C63 AMG (W204) 2008 - 2015
Takada airbag recall
Old Jun 27, 2017 | 09:49 AM
  #51
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Originally Posted by Jasonoff
Doesn't the below apply to your 2013?
Transport Canada Recall # 2017145
AFAIK they're ALL affected...
No. 2017145 only affected 4 units as compared o 2017017 which affected 6370 or 2016158 which affected 73000.
I am realistic. I expect that as my car ages it will get on the list but it will likely be 2023 unless DB decides to be proactive and once caught up - if they ever do get caught up - will change it voluntarily.
There are no recalls on my car that I or my Service Manager can find.
Old Jun 28, 2017 | 10:06 PM
  #52
bhamg's Avatar
C63 AMG
Originally Posted by KrisKeeney
guys: I found this MB site to enter VIN to find out if your car is affected by the recall: https://www.mbusa.com/mercedes/recall
thanks
Kris Keeney
According to this MBUSA site:
Zone A (CA, TX, lower SE states):
States with greater temperature cycling and absolute humidity. Time in service until significant propellant degradation may occur is projected at between 6‑9 years.
We may yet see an explosion - pun intended - in the numbers of airbag-related injuries. I did not know the window had widened as early as 2014.
Old Jun 29, 2017 | 06:11 AM
  #53
Phil_T's Avatar
C63 AMG Saloon
Not heard anything about this in the UK but saw about it on the news today, The link from which one of you provided means I should be fine right? 2013 c63 amg.
The link said c class to 2014 but in brackets said only effected c63 upto 2012?
Also pretty sure on mine if its just the passenger airbag you can turn it off by inserting the drivers key into the dash near the glovebox?
Old Jun 29, 2017 | 12:05 PM
  #54
No. Each market is different. e.g. in Canada Transport Canada lists only C class and as of yesterday the 2013 were not yet on the list.
Check here:
https://www.gov.uk/check-if-a-vehicle-has-been-recalled
Old Jul 20, 2017 | 06:46 PM
  #55
AMG3.2's Avatar
C63 AMG, P30
Just called a dealership in the SF Bay Area. They're still waiting on parts. Don't really like the idea of driving around with an explosive in my face...
Old Jul 20, 2017 | 07:45 PM
  #56
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
Pretty much the same every where they say wait until you get another notice in the mail.
Old Jul 20, 2017 | 07:49 PM
  #57
MBNRG's Avatar
Do the Pre-FLs have both Driver & Passenger Air Bags affected in the Recall?
My 2012 FL only states the Passenger side is affected.
Or is it only a matter of time before they announce recall of both Driver & Passenger for FLs?
If so inclined, one can easily disconnect the seat wiring harness underneath on the affected side, thereby preventing operation of that airbag (i think), but one has to carefully weigh the risk/benefit of this against a possible faulty airbag deployment. . .
Old Jul 20, 2017 | 07:51 PM
  #58
C SEXY 3's Avatar
If so inclined, one can easily disconnect the seat wiring harness underneath on the affected side, thereby causing non-operation of that airbag (i think), but one has to carefully weigh the risk/benefit of this against a possible faulty airbag deployment. . .
I actually think it's the other way around issue of the bags not going off in case of a crash.
Old Jul 20, 2017 | 07:58 PM
  #59
MBNRG's Avatar
It would seem from below, taken verbatim from my Recall notice when checking my 2012 VIN that it is for a dangerous rupture of the inflator:
SUMMARY Certain Mercedes-Benz vehicles are equipped with passenger-side front airbags provided by the supplier TK Holdings Inc. ("Takata"). On January 3, 2017 Takata filed another Defect Information Report with NHTSA announcing a potential defect in some of the subject inflators. Based upon Takata's information to date, "Takata is not aware of any test ruptures in ballistic testing of returned inflators in the designated categories and model years or confirmed field incidents of the subject non-desiccated ammonium nitrate inflators other than those already under recall as detailed in prior defect information reports. Out of an abundance of caution, however, Takata is filing this report in cooperation with NHTSA to promote public safety.
CONSEQUENCE
According to Takata, activation of a non-desiccated ammonium nitrate inflator with degraded propellant may result in an inflator rupture. An inflator rupture may cause metal fragments to pass through the air bag and into the vehicle interior at high speed, which may result in injury or death to vehicle occupants.
To clarify, I suggested one may consider disconnecting seat harness underneath seat to prevent deployment of affected airbag and hence avoid any dangerous inflator rupture
Old Jul 20, 2017 | 08:02 PM
  #60
C SEXY 3's Avatar
CONSEQUENCE
Hmmm I must have read some other notice.
Old Jul 20, 2017 | 08:34 PM
  #61
bhamg's Avatar
C63 AMG
I spoke to my dealer and asked to have the front airbags disconnected. They flatly said "no" due to the airbags being part of an integrated safety system, so therefore liability issues were involved. I'm thinking that I should ask for a rental and have on record that I was turned down (presumably).
Old Jul 20, 2017 | 09:13 PM
  #62
It is an issue so location dependent.
If you want the bloody bags disconnected do it yourself or find an indy who will do it. We lived for decades without them. The key still is to stay in the vehicle so seat belts are a must but it is your choice in the end. Of course if there is an incident then you cannot sue them but whether you get a face full of scrapnel is very much a random thing.
