C63 AMG (W204) 2008 - 2015
M156 6.2l motors down on power
Old Dec 21, 2016 | 08:32 PM
  #51
Celicasaur's Avatar
W212 - E63 AMG
Originally Posted by thesaintusa
Reading the thread for the first time, this is what I would think as a problem, especially if the car otherwise runs fine.
Might be a good idea to sort out why you are 'down' on power instead of adding headers to the mix (although they would remove your primaries for that).
Alternatively, as you car gets amazing gas mileage, perhaps instead of limp mode, your car is in super economy mode without you knowing it.
If you have read this for the first time, how could you not have worked out that I've been trying to work out the reason for being down on power all this time
If anything I've been trying to hold off from fitting the headers until I'm satisfied that I've explored every other avenue.
I would agree that the fuel economy is a bit strange. But it also points to an exhaust restriction, thus the reason why the chambers don't need as much fuel as a car with a correctly or free-flowing exhaust system.
FWIW I'm not entirely convinced that a decat will solve my car issues entirely, as it doesn't explain why some people are down even without cats. We'll see how it goes I guess.
Old Dec 22, 2016 | 07:25 AM
  #52
sirius9's Avatar
W204 C63 saloon
Based on the MSL charts provided, it seems that your engine is down by about 40bhp using an 18% conversion of whp.
Not sure if this will help you or not, but my C63 was down by 20bhp pre tune and post tune, V5 Eurocharged map. This is despite a service and change of spark plugs etc etc. I was pretty cheesed off.
But then all was revealed when I had IPE headers installed and it made 552bhp on MSL's dyno and this was correlated with a slightly lower figure (as expected) on a Dyno Dynamics dyno. So, it seems that the headers on these M156 were restrictive and may affect each engine differently.
It could still be that once headers changed and cats delete (or sports cats installed), all may be resolved? which i sincerely hope so for you.
Old Dec 22, 2016 | 08:10 AM
  #53
chrisridebike8's Avatar
'10 C63
Omg. Another one of these?! So your car made the gains it was supposed to, meaning the post-tune dyno had enough gains over the baseline. That's all you can use for dyno numbers. For example, i made 380 whp baseline and then 425 whp tune only. If you made 370/415, then it's fine. You can't compare different cars on different dynos, only the gains on the same car and same dyno. So swtching to a different dyno and getting the numbers you want is worthless info without a baseline on that dyno too. That being said, when the OP was down 40 hp to similar cars ON THE SAME DYNO, he probably had a reason to believe he was down on power.
Bottom line: dynos only measure gains or are used for tuning.
Old Dec 22, 2016 | 09:08 AM
  #54
sirius9's Avatar
W204 C63 saloon
I am just trying to offer an opinion.
I agree that different dyno on different day gives different results.
What i was referring to was that post headers, bhp gain was around 50 rather than the expected 30-35. Which then conpensated for the presumably low figure on OEM headers.
Anyways, just hope OP has his sorted in the end.
Best of luck.
Old Dec 23, 2016 | 06:57 AM
  #55
Celicasaur's Avatar
W212 - E63 AMG
Finally unwrapped my headers after having them dormant for months on end. Many thanks to mr747 for his help ... the man is a legend
M156 6.2l motors down on power-20161222_113037_1482492816557_resized_zpsydg8dgkk.jpg
M156 6.2l motors down on power-20161222_113044_1482492820456_resized_zps9tbyekvi.jpg
3" outlet
M156 6.2l motors down on power-20161222_113114_1482492824041_resized_zpsslairzaz.jpg
Waiting on mandrel bends and x-pipe to arrive after xmas now. Hopefully have it all fitted in January and then I'll pop back for a retune.
Car is a little more enjoyable with the extra 20hp all over. Man, you lighter C class guys with strong power must be loving it!
Old Dec 23, 2016 | 07:17 AM
  #56
Vladds's Avatar
2010 C63 2019 GLA45
So what do you fuel over there, 98 RON?
Old Dec 23, 2016 | 08:21 PM
  #57
Celicasaur's Avatar
W212 - E63 AMG
Indeed sir, that's correct ^
Old Dec 23, 2016 | 11:04 PM
  #58
s.e.a.n.'s Avatar
2009 C63
Interested to see the gains from the decat and headers.
