Brake cooling ducts and modified front bumper
I have already pruchased the 390mm Black Series brakes, but still want air cooling.
So I am interested in air brake ducts as well, and I'm very surprised almost nobody untill now has done this.
Well, almost nobody.. Some guys in Germany have done it with the pre-facelift bumper.
As you can see on the second photo, they have removed the foglights as air ducts.
I own a facelift C63, so I will need to do this with the updated bumper, like you.
C63 Brake cooling ducts by Hirsch tracksport (Germany)
Thanks for this
No, haven't done it yet. Have been working on a few other little things, busy at work, and waiting for my 44O kit to arrive(I was just notified today that it shipped out to me). So I'll tackle this pretty soon.
Just washed it and waiting for it to dry before fastening the new mesh.
507 DRL surrounds, DRLs, and OE mesh. Make me an offer of you want any of this.
I actually like the NACA vents on the Mansory S63, and am considering this also. One extracts air from the engine bay better (507), while these get more cool air into the engine bay. Unsure which one would be more effective. Or if I should install regular old louvers.
Regarding bumper - indeed looks great on the outside! Now you need to follow through with what is under the skin: The 44O oil cooler for example needs good ducting to be effective. You now have a bigger opening for it, but need to fabricate a duct that mates up with both the cooler and the bumper. Maybe the BS duct is a closer match and can be modified (details in my build thread). The cooler is the same, so the BS duct bolts right on.
Also for the brake ducts you really should try to get some sort of inlet nozzle/funnel, even if it is behind the mesh and does not use the entire mesh. A funnel and a smooth transition will increase flow a lot.
You are breaking ground, man!
Congratulations, you have found the one product in the Mansory catalog that is not so completely over the top and repulsive. I like those vents. And your front end looks BA-DASS.
