C63 AMG (W204) 2008 - 2015
2014 507 would not start!! Need service tech help!!
Old Aug 11, 2016 | 07:51 PM
JRHolt's Avatar
2024 GLE 63 S AMG SUV
Hey everyone,
Wanted to share my experience with everyone on here to see if anyone has had a similar issue like mine. Sorry in advance for the long post but I really need some help here if anyone has any experience with this issue.
On Monday August 8th I was at work and during my lunch break I had the car washed and then stopped at In-N-Out for a quick bite to eat.
When I went out to start my car to return to work the car would not start.
Here are the exact symptoms:
Walked up to the car with the fob in my pocket, grabbed the door handle to open the door and it opened normally. So the fob was properly detected by the car.
I have keyless go so I depressed the brake pedal and pushed the button and nothing happened at all. I then noticed that non of the lights on the gauges on the instrument panel were lit up. The center information screen was working and the radio would work but that was about it. After depressing the start button a few more times I got the message "Key not detected", or something to that effect.
I removed the push button for the keyless go and inserted the key, still no reaction from the gauges at all. I turn the key several times and got nothing.
I tried both the keyless go and the key several times and kept getting the same results.
I finally had to call Mercedes-Benz Roadside Assistance. They sent a tech out and he tried to to jump start it to see if it was a low battery but got the same results that I did. When he realized that, he call for the tow truck and told the representative that it was obviously an electrical issue and the car need to be towed to the Dealership.
It was late in the day so they were not going to touch it until the next day. They asked me to drop off the other key for the car the next morning and I did just that.
The car is still at the Dealership and the service advisor told me that for the last three days the car starts normally with both keys and that there are no codes stored for any faults. Of course without any codes or being able to replicate the issue they are not going to replace anything.
Tomorrow is Friday and if they still cannot find anything I am going to go pick it up.
If there are any Mercedes service technicians on here that could help me research this issue I would greatly appreciate it.
With the research I have done it sounds like the likely culprit is either the Ignition Module or one of the fuse boxes but I am not sure if they could have faulted and not left a code.
I did find one Service Bulletin for a "No Start" condition but it only covered 2012 and 2013 W204: LI54-15-P057.
If anyone has any more information I would be very grateful
Thank you for your time
Old Aug 11, 2016 | 08:04 PM
rohitC63's Avatar
C63 AMG
Mine did that last year, turns out to "jump start" the car you have to have it connected to another car for AT LEAST 5 minutes to get enough juice in the battery to start the monster.
Old Aug 11, 2016 | 08:07 PM
JRHolt's Avatar
rohitC63,
Thanks for the reply but there wasn't any apparent issue with low battery voltage. The next morning the car started just fine without any codes or issues
Old Aug 11, 2016 | 08:20 PM
realjones88's Avatar
2012 C63 P31 sedan
Did they put the car on a trickle charger at the dealership? If the battery voltage was low juicing it back up would fix that and could be why they can't create the issue.
Old Aug 11, 2016 | 08:21 PM
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
Hope you figure it out and its nothing major! i wonder if it was related to the wash and if water got on a sensor or anything...
Old Aug 11, 2016 | 08:30 PM
JRHolt's Avatar
Not that I am aware of. I will ask for more details when I speak to him tomorrow
I believe that if there was a low battery voltage detected that it would store a code. It did on my 2006 SLK55 so I would assume that it would on this car as well.
Old Aug 11, 2016 | 08:33 PM
JRHolt's Avatar
Thanks me too Yea I was thinking about the water issue as well but it was like 105 degrees that day in Dallas so I would think it would have dried out.
Also thought about the heat as a possible issue and maybe when it cooled down it worked fine?
I hope we can figure this one out, I do not want to get stranded somewhere in the middle of the night
Old Aug 12, 2016 | 12:45 AM
roadtalontsi's Avatar
10 C six trizzle
sounds like a steering lock. pretty unusual for a 2014. its usually a 08' 09' c-class problem.
Old Aug 12, 2016 | 08:31 AM
gforc3's Avatar
C63 Coupe
I've had this issue 4 times, steering lock and Eis need to be replaced. Last time they replaced my keys and the issue hasn't resurfaced yet... We will see.
Old Aug 12, 2016 | 08:54 AM
JRHolt's Avatar
Oh man!!! So there were not any fault codes on your car any of the 4 times it happened?? 😳
Old Aug 12, 2016 | 09:05 AM
AmgSeahawker's Avatar
08 clk63, 06 E55, 05 c55, 14 ml350, 98 pathfinder. Have owned cl55, s55, cls55, c230, cl500, cls500
Just worked on a car with same symptoms. No crank no start and no reaction from the cluster. Car had been towed in but by the time we got it the car was starting every time. Ended up being the EIS. Never had a code. Had to catch it in the act then performed EIS test and failed.
gforc3's Avatar
C63 Coupe
There were codes I can upload a picture of one of the service records if you want later today
Old Aug 12, 2016 | 09:16 AM
jmueller's Avatar
Jag F-Type V8
This happened to me once. Tried to start the car with and without keyless go, and no luck. I ended up walking away for about 10 minutes and then walked back up within range and the car started no problem with keyless go. I thought it was just a hiccup and luckily it hasn't resurfaced.
Old Aug 12, 2016 | 09:28 AM
gforc3's Avatar
C63 Coupe
Don't wanna be the bearer of bad news but in my experience it will resurface eventually. Get it fixed asap before you get stuck somewhere
Old Aug 12, 2016 | 12:37 PM
JRHolt's Avatar
Thank you very much for the information. Would it be possible to contact you directly to get more detailed information on how you got it to repeat the fault?
JRHolt's Avatar
That sounds great! You can upload it here or just email it to me through the forum if you wish.
Thank you
Old Aug 12, 2016 | 12:40 PM
JRHolt's Avatar
Wish I had been that lucky. I was stuck in an IN-N-Out parking lot for about 3 hours until the tow truck finally showed up and the car never did respond until the next morning
Old Aug 12, 2016 | 11:12 PM
I really didn't do anything special just started the car several times thru out the day until the problem occurred.
Old Aug 13, 2016 | 01:26 AM
finewayne's Avatar
C Class
lucky man
Old Aug 13, 2016 | 02:04 AM
VR38DETT's Avatar
2012 C63 Coupe
Not to derail the topic but mine did start a few times with no cluster reaction until a minute later. And that is an EIS issue?
Old Aug 13, 2016 | 01:23 PM
JRHolt's Avatar
Thanks! Hopefully if it happens again it will happen at home and I can connect my Xentry system and capture the failure code.
Maybe I should just bring the Xentry system with me everywhere I go
Old Aug 13, 2016 | 01:57 PM
If there is no codes You will have to go thru guided test of drive authorization in EIS control unit.
Old Aug 13, 2016 | 05:08 PM
nobbyv's Avatar
2016 Cardinal Red AMG C63 S
I have nothing to add other than good luck and I didn't know In-N-Out had made it to Texas.
Old Aug 13, 2016 | 08:13 PM
JRHolt's Avatar
Thank you for the guidance AmgSeahawker
Old Aug 14, 2016 | 12:14 AM
507OverBiturbo's Avatar
C63 507
Hey, hope you get this figured out without issue - would be interested in hearing how it's resolved.
