Front end knocking sound at slow speed?
I have an 09' C63 with 25K miles which I purchased back in December last year (car had 23K miles back then). Recently, the front suspension area started to develop faint knocking noises on both sides of the car. The sound is quite similar to loose sway bar end links but at much quieter volumn. The noise occurs mostly when hitting small bumps or rough roads at slow speed but sometimes I could hear this at up to 45mph if there are sharp bumps or joints on the freeways. Going over a smooth speed bump doesn't trigger the sound.
I already changed out the end links but it did not fix the problem. The other suspension parts and bushings are still tight and looking brand new.
My other mechanic is suggesting that it could be coming from the struts or the strut mount bearings. Do worn out struts make knocking sounds? I read some of the older threads here also suggesting that this could be from worn out strut mount bearings, but I would love to get this fixed in one take. Parts for the C63 are special order only from where I live and cost about 40% higher than those in EU and states.
Thanks in advance.
Mark
Thanks in advance.
Mark
Definitely sounds like worn strut mount bearings.
What you described is a classic case of a bad bearings. Is the car lowered?
Is it only sound? Or are there any other symptoms such as vibration etc?
If it is just sound it sounds like the struts to me
I have one more question to ask you guys since I'll be ordering the parts soon. Is it only the bearings that usually needed replacements, or the strut mount top hats themselves are worn items as well? Also, are these parts shared with the rest of W204 C-Classes or are they C63's specific? Thanks
I have a question too. I bought my car with a bilstein coilover kit installed and I am also having the knocking sound at low speeds (right front). Question is will it use stock strut bearings or would the coilover kit have its own strut bearings. Not very knowledgeable about coilover kits.
It could be either. The B16,PSS10 48-141147 appears to use the stock top hats and the clubsport kit 48-229333 uses camber adjustable top plates. Looks like if your rear shocks have a yellow body the kit is the B16 and if they are silver the kit is a clubsport.
http://www.tdotperformance.ca/2012-m...ing-kits?pl=1&
id check the actual sway bar.. i just did my end links and shortly after i heard this rattle... the bolt and bushing started to walk in the actual sway bar... i just put the bushing(both bushings were fine) in place and used a tq wrench(like 100nm which is like 80lb) to tighten the bolt on the sway bar..double check that number tho
my reasoning for using the term in this instance is because when doing sway bar end links... you dont touch the sway bar at all nor its bolts... yet somehow the bolt found its way loose which also caused the bushing to move(hence why i used the term walk) people probably use other terms as there is no right or wrong phrase just what i chose to use..
so basically after i changed my sway bar end links i dropped the car off the jack stands and drove to test the steering in that moment i heard this (clunking,Rattle,etc etc) that ive never heard before when driving over bumps,dips,etc etc... it drove me nuts.. i checked everything i touched prior plus what ive read others suggested it could be.. it was none of those things until i jacked the car up again and shook or turned the wheels in an aggresive manner which when i noticed it was my sway bar itself that became loose(how i dont know) guess it just one of those things..checked the bushings and sat them in its correct place tighten the bolts to spec and Voila!! no more rattle shakes clunking or any binding when going over dips bumps potholes or whatever... sometimes bolts find their way loose how i dont know but just know i dont know hear that rattle... which is why is y i suggested checking that out as well
The way they built these cars are amazing!!! if u check it out yourself youll know what i mean..
such as there are to points u can do your sway bar end links(where the top bolt will go it can bolt in its original position or theres another hole to the left or in front depending on what angle youre lookin at it) id assume its for making turning tighter im not sure & theres sensors near the sway bar that id assume has something to do with the suspension settings that measures or keeps the car from dipping when going into a turn at speeds(im not a tech so i dont know for sure) but these cars are def over engineered and i love finding out new stuff i wouldve never known was there if i didnt try to tackle things my self....
Such as the intelligent system head lights(another story) but taking them apart($1600 assembly from MB talk about tax,ballast is $500 the bulb is high number too and i didnt even as what the lil black module cost to make these suckers move) was intimidating but cool...
back to the topic try checkin sway bar too is all im suggesting
shaun.barnard (12-11-2016)
Replaced them with Mahle aftermarket links. The old links you could grab the thread of a ball joint with two fingers and bounce the whole link up and down on any ball thread. Well the links were in the car for 8 years so I would suppose they needed replacing soon.
No noises now and steering more direct and suspension firmer.
Thanks man! Can you post a link to the new parts you got?
Sorry Chris, only see your post now, don't think the link will help you as it is a South African company that imports OE German parts for all German cars here but the brand is Mahle
Heres some info about them:
https://en.wikipedia.org/wiki/Mahle_GmbH
And here is their website:
http://www.mahle.com/mahle/en/
I'm experiencing a similar problem - faint knocking sound at slow speeds.
i had my strut mount bearings changed (I decided not to change the strut hats as they seem not to be a wear item), also changed the stabilizer end links.
The sound is still there unfortunately.
Two different dealerships checked my suspension and failed to locate the problem, giving wrong advice. One of them even told me to change my front shocks. I decided to check them on MAHA shock absorber and suspension testing machine. The test showed zero wear of suspension components.
Having read this thread I need to double check the bolts of the sway bar mounts. It's either that or the steel strut mount hats.
Checked the sway bar bushes and they looked fine and in their place then felt the end links and they were so worn you could wiggle them and twist them from side to side easily. Jacked up the car and couldn't wiggle the wheels from left to right but they had play when I wiggled them from top to bottom.
Thanks in advance.
Mark
Thanks in advance.
Mark
My experience, I have been battling this same clunking issue for months. Change my strut bearings and still experienced the clunk metallic noise at low speed and high speed over sharp bump especially on the driver side. Car drives fine. Indi shops blamed this on my KW V3 and advised I might have a bad front left strut. Checked my entire suspension and no play what so ever. I gave up and took it to a dealer that I have a relationship with. Bam! caused was my engine mount and tranny mount collapsed. Weird is that it never exhibited any typical bad engine mount behavior (leak, vibration, flexing, etc.). No more noise, but they raped me pretty bad on the labor.