My car (2013) is not yet on the recall list here in Canada.
Old Jul 21, 2017 | 12:53 PM
  #63
HBC350's Avatar
'18 C63A Cabriolet
Originally Posted by agentMurdoc
Friend of mine is also going through this recall with his acura. He told them he doesn't feel safe driving the car. It's endangering his passengers/family. They gave him a rental car. Catch is he has to park his affected car at home and cannot drive it (mileage is recorded). He's had a rental for like a month now. Someone he knows that did it too has had their rental for 3 months now. Something to thing about. Keep the mileage low on all your cars and beat the **** out of a rental. Not to mention saving money, by using 87 octane!
Honda is getting some replacement airbags and putting them in. My daughter's 2010 Accord was fixed in February after I called the dealer and told them I need something to drive while I wait for parts. Voila! "We have parts for your car."
Old Jul 21, 2017 | 08:30 PM
  #64
BadCompany's Avatar
2014 C63 AMG Edition 507 coupe
Lots of manufacturers have been getting replacement parts and installing for a while now. There is just a huge wait for manufacturing, so the dealers that are replacing are only getting small batches of parts. I waited for nearly a year to have the passenger bag done in my ISF. Waiting and waiting - and I live in the "highest risk" zone because of the year around heat and humidity. When Lexus finally approved it back in March, I called the only Hawaii dealer and was told that Lexus hadn't started the recall phase for my car and I was wrong. After explaining they were wrong and telling them the technical bulletin number, the service adviser said, "Oh... let me go check..." Voila. Parts were there and they fixed my car two days later. It was later disclosed to me that there was a "recall list" and they were prioritizing cars bought from the dealership (and since mine wasn't...).
Anyway, the solution from Lexus to any concern about it going off was for passengers to not ride in the front...
Old Jul 24, 2017 | 11:51 AM
  #65
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
http://www.autoblog.com/2017/07/24/t...-shrapnel-neck
Old Jul 24, 2017 | 12:20 PM
  #66
AMG3.2's Avatar
C63 AMG, P30
This is why I'm upgrading to a 2012+ airbag. From everything I can find so far, those don't look to be recalled.
Old Jul 24, 2017 | 12:33 PM
  #67
chrisridebike8's Avatar
'10 C63
according to the MB website for the recall, the passenger airbag is affected too. I guess if I swapped to a FL wheel or even a w205 wheel, my ball would be in the fairway
Old Jul 24, 2017 | 12:40 PM
  #68
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...eng&rn=2016158
Originally Posted by Transport Canada Recall # 2016158
On certain vehicles, the driver frontal airbag inflator could produce excessive internal pressure during airbag deployment. Increased pressure may cause the inflator to rupture, which could allow fragments to be propelled toward vehicle occupants, increasing the risk of injury. This could also damage the airbag module, which could prevent proper deployment. Failure of the airbag to fully deploy during a crash (where deployment is warranted) could increase the risk of personal injury to the seat occupant. Correction: Dealers will replace the front driver air bag module.
What's with that "correction" in the details? Is it just a module replacement now?
Old Jul 24, 2017 | 12:41 PM
  #69
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I only received a recall notice for the passenger airbag.
Old Jul 24, 2017 | 12:55 PM
  #70
AMG3.2's Avatar
C63 AMG, P30
So does this mean:
1) PFL -- Steering wheel airbag affected. Whether it's the module or airbag itself is up in the air?
2) FL -- Steering wheel airbag not affected. Passenger airbag affected.
Old Jul 24, 2017 | 03:17 PM
  #71
MBNRG's Avatar
So does this mean:
I had asked a similar question above as well.
So far, what I can deduce:
1. PFL: The Driver's side is affected. Is this the Inflator, or the Module, that is affected?
Is the Passenger side affected too on PFL?
2. FL: Passenger side is affected. Both BLKROKT and I have FL 2012 models, and our recall states only Passenger is affected. This appears to be the Inflator.
Any other FL cars out there with possible Driver's side affected?
Old Jul 24, 2017 | 03:21 PM
  #72
MBNRG's Avatar
One can easily disconnect the seat wiring harness underneath on the affected side (I believe it is the yellow connector), thereby preventing operation of that airbag by triggering an SRS Airbag fault code light, but one has to carefully weigh the risk/benefit of this against a possible explosive shrapnel spreading airbag deployment. . .
Old Jul 24, 2017 | 03:37 PM
  #73
'10 C63
Yes, PFL driver and passenger airbags are affected. I checked the MB recall site. Not sure what is specifically affected but it makes them IEDs for your face...
Old Jul 24, 2017 | 03:42 PM
  #74
bhamg's Avatar
C63 AMG
Interesting differences. Both sides, complete airbag assembly:
Once parts are available customers will be sent a letter asking them to go to an authorized Mercedes Benz dealer who will replace the Driver side front airbag of the potentially affected vehicles. Recall Campaign 2016020003 Owners may contact Mercedes-Benz at 1-877-496-3691.
Old Jul 24, 2017 | 08:53 PM
  #75
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Lol!
