Aftermarket sway bars for C63?
Hi there! Somebody use the Aftermarket sway bars on your C63? Eibach makes bars only non AMG W204 models. Somebody makes tuned sway bars for C63 W204?
Received 2,849 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nope. Sway bars are pretty beefy. No need. Poly bushings would be nice though.
As far as I could tell, they wouldn't fit. Why do you think you need upgraded sway bars?
SPONSOR
2007 Mercedes E63 AMG
dunno about the C63, but as much as my E63 has well acting sized sway bars, i'd love to have beefier ones in form of size or hollow.
can't say there is no reason for them...everybody has a different driving style as well as prefers different characteristics. my Audi A4 has Hotchkis uprated RS4 sway bars...they're bigger than the RS4's sways and I'm running them at the 3rd stiffest setting. They're great, my Audi takes turns like a gokart now.
There are sway bars that fit the C63, i've been thinking about making an order for them. Some of the locals in China run sways, and they've had good experiences with them.
Everybody drives different/has different requirements and definitions on what is needed/not needed.
I may give them a shot to see if there's any noticeable difference.
I've changed my mind on this topic. Phil are you still checking the forum? Would be great to know any source for upgraded bars. I've looked at the Eibach unit for the regular C-class (28mm/21mm and 2-way adjustable vs 27mm/20mm stock C63), and they're a different shape. Although putting C63 bars on the other C-class models is a known mod, counterintuitively, it doesn't appear you can do it the other way around.
Well I'll be the guinea pig on these. Got a chance to see some actual detailed pictures of the Eibach sway bars (the pics I had seen were not actual as it turns out), and they look to be the same shape as the OE ones. Only 1mm difference in thickness for both F/R - which translates to 15% stiffer front and 20% rear - but they also come with poly bushings which is nice. Plus the front is 2-way adjustable. They're on the way, and I'll try putting them on when my car's back from the body shop and report back on the fitment etc.
BLKROKT (05-01-2017)
Thanks guys. Anything can be made to fit. Stay tuned.
Nice work BLK! Any links to where you bought them from?
BLKROKT (09-29-2018)
The following 2 users liked this post by BLKROKT:
chrisridebike8 (05-01-2017),
MBNRG (07-29-2017)
Also interested here on how it will end up. I remember I saw a shop here in China that seems to have made the eibach install on a C63, so I guess you'll be fine.
BLKROKT (05-03-2017)
Eibach sucks. 2 days after my order - remember I ordered with them because it showed "IN STOCK" - NOW they tell me it's on backorder. That's just insulting. So looks like June 30 now, if I keep the order. Will report back with any updates or alternative sources. I'll probably cancel and go through Tire Rack because they had it cheaper.
Did you actually speak to anyone who confirmed stock, or did it just show as in stock when you ordered online?
If someone confirmed, then they lied, and you should tell them to get bent.
However, if it just showed as in stock online, then it could just be a computer error.
BLKROKT (02-28-2018)
Talked to Eibach today. They said that they're working on upgrading their systems to prevent things like this from happening. Super. One helpful bit of info is that the bars likely fit the C63, it's just that they didn't have a car to test them on so they couldn't list them as fitting. So that's encouraging.
So I cancelled my order and placed one with Summit for $50 less. Still on the same timeline. Production should be done by June 30, and the bars will be drop-shipped directly to me sometime that first week of July. So now I wait.
Hmmmm. I'm sure due to liability issues that they would have to do it in-house. But it never hurts to ask. Will call the dude back tomorrow if I have time thanks.
Edit: Nevermind lol it's 2-way adjustable in the front.
