Brake cooling ducts and modified front bumper
Last question. So should I be using the OE caliper bolts to put it back together, or do I need to order more of yours? The RB bolts supplied with the BBK (72mm - 12mm head, no washer, 60mm shank) are significantly shorter than the OE bolts (85mm - 12mm head, washer, 73mm shank). The RB bolts probably threaded just a bit more than halfway into your adapter, they did not come close to bottoming. The OE bolts may just barely bottom out in the adapter before reaching proper torque on the caliper. Is there a length inbetween you’d recommend? Thanks.
https://mbworld.org/forums/c63-amg-w...coilovers.html
Our bolts are standard cap bolts = same as Porsches' OE caliper bolts (w/o washers).
Caliper bolts can be used at users' own discretion but what we included in the kit is based on good engineering practice. The bolt head (standard) usually is normally not account for the bolt length. eg. 70mm bolts refers to shank length only.
So are you saying, yes I should be using 70mm bolts there?
The OEM bolts are 72mm with a 2mm washer.
The RB BBK bolts are 60mm no washer.
The thread depth of the caliper adapter is 26mm.
If you're saying that the caliper depth is 44mm, and since the adapter depth is 26mm, then shouldn’t I be using the OEM 72mm bolts w/ 2mm washers, which would use all adapter thread leaving zero space, rather than the 60mm RB BBK bolts which would only thread 16mm into the 26mm adapter leaving 10mm of unused thread?
OEM Bolts: 72-2-44-26=26mm insertion into adapter with 0mm unused adapter thread
RB BBK Bolts: 60-44-26=16mm insertion into adapter with 10mm unused adapter thread
Sorry for all the back and forth, just want to make sure I’m using the correct hardware.
Also these cannons (brake duct intakes) for the front grill. 5” OD to 3” hose adapter.
One other thing. My Goodridge rear brake lines are a little short and there’s tension on the fittings I don’t like. Have reached out to see if they can make me a set 1-2” longer stay tuned.
Most of my parts are in and got the passenger side apart today. Should be all downhill now.
Quick picture of the new dust shield and rotor. You can’t really see it in the pic, but that duct is pointing right at the inner hub area, which will pick up the cool air with the rotor vanes. You want it pointing here rather than a spot on the rotor itself which won’t be very effective.
The X204 platform never had the AMG treatment, so there isnt much information about retrofits or brake lines length. I tried a C63 kit first and it was too short, and then I place an order for C63 front only, but in special notes I said I wanted it minimum for 600mm length or something and Goodridge obliged.
I ended up finding brake length information for various Mercedes and I now I got Front W211 for rear calipers and that (C63) custom stainless length front.
I also ordered the ML front hose because it has a rubber bumper with the W211 kit (not installed yet). Also the goodridge copper crush washers are amazing quality.
After
I’m pretty sure I can just plug the one hose off the pump circled above. Will make EGR blockoff plates some other time when I have more patience to remove the entire system with hoses etc. Taking the pump out gives me the room I need.
Direct shot through.... almost. I was going to shoot through this gap below, but it’ll route dangerously close to the alternator and belt. Even crushed down and zip tied I don’t like it. FML. A 2” hose here would be easier...
So I may have to rethink using a 3” hose as it’s just not going to get through there. This is about the best I can do with 3” hose, and I don’t think it will work once the tire is on and cranked right.
More trial and more error. Sigh.
And with a wheel on.... I’m tempted to say that might just work. I’ll cover the part of the duct that might come in contact with the tire on full lock with Kevlar felt tape.
On an unrelated note, it’s nice to see a wheel back on the car after 6 months. Have a new set of PSC2’s in the mail (hey they were on sale). Really going to push to get it all done in the next week.
I look forward to seeing more of your progress as you give me ideas about things you upgraded on your car so I can use your ideas to copy or R&D to upgrade my car. Although doubt I'll ever track it, just hard street driven.
Lastly, when you do the racing brake caliper rebuild kit which you have done. And getting rid of the hats on the pistons with the new ones you can now run GTR pads which will give you a lot more compound options and without doing research I'll bet are a bit cheaper. Now the only thing is the pad is NOT notched for the wear sensor other than that they are I believe 4mm thicker, cheaper price, and more compounds offered. Just a bit of info if you didnt already know, as I plan to rebuild mine and get them repowdercoated as well.
I was already running the thicker “GT-R” pads. Carbotech XP12. No wear sensors (they’re zip tied to the struts) and you have to drill out the caliper pin holes too.
They actually fit fine on calipers with piston hats. You just have to get the pistons completely pushed in, then lube up the pad backing plate liberally with the purple ceramic Permatex, and they’ll slide in. I even got shims in there too. It was a very tight fit.
These new pistons made made it easier to install the new set of front pads for sure though.
Three years ago thats exactly where I said I was going to punch through. Looks like it might even work...
First plug the outlet tube from the secondary air injection pump. Also had to drill out a bunch of rivets to remove the pump bracket.
44O scoop duct needs to be trimmed
This is where a 3” duct has to come through
Good shot of how the duct has to go under one of the oil lines for the 44O cooler. Anything sharp or might rub gets covered with Kevlar felt tape.
Tucked against the body, secured with zipties and with enough excess for wheel turning.
Passenger side done with modified duct/scoop thing.
Starting to look like a car again.
Don't appear to have any leaks. On full lock the drivers side duct is rubbing on the tire FML. Need to figure that out when I have more patience.
Next challenge is getting it out of the garage and up the ramp. I jacked the KWs height all the way up in front, still don’t think it’s enough. Next project is to either get a small ramp made to cut the angle or make the front bumper quick-release. Getting closer...
Impressive work either way. nice mod!
I was just about to start the brake cooling project. Going with the upgraded Black series kit from RB to begin with. Have the 44O installed so I will probably face the same problem that Jim has in trying to squeeze things in.
I have the BS front bumper so saves me the modifications that Jim had to do (hats off this his patience)
With the 44O Kit I had a lot of space in front but, I under up installing a custom tranny cooling line with a pump connected to the weistec pan.
My only concern is that I think at complete lock, the not so flexible 3inch silicon pipe may rub on a full lock.
@BLKROKT did you get Around solving this issue ?
I was just going through the Porsche design and it looks like it's just a simple channel that hits the rotors and deflects.
The design that I saw on your picture actually hits the brakes with air perpendicular to it and in line with the steering rotational movement
Point here is that at high speeds the air velocity through the 3 inch ducts can tend to cause stability issues specifically on long straights. This is plain physics and may need looking into as there is no way that the air channel on both sides will have balanced pressures
Just do a straight pull and see if you are fighting with the steering to keep it straight
I wouldnt be surprised that this may end up in some stability issue
Just my two bits, but could be wrong completely if the air pressure is negligible on the brake
Another interesting revelation - (true or BS is to be determined). Was speaking to a German tuner who claimed that a direct ECU benched tune for the c63 W204 gives access to functions that otherwise are not available via OBD. It specifically addresses the gear shift lag is what I was told. I currently run a EC V7, but haven’t found it to be very aggressive
any thoughts ?
See the "Seal Plates" section in the below link.
https://nasaspeed.news/tech/brakes/p...wer-lap-times/
And I already tried using the Porsche 996 GT3 Cup brake ducts. Insufficient for our 1000lb heavier cars.
