Comparing tires for my C63
My p zero nero tires are shot right now in the back and while i don't drive in the snow even in the freezing cold they are not the best.
But it all depends what you want and need out of the tire. The Conti extreme is only ok. The Super sport is by far the better all around tire you will find right now for this car in my opinion.
Then...
Having said that, when I generalize tires for the car, I don't think of snow because if you have a C63, in my mind you probably have another car to drive in the snow. So I sort of through that out.
And people DD the c63, year round, as their only car. Shouldn't assume that because someone has a c63 they have something else for the snow so there's that.
"People act like the second you hit the throttle in a dusting you'll spin off into oblivion"
You absolutely could.
As for spinning off and absolutely being able to, please explain how? If you mash the gas on a dry day it takes you a second to get going. On snow if you mash it you won't even move.
You even talk about the light throttle in the car and how it's hard to control it... Does your foot weigh 50 pounds because you can make a c63 feel like it has less power than a Prius if you want to.
Did you want us to know you track cars? Because the OP never mentioned anything about tracking his if you want to talk about relevance. But I agree with you here, I also wouldn't use an all season on the track.
And then there's this:
Again, I'm not trying to start a tizzy here but you come out of left field talking about relevance and driving in the snow... but made the above contributions...
When you're driving in snow the main concern isn't even the process of getting a car going, but the process of slowing it down and stopping. The amount of power a car has is mostly irrelevant for people that have driven and know how to drive in snow.
And all of this stemming from a question about driving in Dallas freakin' Texas where you can run MPSS (A summer, not all season tire) year round. I'm glad the OP is going with that tire.
I'll even admit, I've had both of my c63's in snow on MPSS tires and I'm still alive. Never spun off into oblivion tapping on that on/off switch where I'm putting out instant WOT electric torque.... For reference, I live in Western NY... We get a little snow here. My neighboring area got 88 inches (OVER 7 FEET!) of snow in less that 4 days.
I also come from one of the coldest and snowiest places in the country. If your history in Lake Tahoe applies then my history does too.
Basically, I know a thing or two about snow and driving in it. We dove into snow much deeper than we even had to on this thread because again, it's Dallas.
Again, I feel like I need to reinforce I'm not try to start things up with you because I feel like we have gone at it in the past (can't remember) which is why I think you went out of your way to point out my pointless post. I know I can be a little annoying, but at least I'm not giving people bad info.
If you're shopping around though, you should really check out Nokian Hakkapeliitta r2's. Similar performance to the Blizzak if not even better in the snow but they also last much longer.
The LM60 will treat you well though.
I have successfully raced a lot in the rain, but we changed the set up of the car significantly (i.e. gearing, shock settings, disconnected sway bars, etc.), and put on proper tread design rain tires. In the rain I am assuming the trick to keeping the pointy end of the C63 in front, is simply to use a soft go pedal and common sense. Are all season tires fine for the winter rains? If the rain is bad enough I can drive my truck, as I did yesterday, but all things being even remotely equal, I didn't buy the 63 for it to sit in the garage.
Thoughts, ideas?
Then...
If you had the tire experience where others should take your word then you wouldn't suggest an MPSS is an all season tire.
Ratings & reviews Michelin Pilot Super Sport
CONSUMER SURVEYS
Based on 1,130 submissions of our online survey. Average Rating:
Performance Category: Max Performance Summer
Compare Ratings for All Tires in This Category
- Survey Stats
- 7,198,247 Total Miles Reported
- 1 out of 30 in Max Performance Summer Tires
- 100% vs. best in Max Performance Summer Tires
8.9 - Excellent
Wet Performance
9.0 - Excellent
- 9.0 Hydroplaning Resistance
- 9.0 Wet Traction
Dry Performance
9.5 - Excellent
- 9.5 Cornering Stability
- 9.6 Dry Traction
- 9.4 Steering Response
Comfort Performance
8.8 - Excellent
- 8.9 Ride Quality
- 8.7 Noise
8.2 - Good
Note: Consumer Survey Ratings are from 0-10 with 10 being the highest.
Perhaps, but having lived in the stuff, most people drive 4x4 trucks and all wheel drive cars in the winter. Just makes sense to most.
Relevant in the sense that is a lambo in the snow. Listen, driving in the snow is a matter of practice, experience, and confidence. That's the point of the video, have confidence in knowing that you can get a c63 down the road on snow tires if a lambo can climb up a mountain. Some people need to see things like that in order to build up a trust/confidence in the car they have and getting down the road.
Well when you hit the throttle on a car with that much torque and this touchy of a throttle, driving in the rain or snow makes it that much more dangerous. I would have thought that was obvious.
Dead wrong. Please tell me that you're kidding on this one. Now a C63 can feel as if you have less power than a prius?? Oooooook.
