How to confirm a headbolt issue?
My idle is a bit rough as I can feel slight vibrations inside the car, that has been the case for the past 6 months.
I have replaced the plugs already but that didn't help much. The old plugs looked clean and dry.
The fact that my coolant hasn't gone down makes me think it's an intermittent coolant level sensor. I just don't know why the idle is slightly rough, other than a bad coil. Performance feels the same. No smoke under WOT.
I don't have a software to diagnose anything with. I have left messages at both dealerships near me but still no response. I just want to get ideas on how else to diagnose and rule out head bolts stretching. Anything other than a compression test?
I spoke with a guy that owns a MB shop who had worked in the local MB service dept for 24 years. He said that if coolant gets in the oil there is usually bearing failure within 10k miles even if the bolts and gaskets are replaced because the coolant stays in the bearings. Not sure how true that is.
Any suggestions are very welcome, other than "take it to the dealer".
I also ordered this kit:
https://www.amazon.com/Lisle-75500-C...s=block+tester
I will also do a compression test.
If all results from all these tests are good then I will probably just take the car to a local shop that has done quite a few of the "one by one" bolt swaps on these engines and have them do it that way as preventative maintenance.
That tester you ordered will be good enough to let you know the state of your HG. You can also do a cooling system pressure test as well to be 100%.
I have an appointment scheduled to drop off the car at the dealership Thursday morning. The block tester kit arrives tomorrow and therefore I can do that test myself.
I was a bit discouraged by the service advisor I talked to at the dealership. He said that in the 15 years he's worked there they have never done any engine work on a C63. That has me a bit worried about the quality of work they will do if it gets to there. He said that these engines are bullet proof and he hasn't even heard of any having bolt problems. Anyways, the diagnostic will be $210. We will see what that will get me at the end but it sounded like they don't even know where to start diagnosing it.
If the coolant is dropping that means there must be a path to at least one of the cylinders from that reservoir, so it should detect it.
I just took this picture literally ten minutes ago. The car is pretty much cold at this point. You can see that the coolant is covering at least half an inch over the black area, I think it's actually more and it's just the angle. The message only appears in the morning so tomorrow morning before I start the car I will check the level first and then will see if the message appears. If it does then clearly this car is messing with me and my paranoia about bad head bolts.
I also added half a gallon of window washer fluid in the washer reservoir. I read somewhere that being low on washer fluid sometimes triggers the coolant message. That's pretty damn weird but I still topped it off. Who knows, the message might not show up tomorrow morning.
I am still replacing the bolts though, but it will be one by one and for a lot cheaper.
Yes, what you're saying makes sense to me now.
A quick update, this morning I checked the coolant level and it was exactly where it was yesterday, as shown in the picture. Yet I still got the low coolant message. Seems like it's just a bad sensor in the expansion reservoir. I will order a new reservoir today and see if it goes away. At least I am not loosing coolant, which is a huge relief. I still plan on replacing the head bolts after this scare but it will be at a shop that does it one by one for about $1k, instead of $5500 at the dealer where they remove the heads.
I will order a new overflow reservoir now and hopefully that will make the coolant message go away every morning.
On a possibly related note, I got a "Check oil next fill up" or something like that today while driving. Not sure why as my oil level was just perfect when I was checking my dipstick yesterday for any milky oil in the engine. I think this car is trying to make me paranoid and is playing some nasty tricks on me.
