C63 AMG (W204) 2008 - 2015
Misfires & Check Engine Light
Old Dec 15, 2016 | 07:12 PM
Jacked a c63's Avatar
2009 C63 AMG, 2013 CLS63 SAMG, FORD F350, BMW 750LI
I had the coils checked and they said all the coils are good.
Old Dec 15, 2016 | 07:13 PM
what does short/long term fuel trim mean?
How much did it cost you to replace your intake gasket?
Old Dec 15, 2016 | 08:26 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Has anyone recommended you change your primary O2s yet? You should...
IM gasket and bolts cost me ~30 bucks.
Old Dec 16, 2016 | 04:30 AM
I will definitely change my primary o2's and hopefully that will fix the problem! Thanks!
Old Dec 16, 2016 | 06:02 AM
CarHopper's Avatar
E63S | X5
You have a problem with your o2 sensors which is causing your misfires. Fix that and you should be good.
Old Dec 16, 2016 | 10:25 AM
  #32
chrisridebike8's Avatar
'10 C63
I forget what the dealer quoted me but it was somethinng stupid like $700 or maybe $900. Replaced the IM gaskets, bolts and pcv for like $140. Easy to do.
https://mbworld.org/forums/c63-amg-w...valve-diy.html
Old Dec 18, 2016 | 03:43 PM
  #33
Merc63's Avatar
C63 AMG
Did you just have the headers installed? If so, confirm the primary o2 sensors are connected to the correct exhaust streams. If they are crossed, it will do this after a bit of driving and the ECU is confused.
Headers will also fry the primary o2 sensors over time. These engines run closed loop, without proper o2 feedback engine will run like crap. How did the plugs look?
Old Dec 20, 2016 | 03:34 PM
  #34
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
If you had headers installed you should also have a tune to remove the CEL code from the o2 senors.
Old Dec 22, 2016 | 06:04 AM
  #35
I just had all my o2 sensors replaced and nothing has changed.
The dealership told first told me it was the sparks, then said coils, and then after i mentioned the o2 sensor to them because thats what everyone on the forums is telling me.. they were like "its most likely the o2 sensors" they changed them.. and nothing has changed.. they're charging me for everything and they can't figure out the problem. This is the second dealership I've been to that don't know what the problem is.
Old Dec 22, 2016 | 06:07 AM
  #36
I had my headers installed like almost two years ago.
The dealer told me to change the sparks because they needed to be changed and that it was causing the misfires and CEL and shaking, the dealer changed them... and problems still there... then they said its the coils... they changed those too.. and nothing changed.. then lastly everyone on forums said its the o2 sensors... changed those.. and nothing.. still the same problem...
I rather not tell the dealership anything else because they'll just tell me yea its probably that.. and charge me for the fourth time.. and solve nothing.
I don't know what else it could be
Old Dec 22, 2016 | 06:08 AM
  #37
I had headers installed about two years ago.. because of that i got CEL but then i got EC tune and they fixed everything.
BUT now idk what the issue is... and nobody seems to know .. the dealership is just guessing and taking my money.
Old Dec 22, 2016 | 08:49 AM
  #38
faz492's Avatar
e63 amg w212 6.3
I need some help please.
My C63 is having CEL and misfires.
At first the codes were P0300 301 303 304
I had all my spark plugs changed and reset the computer. The problem went away and the car drove fine for maybe 30 miles.
Now it has really rough idles and shakes really bad slowing down to a complete stop and accelerating from a stop. It threw similar codes just different ending numbers.
Anyone know what this problem is?
I have headers and midpipes and a tune.
my car did the same thing.... like u said spark plugs changed, ECU reset.. had the car towed back.... started it... shakey on idle switched itself off... now its not starting at all its not cranking over...
I've also been told it may be the Headbolt issue... :/
they are striping the engine apart in 2 weeks completely to find the problem.
I will get them to check the 02 sensors to see if it helps, also the Intake Manifold... :/.