I can drift my bicycle in the snow and my little legs can't even put out 1hp I bet.
Sounds like fun.
Dads ran R888's and was one of the most if not the most well versed c63 owner with extreme builds, track time, etc.
That's great. It's still a bad tire for the C63. In fact it's not a good tire for heavy cars.
The tire's sidewall is not very strong, it get's louder the more weight that is put on it and doesn't last very long especially on heavy cars. Google Toyo Proxies 888 on heavy cars. I am by far not the only one saying it.
I don't think I ever mentioned I race or track cars in this thread at all, did I?
No offence taken, just a vast difference in opinions.
You assume everyone is a good driver these days when that's far from the case.
Never said it didn't.
I'm giving people info on my personal experiences and tire experiences. If I don't know the answer to something, I don't chime in, but when I do, I try and help.
Hope this helps or is readable on my part.
This link should be a tell all on the MPSS tire in the wet.
http://www.tirerack.com/tires/survey...pe&autoModClar=
As for the Michelin ratings, the aren't rating the performance of it up against all seasons and winter tires but other "Max Performance Summer" which is what they are listed at, not all seasons.
The Prius thing... I can lose a race to a Prius in a C63. Sure, the Prius would be going WOT and the C63 wouldn't, but that doesn't matter here. What matters is if you can't control the car, and torque, then you shouldn't be in it. And you can. It's not like the c63 throws you into the seat every single time you go.
Again, driving in snow isn't about going, it's about stopping.
I would argue that the MPSS is a very good winter tire. It's not a snow tire mind you, but it is very very good as a wet tire, which would be all weather even though it's not thought of as one. I would stack it up against any "all weather" tires in the wet alone.
The C63 has a touchy gas pedal and it has a slight delay. That alone can be challenging on a snowy surface no matter the tire due to the car being a torque monster. Yes it can be feathered, but it's far from ideal. There are times that I am lazy at a stop, then slightly push the throttle down a bit too much and the car spins. This is with race tires and limited slip on a dry street. You have to be on your game in the snow with this thing.
So I've made the decision to get the Michelin PSSs. As stated by multiple users on here, 9/10 times I won't require winter/all season tires around Dallas. In the case, that it does snow here, most of Dallas shuts down anyway.. haha.
But I have other cars, with more capable tires, so I probably won't take the C63 out in the snow anyway.
MPSS is just about the best all around DD tire. It really is the jack of all trades and the master at none.
Love it.
In my opinion the best way to make a Prius fast is to drop it off the cliff.
Or maybe you were in the Camaro? (You've got a beast Camaro, right? Old school?) MPSS are not a winter tire. Period. Just because it has wet performance does not make it a winter tire. Once it dips below a certain temp they become solid as a rock and are basically useless. Add in just rain to the cold, screwed. Add in snow and cold, yeah right.
Like, I understand what you're saying and much of what you say works for me. But I wont sit here and let someone say an MPSS is a winter tire, snow or not. That's all really.
Nannies disabled in the city, they impede way more than they assist. Nannies enabled on the hwy and she's very stable.
Ironically, I was driving my car up a an incline to a tire place that is very close to me to get my MPSS swapped out with my winter set up of Dunlop Wintersport 3Ds and I barely made it up a straight incline about 50 yards to the tire place. Traction was almost non-existent even on very light throttle. Only caveat I have is that the MPSS are fine in the cold when it is completely dry and driven sensibly but do you want to risk driving around on tires that literally don't work in snow or on black ice at all? They feel like hockey pucks when it's below freezing.
I have Michelin Pilot Sport A/S on my C63 now and tread on my rears are almost gone. It snowed this weekend about 6 total inches and I had very very poor traction in about 2 inches of packed snow early on in the storm. I actually had to leave my car in a parking lot overnight as when I left the house the roads were clear but by the time I was driving home the roads will 2 inches of packed snow and not yet plowed. I am replacing the tires this week as my C63 is my everyday car.
I'd agree that the MPSS is not a winter tire, but for a high performance tire, it works very well in the rain. Since the OP is in Texas, I didn't think snow would be an issue. So perhaps I worded wrong by saying its a winter tire, BUT it's a great rain tire and as good as all seasons in the wet, yet not having to give up your dry traction. Jasonoff said it best, its great at everything but a master of none.
I initially got DWS for C63 but finding a 18" wheel setup was a hassle, ended up throwing those on my daily 330i. Let me tell you the DWS are fine for driving around in 3-4 inches snow flat areas but inclines, steep slopes they suck ***.
Since my summer tires were worn out and bald I figured lets see what the hype about snow tires is all about. I don't plan on driving my c63 in much snow but its nice to know its equipped now.
Any tips on driving C63 in the snow? May sound stupid but this is my first real performance car and I am still learning the car and like to get many tips/opinions from other drivers as I feel it helps so much.
