers fellas, ill let ya know.
Old Mar 23, 2016 | 02:58 PM
Glbaraban's Avatar
C63 2012
Hey, I got the same issue. let me know if that helps
Old Mar 23, 2016 | 03:03 PM
Dally's Avatar
C63 Coupe
oh...interesting...is that after you had the 2nd cat and res cut and replaced with x pipe as well?
I'm going to reset it right now then rip it...brb
Old Mar 23, 2016 | 03:08 PM
Glbaraban's Avatar
C63 2012
I bought a car with x-pipe. I know it was welded not good so I may have a leak somewhere.
Going to delete resonator and to check for the leaks again.
After the tune - nothing has changed.
Old Mar 23, 2016 | 03:28 PM
Dally's Avatar
C63 Coupe
well that was interesting...
I reset it twice to be sure.
Revved it, change...still soft baby lamb revs...
Then ripped it tim hortons and its definitely faster...snappier, arrogant and reminded me of why I bought this car in the first place...it put that smile back on my face.
Then while in the drive thru line for coffee, considering a chocolate glazed tim bit to match the one now fresh in my shorts, I revved it again, hoping for the anger...
and got baby lamb again...
pissed I didn't get the tim bit but got the coffee and ripped it away...again, reminding me of the power of the C63's....
thinkin to myself maybe its just me..maybe its just my ears...maybe I'm not as intuitive to my cars sounds and blips and gurgles as I'd like to think I am...I parked it.
Then revved it again and it snapped at me like I remembered...exactly like... vindicating that I DO in fact know my car/cars and this is an issue...
but still left me at square one...post one...same issue...sigh
what in the hell is going on here gentlemen....
Old Mar 23, 2016 | 03:33 PM
Glbaraban's Avatar
C63 2012
do you feel a power loss, or just noise difference?
Old Mar 23, 2016 | 03:38 PM
Dally's Avatar
C63 Coupe
When in park only...and revving it, power loss and noise difference...big time noise difference, feels less powerful.
Driving it, especially after the reset just now, damn...no loss in power, if not more.
Old Mar 23, 2016 | 03:42 PM
Glbaraban's Avatar
C63 2012
I thought I was the only one... Ok, we need to check weldings.
Maybe someone else on the forum will help.
Old Mar 23, 2016 | 03:55 PM
Dally's Avatar
C63 Coupe
and here I thought I WAS the only one...
LOL
We do...and then shaddapp all the people who've said...I CAN'T be a leak...a leak wouldn't do that...
we'll see wont we...
when you goin?
Old Mar 23, 2016 | 04:44 PM
INS1GNIA's Avatar
'13 C63 AMG P31
What mode are you using/driving in, C/S/S+/M? If you are revving it in C mode, I can understand the difference in tone. Also the more aggressive and consistently you drive in S,S+,M the more the car adapts to that type of driving. Also lower your rear seats, you'll be able to hear the exhaust note better .
Old Mar 23, 2016 | 04:49 PM
tpliquid's Avatar
too poor now
oh i didnt know c would make it quietier
Old Mar 23, 2016 | 04:52 PM
Dally's Avatar
C63 Coupe
Forgot to mention that actually, yes tested in all modes a few times and its the same across the board for that 'testing session'
Its been sitting for a couple hours now...I bet I go outside and fire it up and its nasty...meaning lovely.
Morning starts are always eye opening ear cleaning. But by the time I get to work, c, s, s plus or M ...shes a baby lamb during revving.
I got a MB scanner going on it tomorrow without cel's but apparently the logfiles will show something if it doesn't throw a cel.
thanks gents.
Old Mar 23, 2016 | 04:54 PM
Dally's Avatar
C63 Coupe
my seats are sunk flat...im 6' 4 lol and I drive with the window down in minus 20 to hear it lol
ill try ripping it in S plus all the way to the mall then test it when I get there...update all later
Old Mar 23, 2016 | 05:01 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Haha, yea I'm sure the fit is a bit tight.
A good video for reference on sound:
<iframe width="560" height="315" src="https://www.youtube.com/embed/iK2DILwmcuQ" frameborder="0" allowfullscreen></iframe>
Old Mar 23, 2016 | 06:24 PM
ArmoE55's Avatar
2006 E55
Is every C63 able to lower the rear seats? I'm very new to the C63 but I couldn't find how to lower my rear seats, I tried every trick and looked everywhere.
I don't think my car is able to lower the rear seats ... ? Thank you.
Old Mar 23, 2016 | 06:39 PM
Eric ATP's Avatar
2012 C63 P31 black/black
Do u have an owners manual? You can buy one on eBay pretty cheap.
Look in ur trunk. You will see the rear seat release there.
Old Mar 23, 2016 | 06:51 PM
CPD SLK's Avatar
2009 C63 AMG
A leak or maybe if the new piping is hitting the body underneath maybe it is pulling timing because of knock? I have the resonator delete but not the 2ndary pipes...that's next!
Old Mar 23, 2016 | 08:21 PM
Blake_von_Texas's Avatar
C63 AMG
I have experienced the described "sluggish" rev in park only once and it was the day that I deleted the secondary cats. I personally believe it has the do with the difference in exhaust pressure? I suppose its possible that the ECU isn't compensating properly when the motor has no load on it.
Old Mar 23, 2016 | 10:25 PM
ArmoE55's Avatar
2006 E55
Yes, I have an owner's manual and read it thoroughly. The OM has two handles pictured in the trunk to release the backseats to fold them forward and expose the trunk. However, my car does not have the release handles in the trunk - that's why I asked if ALL C63s can fold the seats down - or maybe there is another way to do it? I looked all through the trunk and also went inside the car - nothing to fold the seats down.
Any thoughts? Thank you.
OP - sorry for the thread hijack!
Old Mar 23, 2016 | 11:40 PM
Dally's Avatar
C63 Coupe
Watch "2nd cats cut no res replaced with ss X pipe" on YouTube
And then this...
She was healthy above... Then slowly.. Surely it's worsened
Like here in C mode
Watch "Res cat cut but... Somethings up" on YouTube
Watch "Res cat cut xpipe" on YouTube
Old Mar 24, 2016 | 03:56 PM
Glbaraban's Avatar
C63 2012
any updates?
