Those With Aftermarket Coilovers...
Has anyone else ran into this problem, I was really hoping I wouldn't need to add them on this car.
It looks like K-Mac's are the ones everyone suggests but I cant seem to find a website to buy them from.
What could be affected is caster, camber, and pulling as without alignment correction bolts, is not possible to fix.
Can you post your alignment specs?
Coilovers with aftermarket camber plates adjust front camber/caster only.
(K-Mac) - Stage 2 (Street/Race) P/N # 503016-2L
As 3.2 said, front toe can be adjusted with the factory tie rods and the rear toe has some adjustability.
Don't try to match factory toe settings unless you want to eat up the rear tires and there seems to be some directional "pulling" issues set from the factory. MB seems to have tried to compensate for it but seems to have mixed up some settings for LHD/RHD. (Hence why the some owners had some issues when installing H&R springs with factory alignment settings).
Ask your mechanic to set the front and rear toe to ~ 0 and go from there. They shouldn't have any issues doing that. Using some penetrating oil will help break it loose.
Contact Kevin Mcintyre @ K-Mac - sales@k-mac.com
Tell him David and Jim (Mort) referred you.
Theres math involved in all of this stuff so I don't really get it. I just know how to calculate percentages cos Im in commission sales lol.
I would love to post the alinement specs but the shop I went to threw the sheet out after they were done with my car (I was pretty pissed) My buddy in Orlando that owns a shop didn't really understand what they were saying about having trouble with the toe either.
I would not allow them to touch the car anymore and I would go to a shop that knows what they are doing.
Read through this thread, a couple of us, myself included, posted some pretty good info in there regarding the pull.
https://mbworld.org/forums/c63-amg-w...lls-right.html
If you're pulling, you'll need to install the factory alignment bolts to bring the control arms back in to spec. Caster and Camber being out of whack are causing your pull.
I've forgotten the specifics but read up in that thread.
It's supposed to be one of the top euro shops in Tampa too, pretty disappointing
I'll need two right?
Thanks again for the help guys, I'll let you know how I make out.
I've been to Florida (South Florida) a million times, but have never made it to Renntech. Always make it to Prestige Automotive though