Old Dec 22, 2016 | 06:29 PM
  #39
damn, don't say that about the headbolt. I'm hoping its not the headbolt because I don't have warranty and I've heard stories where they replace the headbolt but the dealer mechanics don't know what theyre doing so the cars engine comes out like **** afterwards.
Old Dec 22, 2016 | 08:34 PM
  #40
faz492's Avatar
e63 amg w212 6.3
I dont have warranty, But if it is the Headbolts you can get a camera remove the sparkplugs and check around there or some crap the dealership was telling me because they would find water/coolant etc.
I'm not trusting them 100% on this.
It could maybe be a valve spring from what a shop said to me..
But eitherway have to strip the motor apart to figure out.
Old Dec 23, 2016 | 05:07 AM
  #41
I'm hoping its something small and stupid thats causing the problem.
I've done just about everything they said could be the issue, but there hasn't been any difference in the cars condition. I think they already checked for leaks but found nothing.
I will bring up the valve spring to them and hopefully they don't charge me to fix the valve spring like everything else.
Thanks!
Old Dec 23, 2016 | 07:56 AM
  #42
faz492's Avatar
e63 amg w212 6.3
Thanks!
If my engine does need a rebuild then I'm going to add forged rods and pistons etc maybe...
Old Dec 24, 2016 | 06:19 AM
  #43
What are forged rods and pistons?
Mind me asking where you live? I'm in NY
Old Dec 24, 2016 | 07:38 AM
  #44
faz492's Avatar
e63 amg w212 6.3
pistons/rods which can withstand up to 1000hp and a harder beating if you want to supercharge your car in the future etc.
http://weistec.com/all/c/c-63/2012-2...internals.html
Old Dec 24, 2016 | 09:12 PM
  #45
Other than the headbolt should I change anything else?
I plan on keeping the car the way it is, already has headers/mids/catback and tune.
Old Dec 24, 2016 | 11:19 PM
  #46
faz492's Avatar
e63 amg w212 6.3
You should change your valve buckets to SLS ones atleast so you future proof the car.
Old Dec 25, 2016 | 04:43 AM
  #47
what are the valve buckets for? and what do you mean by future proof?
I saw them on weistec there were regular ones ones for 1k and then black series ones for 2k
Old Dec 25, 2016 | 05:28 AM
  #48
faz492's Avatar
e63 amg w212 6.3
M156 engines are known for the valve bucket issues so people upgrade their ones to the 999usd sls ones.
Quote from weistec:
By now many have heard of the issue of accelerated wear in the valvetrain of the M156 engine. The materials design of the valvetrain components results in repeated contact of soft metals with hard metals. Eventually this can result in premature wear of the valvetrain, degrading engine performance or even causing engine failure.
Many M156 valve buckets are prone to "bleed down" resulting in excessive valve lash during cold start up, commonly heard as a loud tapping noise until the engine fully reaches operating temperature. Excessive valve lash is a major contributor to accelerated valvetrain wear. The M159 engine, used in the SLS and SLS roadster, features valve buckets that are of an improved design. The M159 valve buckets feature an anti friction coating to reduce wear on the camshaft lobes. They also have an improved hydraulic system that will not "bleed down" like the M156 valve buckets. Installation of M159 valve buckets will help prevent any premature wear to your engine's valvetrain and make for a quieter engine on cold starts.
Key Features:
  • Anti Friction coating
  • Improved Hydraulic system
  • Direct Replacement for M156 Valve Buckets
Old Dec 25, 2016 | 05:48 AM
  #49
faz492's Avatar
e63 amg w212 6.3
Which is why im having my engine stripped unless a valve buckets gone or a valve spring headbolt etc.
Old Dec 31, 2016 | 12:59 AM
  #50
faz492's Avatar
e63 amg w212 6.3
Hey mate, My car had a vacuum leak, changed all the hoses and gaskets.
The car wont be back until Friday because they are doing further testing.
