C63 AMG (W204) 2008 - 2015
Intake Manifold Gasket and PCV valve DIY
Old 05-30-2021, 10:39 AM
  #126
SoCalCL's Avatar
CL 63 AMG
Intake Manifold from a sprinter
Originally Posted by c63panda
If anyone needs pm me. Twenty for one, only two available. Repairing with a sleeve woulda worked but it just didn't feel right so I bought a used sprinter manifold (80$).
Do you have the part # for the sprinter manifold that fits our M156?
I could of definitely bought one of these tabs if you still have them of course.. just did a fix for this after snapping mine on removal.. Used a a bit of jb weld on bottom than a sleeve of aluminum to build a bridge from the Tab to the IM, wired them tight together and jb welded the top. Will see how this works, seems to be pretty strong but just in case a $80 IM manifold is a good price vs 300+ for used
Old 11-18-2021, 08:37 PM
  #127
tasteofpower's Avatar
2011 C63 AMG
WELP!
Might have to try to do this myself. Doesnt look to hard to replace a intake manifold...
Old 12-29-2021, 10:52 AM
  #128
Robbe's Avatar
W204 C63 Coupe Edition 1
My codes for a lean bank 1 turned out to be an injector stuck open.
Is logical when you think about it, an always open injector will cause a lot of misfiring, and then oxygen will not be used during a misfire, which the O2 sensor translates to lean mixture.
When in fact it is overly rich...
So if you have these codes, try checking the injectors first. A cheap cleaning set + an aerosol of cleaner + a 12V source will do the trick.
I did all this together with the gaskets and PCV pipe, but now doubt if those 2 were at fault.
Old 12-29-2021, 12:44 PM
  #129
Rovel's Avatar
2007 E63 Amg
I would definitely change the injectors rather than risking it. It’s an aged part.
Old 12-29-2021, 05:42 PM
  #130
chrisridebike8's Avatar
'10 C63
When I had a stuck injector, oil temp on the cluster would rapidly bounce all over the place. If you are changing the intake mani gasket and pcv, it’s a great time to do the injectors as well.
Old 12-30-2021, 05:06 AM
  #131
Robbe's Avatar
I already ordered new injectors, but strangely enough the parts situation in Europe is different to the USA.
There are no parts houses (not even in Germany!) where you can order parts. Yes some small venues have some parts, but unlike that other German brand from Bavaria, you can´t just order everything online with a third party seller.
So I found the injectors on Ebay in Latvia , or Lithania or one of those ex-Sovjet states that now are part of the European Union, I forgot which one. Should arrive with me in The Netherlands in 3 or 4 weeks.
The gaskets and PCV pipe and bolts were available through the official dealer, but I fear what they ask for 8 injectors...
Having cleaned the injectors will certainly work for the next 500 miles, so I am not worried.
Next project: oils smoke coming from the driver's side, after the intake gasket repair. Maybe old oil from the intake , dripped out when it was removed? Should stop within 100 miles I would think (just did like 15 ysterday)
Otherwise it will be a new valve cover gasket and valve adjuster gasket...
Old 01-06-2022, 10:31 PM
  #132
EMR2004's Avatar
2011 E63 AMG
Help
Any ideas on how I can get this damn bolt out. This job has turned into an absolute nightmare. Please help!!
The bolt sheared off. Totally oxidized inside. I couldn't get it out with my vampliers. Thinking about drilling it out... any ideas?
Old 01-06-2022, 10:52 PM
  #133
jonii's Avatar
E63s AMG Biturbo
drill a starting point with a diamond rotary bit to make a accurate center point. and from there drill it out.
Old 01-06-2022, 11:07 PM
  #134
Rovel's Avatar
2007 E63 Amg
Which bolt are you referring to?
Old 01-06-2022, 11:25 PM
  #135
EMR2004's Avatar
2011 E63 AMG
The T30 that holds the pcv to the intake manifold.
Old 01-06-2022, 11:26 PM
  #136
EMR2004's Avatar
2011 E63 AMG
a dremel diamond bit? Can you suggest one? I have been trying to drill using steel bits and it's not working. Planning to buy new bits tomorrow and cutting oil..
Old 01-07-2022, 07:26 AM
  #137
Robbe's Avatar
A simple diamond-dust covered spherical tip bit will work. But work slowly without much pushing, overheating the tip will ruin it.
Old 03-07-2024, 01:37 PM
  #138
wazc63's Avatar
2009 c63 amg
Does anyone know what those 4 plugs at the front of the intake manifold are called?
Old 03-12-2024, 08:09 PM
  #139
dattorob's Avatar
AMG C63 W204
one with red arrow is MAP sensor, not sure about the other three
Old 04-09-2024, 04:24 PM
  #140
w211E63_Sac's Avatar
2007 Mercedes E63 AMG
Help!!!
Please help
So, I followed all the steps, got to the throttle body adapter plate swapped as the old one had a hole in it. Transferred everything into the new plate. I did replace the engine crankcase vent valve as well. Put it all back together and the car is running very rough...
I have no idea what is going on. Below are the codes, I am getting....
Old 04-09-2024, 08:32 PM
  #141
latinskllz's Avatar
‘14 ML63, ‘11 E63, ‘05 M3
for everyone, remember to work on these bolts little by little just like Tasos Moschatos has mentioned.
unscrew a few quarter turns, screw a few 1/4 turns, unscrew, screw, and eventually bolt will come out cleanly.
Quick Reply: Intake Manifold Gasket and PCV valve DIY
